Patchers - when do you give up on tube prone to "mystery" flats?
Quoted: 1074 Post(s)
Liked 295 Times
Hi all,
Even though I'm generally a patcher, and succesful and happy with that, I do sometimes treat myself to some new tubes.
This time, some Schwalbe Extralight.
One of those has been letting me down lately.
I came out, found the tire flat.
Took the tube out, pumped it up a little and found a 2 mm "pore" that had opened up on the rim side of the tube.
No sign of any pinching, rubbing or any of the other tiny signs one can see around a hole. Just a tiny, neat slit on otherwise pristine rubber.
Ran a finger round inside the rim. Felt OK.
And while the rim tape wouldn't have won any prizes, I didn't find any obvious reason for the flat.
Aiming to do it right the first time, I took the tire off, wrung it inside-out and gave that too a close look.
Nothing even mildly suspicious here.
Working off the vague indication of the status of the rim tape, I put another rim strip on, patched the tube, installed and inflated.
Two minutes later, there's a hiss and the tire goes flat again.
Pulled the thing apart, and there's another "pore" that has opened up, about 1" away from the 1st. Gave the rim another rub down and inspection. Gave the tire another inspection. Nothing.
Now, I know that actual material defects are comparably rare as a cause of flats, but here, it is beginning to look like the most likely cause.
(I had a bad batch of Geax tubes once which were prone to bursting unprovoked. Cutting them apart revealed a thin streak running along the tube, which was where they split open.)
What kind of defect would manifest like this anyhow?
The thin streak on the Geax batch was comparably obvious in comparison. The overstretched zone had lasting deformations in it. Cutting it open was simply verification.
So how many chances would you guys give a tube that flats for no obvious reason, one, two? Until you run out of patches?
Quoted: 839 Post(s)
Liked 1,064 Times
This ^^^ but if not the problem I'd give it about three tries. That's just me being the optimist trying to save a tube though. I use the Schwalbe Extra Lights as well, SV20 to be precise and am very happy with them. Never had an issue for a few years now. Of course it's not impossible to get a defective one and the way mfrs. move around to different countries to produce their products quality control is never guaranteed. The last time I bought these less than a year ago they were being made in Indonesia and are top quality. First I would try another tube to see if you get the same problem and go from there.
Its probably not the tube, its the tire. Theres something very small stuck in there that is causing the flats.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
Likes For San Rensho:
Quoted: 427 Post(s)
Liked 700 Times
Take a dryer sheet and drag it around the rim and around the inside of the tire. Dryer sheets are great for snagging and showing up any burrs.
Likes For freeranger:
Quoted: 1163 Post(s)
Liked 442 Times
I put 26 x 1.25” Schraeder valve Schwalbe tubes on my girlfriend’s Hard Rock mountain bike to make it road worthy.
One tube was fine, the other would go flat pretty quickly with no apparent source. The removable valve was tight and the submerged tube did not show any bubbles.
I ultimately replaced the tube and while that one did not have any apparent slow leaks, as bad luck would have it, it succumbed to punctures from little bits of wire staples on 2 different occasions.
I do wonder a bit about Schwalbe tube’s quality control. I thought I read somewhere (maybe on their website) that they individually test every tube, but I’m not so sure I trust that.
Quoted: 1572 Post(s)
Liked 643 Times
My bet is it's the rim strip. If you are using those plastic things rather than rim tape, I'd double my bet.
It only takes the tiniest little arc of unprotected spoke hole. Ultralight inner tubes, I assume, would require even less exposure. When you pump your tire up to operating pressure, the air pressure tries to press the inner tube against that raw metal edge.
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
I give up on patching when the valve stem develops a cut!
I know these special rubber bladders aren't invincible, but I haven't had a large enough pinch flat or blowout that's too large for a cement patch.
Liked 295 Times
I fitted a rim strip since it was faster, one that came off a wheel that hadn't had any problems.
And while I can see a sharp edge on a rim strip causing issues eventually, one puncturing a tube while the bike is parked does seem extreme.
Señor Member
Quoted: 649 Post(s)
Liked 293 Times
Any failure or leak at the base of the valve stem, or inside the valve, makes replacement necessary. Rough handling when pumping (esp. removal of a too-tight presta valve chuck) is the usual cause of this type of failure.
Any other leak can be patched.
'Mysterious' or repeated leaks are almost always caused by a problem with a component other than the tube - rim tape, tire, rim, spoke, etc., and replacing the tube without finding and fixing the root cause will just result in the new tube getting damaged. If I am getting repeated flats and find a previously unnoticed tiny thorn or piece of wire in the tire was causing it, removal of the cause and a patch on the damaged tube is sufficient.
Likes For Wilfred Laurier:
Liked 295 Times
Update:
After the front developed a leak too, seemingly while being parked, I ditched the tubes in favor of some from my patched stock. For now at least the issue has been resolved. No more pores opening up after inflation.
