Aluminum frame with carbon fork, ideas?
Hi everyone, first time on the forum and looking to purchase a second bike, aluminum frame with a carbon fork. I'm 5' and normally ride around town, some dirt trails. My first bike has lasted me almost 20 years, 2003 Trek 7200 Multirack 15". Still looks great! Anyone have experience in one of these or any other suggestions:
Cannondale Quick Women's 3 (light gray)
Trek FX 3 Disk Women's Stagger (black or magenta are nice)
Sirrus 3.0 Step Through (powder blue)
durability your question? i got a aluminum frame with a carbon fork. ******g hate the fact that it's carbon. weak link. that said, in the two months that i've owned the bike i've been in two crashes where a lot of parts needed replaced, the fork not being one of them. it's an fx 4, which is very similar to an fx 3.
i test road both an '20 fx 3 and a '20 quick 3 and preferred the fx 3. because the frame on the quick didn't fit me right. they look a lot cooler than the fx series.
i don't ride dirt though. 100 percent city.
Quoted: 529 Post(s)
Liked 255 Times
I suggest, work out how much weight you will save, then decide if it is still important.
If you don't limit yourself to a carbon fork, you will have a much bigger range of bikes to choose from.
But it is up to you.
The weight savings will be around 300g (~800g for an aluminum fork vs. ~500g for a carbon one). That's half or less of a water bottle. However, ride quality might be another point to consider.
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
Don't overlook bikes with high quality steel forks. Good steel forks (butted chrome moly steel) don't weigh a lot and generally offer a very forgiving ride quality.
Bikes: Had an old Columbia in the 80's, here a used Schwinn hybrid, now a Cannondale Quick 3 and a Topstone 105..
Quoted: 249 Post(s)
Liked 306 Times
For what it's worth I had a Quick 7 with a moly fork and bought a Quick 3 with carbon blades. The 3 is much better in my perception for vibration dampening but I do not take it off road at all. I have a Topstone for that and that has a full carbon fork. The 7 has been sold and the 3 and Topstone are my go to bikes. I would stick with the Trek if the frame geometry is good for your build. They don't fit me as well as the Cannondale's do so that is my choice.
Frank.
Frank.
Quoted: 1088 Post(s)
Liked 1,025 Times
I'm going to guess that being 5' and looking at women's frames and climbing stairs its a bit of an upper body strength and in which case yes the carbon fork matters and has no real disadvantage that I can think of. I've never had a particular liking for specialized, decent MTB but never impressed me in any other way, but there's plenty who will disagree with me. Both the C-dale and Trek are models I like and had considered for my wife, I would not worry about the fork on either model and they will make the ride more comfortable. Until 2 years ago Trek had been the brand that I had used the most but since then C-dale has just been producing lighter, better equipped bikes for the money for me.
Though looking at just these two I'd be more inclined towards the Trek, the C-dale does have what I'd consider better hubs being thru-axle which I also think are easier to use. However the trek parts are one level higher on most parts being Acera on the trek vs Altus, the trek has a much better crank while the brakes are both hydraulic.
Only other brand you might want to look at is a Liv, the thrive 2 might be in line though at 850, they don't like to post weights and from my experience they can be better equipped but still come out heavier which is something to consider.
