Pressure Washing?
Bikes: Garmin/Tacx Bike Smart
Quoted: 646 Post(s)
Liked 289 Times
Pressure Washing?
Just wondering if anyone has used a pressure washer to clean their bike. I know you don't want the 4,000 PSI model since you can damage bearings, but would carefully using a smaller lower pressure unit be OK? If so, what make/model?
Not a newbie to cycling
Bikes: Omnium Cargo Ti with Rohloff, Bullitt Milk Plus, Dahon Smooth Hound
Quoted: 356 Post(s)
Liked 323 Times
No. Just no. You can use a hose, but don't squeeze the end to "really get in there".
Likes For CargoDane:
Blamester
Yes just be careful. I just use the ones at gas stations for cleaning cars.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
People that say 'never' don't have a clue. Moderate pressure, correct distance, and not pointing it at the wrong places will make sure you're fine. I've pressure washed hundreds of race bikes and before you spout the classice "but race teams have an unlimited supply of spare parts" line we may have a ton of parts in the trailer but we don't want to be replacing parts all the time, we like to have dinner and get some sleep. You can most definitely use a pressure washer safely to help clean a bike.
Quoted: 356 Post(s)
Liked 323 Times
Normal water pressure from the tap with a wide spray nozzle is enough. Hence the "never use a pressure washer".
Of course, if you clean your bikes from a truck, you need something to actually provide some pressure (as in tap-pressure).
Quoted: 6196 Post(s)
Liked 4,811 Times
Is this a cyclocross bike or other off road bike that is caked with mud and other slime? Sure, I'd pressure wash it.
If this is just a road bike with what for me is normal road grime that takes many miles to accumulate, then I' just use a couple wet wipes of some cheap brand. They even hold together well enough to roll up the used ones and then get between the cogs.
Is it perfect? No, but you'll never tell as I pass you! <grin>
Likes For Iride01:
Quoted: 646 Post(s)
Liked 289 Times
I use a cheap Harbor Freight electric pressure washer, always with a wide spray at a distance 6"-8"", so that I can put my fingers in the spray without damaging the skin. I direct the spray parallel to the cassette cogs, so as to clear away the grit, and to knock the schmutz from the chain. Likewise the front chain rings, and anywhere else that grit has found a new home. I recently disassembled the front crank and found zero moisture in the bottom bracket, so I might be doing it right.
Quoted: 646 Post(s)
Liked 289 Times
Quoted: 604 Post(s)
Liked 1,064 Times
I’ve wrecked a lot of stuff using a pressure washer, never tried a bicycle though.
Tim
Tim
If you have the task of pressure spraying the concrete driveway, a high power gasoline driven sprayer might be called for. You can do it with a cheap electric model, but it takes a while. My cheapo does a good job on most tasks, from deck prep for painting to truck washing.
Quoted: 1814 Post(s)
Liked 923 Times
I barely wash my bikes at all, so wouldn't use the pressure washer if just for the hassle of setting it up,
but they get used all the time for CX racing. More chicken-littleing, IMO.
I use a bucket of soapy water and some brushes, and a hose with the "shower" setting to rinse it. What would be on a bike that needs a pressure wash?
I use mineral spirits, paper towels (the all-paper variety), plastic gloves, do it outside, take a ride immediately so all the solvent vaporizes, no water.
Bikes: lots
Liked 2,932 Times
Ever been to a muddy CX race?
Quoted: 2604 Post(s)
Liked 1,933 Times
You need experience using a power washer to wash your bike safely without damaging anything. How do you get that experience? By washing your bike with a power washer and damaging something.
Probably safer for people who haven't washed hundreds of bikes this way to stick to a garden hose.
Likes For pdlamb:
Quoted: 1944 Post(s)
Liked 2,164 Times
For one bike I wouldn't spend the time to set up a pressure washer.
Even on my mountain bikes I use diluted Simple Green in a spray bottle and a hose with a fine spray nozzle.
John
John
I use Dawn and a soft brush on the frame and a stiff brush on the wheels and drive train. When I am finished with the soap I rinse my bikes with a low pressure flow from a lawn nozzle.
My buddy Chuck the physicist took his muddy mountain to the carwash and proceeded to wash the nasty grease out of his BB bearings. After a while it began to make a dreadful noise while we were on a week long ride in Virginia.
Btw maintenance and washing is not the same thing. (I'm aware you didn't make that claim, but ppl tend to conflate the two)
Likes For Racing Dan:
Liked 4,811 Times
I myself wouldn't like the time it took to set up the pressure washer or how wet I got with it. But if it works for you then keep at it and you can thumb your nose at all the Nay Sayers claiming doom and gloom.
Bikes: lots
Liked 2,932 Times
But then why use a pressure washer. The same thing can be achieved with a garden hose with a shower head. Im sure you can (safely) use a pressure washer, but in a private setting, why would you?, except to save one or two minutes over the garden hose. In fact rigging and unrigging the darned thing may take up more time than you save ... :-) From a maintenance point of view there is no benefit at all, possibly even a (small) chance of ruining a bearing or spraying water into cable openings in the frame.
