What happens when cyclists hit potholes?
Quoted: 6199 Post(s)
Liked 4,816 Times
We have that too. However thankfully in my case, the routes I ride are thankfully some of the better maintained or the road just doesn't seem to get potholes.
Quoted: 4806 Post(s)
Liked 3,933 Times
Potholes vary tremendously, and likewise the effects of hitting them at various speeds. So, other than the conclusion that they're not good, there's not much to summarize.
Actually, there is one bit of useful advice, which is not to use the front brake as you're hitting a pothole.
In pothole country, I ride the drops a lot.
Liked 4,816 Times
I did note that when I changed back to 38cm wide drops from the 42cm wide drops I'd been riding for about 4 years, that I was able to dodge pot holes and other road hazards seen at the last moment better. Though that's not the reason I went back to 38cm wide drops.
That is one of the hazards or obstacles, so ride vigilantly at all times, and avoid riding at night! If you truly want to ride, you must accept there are risks, but with smart riding you can beat these odds. Always use a helmet and all gear to give yourself the best chance for survival without bad injuries . Keep God in your life with much prayer and dedication, and you'll be blessed.
In my childhood, I used to carefully guide the thread through a needle's eye, and stitch clothing for fun. Today, I carefully navigate the bike through debris, stones, pointed objects, and potholes, for fun as well.
Never have I been more attentive and vigilant to the streets I am traveling on. Never has my focus and concentration been so high.
Quoted: 3352 Post(s)
Liked 1,056 Times
Most cities, and I know mine should have signs when entering the city that say -----remove dentures and tighten bra straps, rough road ahead!!!
Liked 3,933 Times
So, I was told to do some now unpopular things. Especially - ride the drops in all iffy situations; that it was far better to hit that unseen pothole and come out still riding and physically unhurt if our hands stayed on the bars and in positions where even if our grip wasn't enough; we still had bars in the crotch of our thumb-fore finger. (Modern brake levers; our hands can slip off completely unless the levers are mounted far back and near vertical. In the old days, levers weren't very comfortable and if we hit that pothole, we jammed that crotch on the brake cable. Rude awakening but our hands stayed on! And we all did that at least once.)
In the '90s and '00s I read how the modern thought (by some rather famous big names) was that you rode the brifter hoods with relaxed grip to maximize blood flow to the legs. My former coaches were probably reading that and cringing.
Quoted: 2112 Post(s)
Liked 663 Times
So your useful advice is more or less, really?
Get off your saddle if you can is the only, only, only, useful advice.
-mr. bill
Quoted: 5793 Post(s)
Liked 2,594 Times
So, by your standards, your triple "only" advice is no better than mine.
The reality is that we both endeavor to advise less experienced bicyclists, knowing that those who don't need our help will ignore it.
FB
Chain-L site
FB
Chain-L site
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
I don't know about Boston or NYC, but Oklahoma potholes are as bad as anywhere. And in the little armpit of Kansas I grew up in, I was fortunate to learn about potholes at a young age on a heavy, balloon tired bike before I bruised easily and healed slow.
The ironic thing is where I ride my bike, I don't have a lot of problems with potholes. But my drive to work in the morning this time of year requires memorizing where the potholes are.
Happy banana slug
Quoted: 1533 Post(s)
Liked 1,530 Times
It's 32 minutes of discussion of the forces involved in hitting a pothole; how much force does it take to knock a bike rider over? How deep is that? The point is to give city governments solid data to base their repair policies on rather than "oh cars can handle that, no problem".
Liked 2,594 Times
However, while the data may be useful, it still leaves a lot to subjective judgement because there are so many variables.
Do we design for the least skilled rider on the least stable bike, or seek a reasonable(?) cost benefit balance?
What speed do we assume for folks on bikes? How about E-bikes?
What is the wheel size mix?
These are important judgements that go beyond the physics of bikes and potholes. Critically important now with increasing numbers of small wheel (16-20") E-bikes in use.
Lastly, we need to make a value judgement about how much skill we want to expect of cyclists, who are rationally mist responsible for their own safety.
I like cats.
I think it's great that someone is exploring this. Potholes are made by motor vehicles and the depth and size are commensurate with the pressure of a multi-ton vehicle over a contact area of something like 15-25 square inches. We all know that the hazards to a cyclist are very different from those experienced by a motor vehicle, yet there's little motivation in many cities to repair potholes until they pose a larger danger to motor vehicles.
Likes For ericoseveins:
Yep
Broke a Campy Record axle many years ago hitting a pothole in southeastern Turkey. No flat or bent rim - just a broken axle.
Liked 2,594 Times
That's because Turkish potholes are different than the ones here.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Yep
Lucille
I recently read a post elsewhere about a cyclist who biked into a water covered street, hit a pothole, damaged himself and the bike, and wanted to sue. Others were telling him that he should not have attempted cycling on a flooded street.
Likes For Lucillle:
Liked 2,594 Times
Being an all season cyclist in NYC had its unique challenges. Water filled potholes were my number one cause of dented rims.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Likes For work4bike:
Quoted: 5224 Post(s)
Liked 3,585 Times
Liked 3,585 Times
can help but remind myself, night riding opens one up to road hazards, just like this
The more common road hazard has been the grates (cast or using rebar) that can swallow a bike tire. Railroad track crossing are another hazard and often there is not enough room for bicyclist to cross safely at a 90 degree angle.
A universal problem is highway personnel filling potholes with dry patch and tamping it down. It lasts a week or two and then the hole is back again. I contacted my local official and he has placed a special hot patch machine in the county budget for the next fiscal year. He is doing it for the motorists but bicyclists will benefit as well.
