Panaracer Gravel King??
Quoted: 455 Post(s)
Liked 112 Times
Anyone have any experience with these tires? Looking for a Schwalbe Marathon Supreme replacement. Sixes 26x2
Likes For Tandem Tom:
Quoted: 3242 Post(s)
Liked 2,086 Times
I use a GK SS on my gravel bike. They are 700c, sized 43mm. They are a pretty decent tire on dirt, with enough bite to allow cornering on single track. They also roll surprisingly well on asphalt. Mine are wire bead and I use with tubes.
Likes For Steve B.:
Quoted: 804 Post(s)
Liked 2,985 Times
Likes For '02 nrs:
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 810 Times
Been running GK Slicks for years in 700x28 & 700x38. Very fast tire. They are a go-to road tire for me in road bikes that can only run a 28mm tire. For 35mm+ also a go-to, though I've been trying other tires(loaded up on some Marathon Supremes before they disappeared) as the GK Slicks tend to have a shorter life for me. I'm around 225lbs.
I've mentioned it before..in 26x2 I'd (and I have more than once) go to Schwalbe Big Bens. Not the heavier Plus or GreenGuard, plain old Big Bens. Great tire with and without touring weight.
Likes For fishboat:
Sunshine
Quoted: 10965 Post(s)
Liked 7,491 Times
Yeah, probably half the internet has experience with GK tires. They are some of the most popular tires for mixed use and gravel over the last 10 years.
I have used the GK Slick for years in 32mm and one of my kids has 28mm GK Slicks on her road bike. They roll well, dont puncture frequently, and are relatively inexpensive. These are used with tubes.
Ive then ridden through multiple pairs of GL SS 43mm tires on my gravel bike. Again- roll well, durable, and relatively inexpensive. These have all been tubeless.
The consistent complaint about GK tires, and I fully experienced this, is that they are atrocious to set up tubeless. Panaracer's standards were horrible for years and the tires were entirely too floppy so it was tough to get the bead to seat on the shelf.
Panaracer just announced new GK tires with a full redesign, and its way past due. The new tires are supposed to actually set up easily on tubeless rims.
New models will be in 5mm increments, so 35mm, 40mm, and 45mm.
I am guessing there is a decent sale on GK tires because vendors are trying to get rid of their stock of the old models.
Likes For mstateglfr:
Quoted: 455 Post(s)
Liked 112 Times
Fishbowl, it appears they are 2.15 and I don't think they will fit with the fenders.
Bikes: 3Rensho SuperRecord Export, Bridgestones MB1 RB1 XO2, Colnago Super, Medici GranTurismo, Schwinn Paramount, Olmo Competition, Raleigh Portage, Miyata 1000, Stumpjumper, Lotus Competition, Nishiki Maxima, Panasonic DX6000, Zeus Criterium
Quoted: 30 Post(s)
Liked 82 Times
considering these tires too (2 x 2.15") curious the actual mounted width of the tire. they'd be tight on my bike for clearance
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 457 Times
I have the 38's. They're ok, but I prefer the Supremes. Rolling resistance is ok, but not great. Good grip. I've never had a flat on them, though iirc bicycle rolling resistance shows them with lower puncture protection.
I might try the 37c Panaracer Pasela. 380 grams.
I used to have the 26" Big Apples which were good, but heavier.
In case you cannot find the gravel kings in your size, I have the Continental race kings and am quite satisfied
Quoted: 759 Post(s)
Liked 810 Times
You might consider the Big Apple as it comes in a 26x2, good rolling tire. The Raceguard / Addix versions are the ones I run in the BB, they have the same version in the Big Apple. Never have issues with flats.
https://www.schwalbetires.com/Big-Apple-11100298
I have a Gravel King SS on my front wheel right now, running with a tube. Prior to this I ran a Marathon Supreme on this wheel.
It rides fine, but the puncture resistance is inferior to the Marathon Supreme. I know this is anecdotal and it's just one case, but I got a puncture from a triangular pebble, not even glass, that would have never punctured a Marathon Supreme. I couldn't believe it when I pulled it out. If you're going to run it with sealant then this doesn't matter.
Quoted: 455 Post(s)
Liked 112 Times
So here is something I thought about today on the ride into the bike shop where I work.
I converted my Giant Escape to an ebike in 2022. I put Kenda Komfort tires on them because we had some at the shop. After riding 3000 miles since2022 just back and forth from the shop they still look like new tires.Thies are 770c x40mm. So I just checked our supplier and a 26 x1.95" weights 690grams. I can get the for under $20.
Thoughts?
Thoughts?
Sunshine
Liked 7,491 Times
Thoughts?
Thoughts?
If you want to put Kenda Komfort tires on because another bike of yours has em, ok do it- you have experience with em and clearly dont mind the weight, rolling resistance, or hard material.
Wild that you are asking about GK tires now that I know you work in a shop. They are one of the most commonly used gravel tires for the last decade. Surely co-workers would have experience riding, selling, or seeing them and would weigh in. Seems better than the internet?...but at the same time, you now want to put some plastic feeling Kendas on, so what I think would be a logical first step is clearly not important.
Quoted: 455 Post(s)
Liked 112 Times
Though we have a number of tires to select from touring is not common so other than Schwalbe tires I don't have a real life touring situation to ask about other tires.
Yes we carry and sell Gravel Kings but the customers that buy them don't do any touring.
Sunshine
Liked 7,491 Times
For what it's worth, I have found that a tire works the same for touring as it does for gravel and road riding.
Quoted: 455 Post(s)
Liked 112 Times
Not sure that is completely accurate. The gravel riding guys we servive don't typically carry the weight and amount of gear for the extended period of week after week of riding. So the durability issue of the tire is a key factor.
Sunshine
Liked 7,491 Times
There is 0 meaningful difference between me on that gravel bike and a 175# person with a 30# traditional touring bike and 20# of gear and food. Given the variance in total system weights and it being a total unknown for each of the people that have responded to you, just trust that GK tires competently and easily handle way more than 250# of weight and tires don't care if the weight is on the rider or bike.
Also, tires don't care that they get ridden every day- be it road, gravel, or touring tires.
You mention tire durability. Do you think purpose build gravel tires by default lack durability? The Marathon Supreme tires you plan to replace are not inherently more durable than any number of commonly popular quality gravel tires.
As an experienced touring cyclist and shop employee, I am sure none of this is new.
Quoted: 455 Post(s)
Liked 112 Times
You make a good point!I will order a pair for my bike. Thanks!
