1974 World Voyager Dropout Screws
The rear dropouts have the screws that go in from the rear to adjust the hub location. They have lost their heads, and I am not sure if nutting them up would give enough purchase to twist them out. any ideas?
Quoted: 380 Post(s)
Liked 106 Times
They should screw out from the axle side with a small flat blade screw driver. If the thumb nuts were on that side and are missing they were installed backwards sometime in the bikes life. If that is true they should just screw out from the back side. Roger
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
I've never been able to figure out what the outside knurled nuts do on those dropout adjusters. If you try to spin them by hand, they just unthread from the screw anyway. I guess if you Loctite them onto the screw, you can then turn them by hand.
I've always adjusted them with small screwdrivers from inside the dropout slot. Being a once-every-5-years type of procedure, it's not a big deal.
loose spoke
Classic & Vintage
30
11-08-22 07:43 AM
mixtemaniac
Classic & Vintage
11
03-22-11 10:36 AM
