Too much Orange Seal in tyre? Any concerns?
Quoted: 800 Post(s)
Liked 512 Times
I'm fairly certain I put too much Orange Seal in the front tyre of my road bike. I'm basing this on the fact that
a) when I was done adding the Orange Seal the sealant kept bubbling up and out of my coreless presta valve; and
b) the Orange Seal dip stick was showing sealant above the line.
Any side effect of having too much sealant in the tyre? Or just the extra weight?
Shouldn’t be a problem as long as the tire is still mostly filled with air.
Non omnino gravis
Quoted: 800 Post(s)
Liked 512 Times
Great. Thanks everyone. DrIsotope I'd estimate I put in 50ml in my 25s. The tyre is holding air, so all is good. Cheers.
nothing to see here
Quoted: 218 Post(s)
Liked 145 Times
I don't have very good luck checking the sealant level in the tire after adding sealant. The stem gets coated on the inside and it sometimes gives a false reading on the dipstick. Just check once, add selant as necessary and move on with life.
Bubbling out the stem is pretty common for me if I don't add sealant with the stem at the 3:00 or 9:00 position.
Quoted: 18883 Post(s)
Liked 10,646 Times
I get bubblies out the valve stem when I don't have it at 12 sometimes.
Quoted: 4717 Post(s)
Liked 1,882 Times
