Type A vs. Type B Down Tube Shifter braze-on bosses
I have been trying to find a simple photo that can be easily used to identify the difference between a Type A and Type B braze-on.
in addition, A uses a 5mm screw while a B uses the narrower, uncommon 4.5mm screw.
Note: top frame is Type B, bottom is Type A
I hope this helps
I hope this helps
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,026 Times
All I know is that the red frame's Type A shifter doesn't play well with others and is on a Schwinn Voyageur circa 1984-1985, which is a big reason why I didn't buy such a frame recently (didn't want to bother filing things).
I am going to make an edit because the Top frame is a Type B while the bottom is Type A
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1239 Post(s)
Liked 3,582 Times
Wait, which is which? Video says 'Type A' but shows the one on top (maybe that is just an unintentionally misleading still frame), whereas you mention the top one (red frame) being type B. But thank you, didn't even know different types existed. So the goofy, non-square one is type B?
There were 135 Confentes, but only one...Huffente!
The bottom frame is the more common Type A.
Bikes: yes
Quoted: 512 Post(s)
Liked 409 Times
A commonly posted issue. There are multiple threads about this, with solutions ranging from hunting down the parts, modifying the keyhole shaped mounts and threading, and converting to brifter or bar-end shifters. I did the latter with my 85 Centurion Ironman.
Here's a list of related threads:
Modification: Old style Shimano downtube shifter mounts to later style - Bike Forums
Shimano 600 shift lever woes on a Centurion - Bike Forums
Do I have "B" Style Shifter Bosses? - Page 2 - Bike Forums
Shimano 4.5mm Type-A Shifters / Downtube Braze-ons - What are my options? - Bike Forums
Help Me Out With Shifter Boss Covers on This Miiyata 912 - Bike Forums
cable stops for unusual downtube brazeons - Bike Forums
Downtube shifter boss compatibility - Bike Forums
https://simplicityvintagecycles.com/2...aga-continues/
There's an online vendor called Loose Screws, which used to be bike oriented, but has shifted to firearms. They still have old bike stuff for sale though, including stuff that might work for you.
Shimano Dura Ace 4.5mm Downtube Shifter Screw w/D-ring - I used these to get cable stops on my shifter mounts, for use with bar end shifters. I removed the D-rings by putting the screws upside down in a vice and tapping them with a hammer to pop-off the D-rings. Having the screws is half the battle. These are them.
Shimano Z-401 Friction Downtube Shifter Set - can't vouch for these and the description incorrectly describes them as "Italian type", which they're not.
Shimano Dura Ace EX Downtube Friction Shifters Set - another bad description, but looks suspiciously like the correct shifters.
Likes For Vintage_Cyclist:
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 152 Post(s)
Liked 177 Times
These can be handy: https://www.mcmaster.com/products/sc...ead-size~m4-5/
Bikes: '85 Schwinn Madison, '46 Higgins Ultralite, 1950s Wally Green, '85 Trek 660, '82 3Rensho Export, '90 Trek 970, '91 Schwinn Paramount, '78 Dawes, '78 Trek 730
Quoted: 78 Post(s)
Liked 272 Times
Type A components (Shimano Z series)
Quoted: 567 Post(s)
Liked 1,057 Times
I hope this helps
RJ the Bike Guy - Shimano Type B shifter boss
I hope this helps
If one chooses to stick with downtube shifters, the only 3 options are clamp-on shifters (aesthetically unpleasant to my eyes) or the other 2 varieties you can find in the links above which are specific to these bosses.
The most extreme but effective solution is having the more common bosses brazed on but that would involve refinishing the frame.
Old fart
Quoted: 3597 Post(s)
Liked 3,421 Times
I hope this helps
I hope this helps
Quoted: 567 Post(s)
Liked 1,057 Times
I guess I was in error. I read the round bosses were the B and the normal/ Campy bosses were A.
I don’t internet well…
Quoted: 3464 Post(s)
Liked 2,831 Times
The Campagnolo style of boss dates back to 1953, I have an Italian frame that had them as original.
they were not used frequently.
I also have an Ideor that employs them. It dates from 1958.
Braze-ons were an active argument regarding frame strength and durability for a long time.
