Cateye wireless speedo not working on ebike
Hi.
I've just fitted a Swytch bike kit to my bike. Whilst I am pleased with results, there is one problem: I have a Cateye wireless speedo fitted to the bike, with the sensor on the front wheel. When the electric motor in the Swytch wheel is running, the speedo no longer works: it drops to 0mph. If I then switch off the motor via the power pack the speedo starts working again. Similarly, when pedalling with the motor running the speedo stops working, but as soon as I stop pedalling, it starts working again.
I can only assume that the Swytch motor is interfering with the wireless signal to the speedo. Any ideas on how to solve this?
Old newbie
Bikes: 2022 Trek Emonda SL 5, 2002 Klein Quantum, 2000 Trek 8000, 2011 Trek 7.5 FX
Quoted: 18 Post(s)
Liked 77 Times
Buy a GPS bike computer. I recently did, and I'm never going back. I took the wireless/magnetic computers off of all of my bikes. I use the Wahoo ELEMNT Bolt on all of them.
Yes, likely electrical interference. I had that happen with a Cat Eye and a headlight! putting some distance between them (i.e., the light and the main Cat Eye unit) solved that problem. But if adding distance (and/or shielding) doesn't fit your problem, you may need to go the route CC suggested and migrate to GPS technology.
Good luck!
Good luck!
Quoted: 340 Post(s)
Liked 275 Times
Turning on my Cree LED light would hammer the wireless in my $10 bike speedometer, So I went to a $8 wired speedometer to solve that issue.
Definitely RF interference, I used to use a Cateye Micro wireless, it didn't work when I used my front light, and it went nuts when I close to some automatic doors. The speed would bounce around when I was standing still, 15,45,25,75, etc.
I now use a Cateye Stealth, a GPS unit. It works great, no interference. And I can switch it between bikes, it makes life easier.
All the Swytch components are up front and on the bar so the interference would be strongest there. I don't know how much range the Cateye has but it might be worth moving the sender unit to a seat stay. Sounds iffy, but who knows, if might be a no-cost fix.
Likes For fooferdoggie:
I had the same problem with my Swytch bike and velo wireless +. Resolved it by moving sensor to rear wheel and display to crossbar approx 100mm from the front of the seat. Not ideal, but it's a fix I'm going with.
