Work stand?
Work stand?
My wife rides a Ride-1-Up 700 ST. She loves it, makes her happy, which in turn makes me happy. It's big and heavy about 65 lbs. I've been wonder how I'll support it when it's time for maintenance. My bike stands are more suited to much lighter bikes. Today she had a flat, on the rear tire. What a PIA to change the tube, between the weight of the bike, and the motor in the wheel, and (what I would consider a design flaw) the interference of the derailleur and the axel, and the flats on the axel having to slot into the dropouts, and the motor wiring, it was the most difficult flat to fix I ever had.
I help it up with some straps over a garage rafter, not ideal because it swings around.
Any thoughts on a work stand, or other method to hold the bike for repairs and maintenance?
Enjoy the ride!
Enjoy the ride!
Quoted: 680 Post(s)
Liked 949 Times
I use a Park Tool PCS-10.2 but I also drilled a hole though the clamp on bottom as it can slide and collapse at random times. Rear hub motor bikes are no pleasure to change a tire on.
Ride more, eat less
Quoted: 715 Post(s)
Liked 737 Times
As a bicycle mechanic for decades, I try to avoid putting a heavy ebike onto a workstand.
Easy enough to just flip the ebike upside down and have it rests on the saddle & handlebar to remove the rear hub-motor wheel if need to.
Don't need to pull the rear hub motor/wheel completely off the bike to replace an inner tube, just have the rear wheel rest on the chainstays while the ebike is upside down.
55+ Club,...
Bikes: 9+,...
Quoted: 1115 Post(s)
Liked 849 Times
My ebike is 47lbs (at least - Qualisports Dolphin), so I'll tough it out and flip it over when I get a flat. Otherwise, too heavy for me to risk using a bike stand to work on it.
Likes For tds101:
Quoted: 883 Post(s)
Liked 823 Times
As above, even though I have an excellent (IMO) Park stand, I invert the bike to install a tire (I've never had a flat with Schwalbe Marathon Plus tires which I recommend).
Likes For 2old:
For minor work like chain maintenance, cleaning, adjustments, etc. I set the rear wheel in the bike trainer/exercise stand that I use inside in winter. If I am adjusting the front brakes it is easy to just lift the front enough to spin the wheel to check clearance. I've tried suspending the bike but it is quicker and more stable to just set it in the stand.
But I have inverted the bike to change tires and the rear cassette like cat0020 indicated. I support the bar with a couple of pieces of 2x4 to keep it from resting on the ebike display and headlight.
I bought a set of these portable handlebar jacks that I can carry with me on my rides and it will protect my bike computer when used.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Likes For northtexas:
Park Tools makes bike stands that can support the weight of a heavy e-bike and the legs fold up to make it easy to store them when not in use. I paid $180 for their PCS-9.2 home mechanic bike repair stand and it was OK with a 70 lb e-bike but barely. I ended up selling the two 70 lb e-bikes and buying two Class II bikes that weigh 27 lbs and are a lot easier to manage.
Quoted: 680 Post(s)
Liked 949 Times
Bikes: '97 Bianchi CDI, '97 Specialized RockHopper, '13 Specialized Sirrus Pro, '13 Trek 8.5 DS, '13 BH EasyMotion NeoXtrem, '14 Trek Domane, '86 Schwinn AirDyne ;)
Quoted: 39 Post(s)
Liked 23 Times
My Bikehand stand can handle my 45-lbs-sans-battery e-bike, fairly steadily, though I do check all its joints before I load that weight on it. I've mostly only used it to lube my e-bike each spring. But your bike is significantly heavier, so I couldn't say. At 74, HOWEVER, I value my REI membership, AND they fix flats for free -regardless of your age . Of course, that shop is 10 minutes from me: If there is one in middle NJ, you might consider that, Last year, they replaced 2 tires and installed 2 tubes (I had to convert to tubes to get the tires) that I brought in, and put on a new chain, all for the price of the purchased chain. (NB: I don't know how each store's prices and policies may vary. I've used a shop in California that does vary some.)
Quoted: 967 Post(s)
Liked 1,631 Times
Definitely the way to go. Especially with an E-Bike or a heavy Mountain Bike. Take your time setting it up. Put bracing support overhead. You may have to replace the pins on the pullys. Change out the rope for a higher quality oil resistant type. Get rid of the metal claws that will tear up your seat and handle bars and go to straps. Be sure to position the hangers close to your work area and tools. Your going ta love it...
RAD Sportz Bicycle Hoist 20 USD
Miles to Go
Advertised weight limit of my Parktool PCS 10.2 is 80 lbs. My E-bike is 55 libs sans battery. I might try it with the bike stand, otherwise the pulley system looks like a good idea to me especially if you don't already have a bike stand.
Likes For timdow:
With heavier e-bikes one needs to add special equipment if you want to do it yourself. I added more tools for our bikes that I did not need with my non electric road bikes. I addedd the Park Tools stand as the easier it is to work on the bikes them more inclined I am to do work sooner instead of waiting until I can leave the bike at a local bike shop.
I also need more room for our 7 bikes (9 at the start of year but sold one and gave the other to the fellow who made the original custom frame) and so erected a 8x10 shed near the house on a concrete slab. Part of the cost of ownership for us.
The heavy bikes also required a heavy and very expensive 1Up platform style receiver mounted bike rack which with our selling the two 70lb bikes is now overkill for our other bikes.
