Which brake pads are better?
Old 04-09-13, 08:01 AM
pavement_nyc
Quoted: 9 Post(s)
Liked 22 Times in 6 Posts
XLC Road Brake Shoes vs. Dia Compe
https://www.niagaracycle.com/categori...set-of-4-black
https://www.niagaracycle.com/categori...-box-76gx-grey
They will mostly be used for bikes with steel wheels, I want to start using better pads than the ones I've been using, which are these:
https://www.niagaracycle.com/categori...-shoes-box-100
pavement_nyc is offline
Old 04-09-13, 08:24 AM
Spld cyclist
Spld cyclist's Avatar
Bikes: 2012 Motobecane Fantom CXX, 2012 Motobecane Fantom CX, 1997 Bianchi Nyala, 200? Burley Rock 'n Roll
I don't have experience with these particular choices, but I have found that there is a huge difference between the cheap brake pads I have used and more premium choices. I mostly have Koolstop pads on my bikes now and really like them. I have one bike with Aztek pads, which are also pretty good. I'm not a big fan of Shimano pads. They stop well, but seem to pick up a lot of grit where the others don't.
I shop at Niagara too, but I usually look at Amazon for the huge number of user reviews available there. Since Niagara is an Amazon seller, you'll probably find these on Amazon, and there is a good chance that you'll find some user reviews for them.
Spld cyclist is offline
Old 04-09-13, 08:34 AM
Continuity
Bikes: 1992 Marin Eldridge Grade, 2007 Kona PHD and 199? Trek 1000 (current build project)
Kool-Stop Continentals are very well thought of for those kind of rims and brakes:
The leather-faced 'Raleigh Raincheck'-type blocks provide improved braking performance, especially in the wet:
'Fibrax' made that type too as well as others that work better than most:
File Type: jpg
File Type: jpg
File Type: jpg
Continuity is offline
Old 04-09-13, 08:52 AM
Wanderer
aka Phil Jungels
Wanderer's Avatar
Bikes: 08 Specialized Crosstrail Sport, 05 Sirrus Comp
Quoted: 202 Post(s)
Liked 86 Times in 60 Posts
Kool Stop, Salmon.
Wanderer is offline
Old 04-09-13, 08:55 AM
HillRider
Quoted: 2026 Post(s)
Liked 1,096 Times in 742 Posts
Originally Posted by pavement_nyc
They will mostly be used for bikes with steel wheels,.....
+1 on the Kool Stop Salmons but don't expect much improvement from any brake pad. Steel rims give dreadful braking no matter what you clamp them with. They are poor in dry conditions and absolutely dangerous when wet.
HillRider is offline
Old 04-09-13, 05:47 PM
PHT
The XLC pads are fine for most uses, but the grey matter ones are much better. They are my standard pad for steel rims at the shop. I prefer them to KoolStops but only because of price. KoolStop salmons have earned their reputation, but the grey matters are ALMOST as good on steel rims at half the price.
PHT is offline
Old 04-09-13, 05:54 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Those Raleigh Leather faced shoes were specifically for the old steel rod brake rigs, rim ... Steel
braking surface, the inside face of the Rim.
Given braking is about friction, there are rubber+ abrasive blocks for other purposes
grinding through the chrome will be the result.
for better brakung a Drum Brake Was the solution, like SA Steelight hubs ..
fietsbob is offline
Old 04-09-13, 07:54 PM
HillRider
Not only drum brakes. Aluminum rims with any pad are far better than steel rims with the best pads available.
Old 04-09-13, 08:49 PM
FastJake
Constant tinkerer
FastJake's Avatar
Quoted: 185 Post(s)
Liked 92 Times in 75 Posts
Kool Stop salmons is about the most you can do for steel rims. Braking will still be virtually nothing when wet.
Aluminum rims and most any pad for acceptable braking.
FastJake is offline
RandomTroll
Bicycle Mechanics
10
05-05-16 08:11 AM
Redflea
Bicycle Mechanics
11
02-23-15 07:53 PM
MikeC624
Classic & Vintage
2
07-13-13 10:09 AM
damnable
Bicycle Mechanics
7
04-18-12 12:02 PM
