Hold Fast straps make my stance too wide?
Old 04-12-13, 07:28 AM
pavement_nyc
Quoted: 9 Post(s)
Liked 22 Times in 6 Posts
I love Hold Fast straps because my shoes range in bulkiness, and they are really easy to adjust. I also don't ride fixed so I can do it easily while riding as well. I've realized though that they make my feet too far apart, so I'm wondering if there is anything that would give a narrower stance, and also be east to adjust (with one hand preferably).
pavement_nyc is offline
Old 04-12-13, 07:38 AM
Scrodzilla
Your cog is slipping.
Scrodzilla's Avatar
Quoted: 640 Post(s)
Liked 100 Times in 58 Posts
It's the gigantic BMX pedals you're most likely using causing this, not the straps.
It won't be me, but someone will be along to tell you to go clipless very soon.
Scrodzilla is offline
Old 04-12-13, 07:56 AM
pavement_nyc
Quoted: 9 Post(s)
Ah that's probably true, but those are the only pedals that work with Hold Fast right? I have SPD pedals/shoes but usually I want to wear shoes that I can walk in too.
Old 04-12-13, 07:59 AM
Street rider
We win all charity rides
Street rider's Avatar
Bikes: BMX, fixed gear
I've used holdfast-type straps with more narrow platforms. Tough to pull them through the slots in the pedal, but they work just the same.
Street rider is offline
Old 04-12-13, 08:00 AM
SpeshulEd
SpeshulEd's Avatar
Quoted: 686 Post(s)
Liked 5 Times in 5 Posts
Going along with what Scrod said...the straps are most likely holding your foot in the middle of the pedal. If you feel it's too wide, I'd aim for a smaller pedal. Or slack the straps a bit so you can bring your foot in closer to the bike.
Hey guys, lets go play bikes! Strava
SpeshulEd is offline
Jaytron
Brown Bear, Sqrl Hunter
Jaytron's Avatar
Bikes: CAAD 10 4, Dolan DF4, Fuji Track Classic
Quoted: 8 Post(s)
Liked 26 Times in 15 Posts
Clipless will fix that.
EDIT: Now that I got that out.
Like the rest are saying, try getting narrower pedals.
Jaytron is offline
Old 04-12-13, 08:08 AM
Robofunc
Robofunc's Avatar
Bikes: Schwinn, Bottecchia, Miyata, projects
I use GR-9s and Soma clips & straps. I can ride my bike in almost any shoes and get off and walk around all normal. Life is awesome.
Also, look at your crankset / spindle length could be contributing to high "q factor."
Robofunc is offline
Old 04-12-13, 09:13 AM
David Broon
Sqrl
I alternate between SPD-SL's for real riding, and BMX Pedals+YNOT Straps for casual riding.
I ended up re-building the BMX Pedals with a shorter spindle to get the "Q-factor" Right. Also look at somthing like the Chrome Kursk?
Originally Posted by carleton
Doing one-legged squats while holding chickens in each hand will make someone strong...that doesn't mean it's the best way to train for track racing.
Originally Posted by Nagrom_
That would be spectacular. A trail of blood and sealant.
David Broon is offline
Old 04-12-13, 01:40 PM
McRussellPants
I put hold fasts on some quill pedals on my Kilo TT
Take the plastic toe clip, cut it so theres only about an inch of flat plastic, and flip it around to face towards the back of the pedal then bolt it over the front strap under the pedal, then run the back strap through the slots for the original single strap.
its kinda hard to get in with bigger shoes since the pedals are too narrow to keep the straps shape, but way more narrow than BMX,
McRussellPants is offline
Fullcount
Touring
87
04-21-14 03:39 AM
newbert
Fifty Plus (50+)
74
08-15-13 06:29 PM
EpicSchwinn
Singlespeed & Fixed Gear
11
08-05-11 09:23 AM
diff
27
11-06-10 02:36 PM
Chicago Al
Classic & Vintage
46
07-14-10 07:25 AM
