Using Ultegra 6600 cassette with SRAM Apex groupset
I've currently riding SRAM Apex with 50/34 @ 11-28. Overall it's nice, but I'm finding that the gear spacing is just not optimal for my level of fitness (averaging 17mph usually) and the terrain I ride in, which is predominantly flat. I'm finding that I tend to stay in the 50t ring, but switching around near the upper end. Notably on the 11-28 Apex cassette the upper end the jumps are 28-25-22-19-17, which I find to be quite large for the flats (especially 22 to 19), not to mention cross-chaining at times.
Playing around with gear inch calculators, it seems that something like a 14-25 cassette would allow me to have a lot smoother gear steps around my main cruising speeds. Yes, I realise this is considered a "junior" cassette, but it's what I feel would suit my level better than what I'm currently using. The question is compatibility of the Ultegra 6600 cassette with the SRAM Apex setup -- is it doable, or would it not work?
Location: England, currently dividing my time between university in Guildford and home just outside Reading
Bikes: Too many to list here!
As far as I'm aware, all SRAM and Shimano cassettes are compatible with one another in terms of sprocket spacing and the hub bodies that they'll fit, with the possible exception of 11-speed. I can confirm they are fully compatible as far up the ladder as 9-speed, because that's as high as I've gone mixing and matching, but I believe 10s will work too.
Bikes: Specialized Allez Sport
Quoted: 12 Post(s)
Yes they are compatible. But you need to check so see if the chainstay will clear the 14t cog as your smallest cog with the chain on. Ussually it's kinda tight there.
Quoted: 128 Post(s)
Liked 12 Times
Why not just get a 12-25 cassette? You'll still have somewhat closer spacing and will have a reasonable gear for big tailwind or downhills, and skip with the worry about cog potentially rubbing your chainstay.
"c" is not a unit that measures tire width
Thanks for the info guys. Good to know that the Ultegra cassette should be compatible.
I'm riding a 2012 Specialized Roubaix, but I'm not sure if the chainstays give enough room. Just eyeballing it they seem to provide ample space but I'm not sure how I'd check this without actually having the new cassette on hand..
I guess 12-25 could work, but I'd be missing the 18 and 20 cogs from the 14-25, and those are the gears that I'd probably want to be using a fair amount I think. I don't think I need the top end that much as I'm a through and through flatlander, I don't do climbs/descents, and sustaining 25mph+ on the flats even with a tailwind is probably outside my current realm of fitness.
mattkime
Road Cycling
13
02-10-16 01:42 PM
bobonker
Road Cycling
9
03-18-11 03:41 PM
