Tire Rub on front fork
Hi all.
Probably a silly question, but I just bought some sweet brown Kenda tires for my bike. They look rad, but at 1.95 width, they're rubbing on my front fork, just slightly. Like two millimeters slightly, on the side of the fork. I know I should just buy smaller tires, and that's probably the solution, sadly, but is there anything I could do to keep these bad boys?
Thanks in advance,
Keith.
Thanks in advance,
Keith.
Likes For Mr. 66:
Quoted: 1572 Post(s)
Liked 643 Times
Both sides? Unless it's rubbing both sides, all the way around, I'd be inclined to dabble with a precise wheel trueing too.
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times
Get the wheel trued...
..also I hope that is a proper extended length stem, cause if not, that's a disaster waiting to happen. Also confirms that the bike is a little too small for you.
=8-|
=8-|
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
Disclaimer:
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 457 Times
I'm not a fan of wheels rubbing. I had a front wheel on a fixed gear that rubbed the fork crown lightly one day. It went a little out of true vertically one day during a ride which caused it to rub.
After that 10 mile ride on a rail trail I stopped at my truck. 30 seconds later the tube exploded. I can only think it was the light rubbing on the fork that caused heat build up. It would have been bad if it had gone when I was riding.
Quoted: 1324 Post(s)
Liked 927 Times
How close to the chainstays is the rear tire? You do have the option of getting an MTB front fork. As another poster mentioned, you really don't want a tire rubbing against a part of the bike for any length of time as it'll quickly wear the tire or cause a lot of heat to build up on the tire and/or tube.
Also, please do check that stem to see if it's above the minimum insertion mark. If it is it could snap off if you hit a big bump, hit a pothole, or simple because it became fatigued.
Cheers
Cheers
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
Looking at the seat height, I'd suspect that the frame size is ok. But it would seem that the drive to have the handlebars set up in a cool way has led your stem to be too far extended. I'd take the handlebar off, drop the stem 3 inches, and reinstall the handlebar "upside down" to where it is now. Or, if that doesn't work, I'd get a different set of handlebars. The point is that the stem is WAY too high to be safe.
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times
Mr. Rabbit is an expert on wheels - so make sure that the wheel is trued.
I figured out my tire rub problem. One of the dropouts of my front fork is juuuuust slightly bent. Didn’t notice until I pretty much maxed out the tire size.
and the stem is a technomic 225mm height stem, all the way down the head tube. I chose it not at all for anything ‘cool’ but to get the handlebars up to my seat height, for I am old and not as bendy as I used to be.
thanks all.
thanks all.
Likes For eyemkeith:
