What do you see here?
Old 10-18-20, 05:24 PM
Drillium Dude
Drillium Dude's Avatar
Quoted: 2588 Post(s)
Liked 4,823 Times in 1,709 Posts
I think there's an issue with this derailleur. It seem more obvious when in hand, but would like to know what, if anything, you all see from the following photos:
This is an Ebay purchase. I'm considering returning it but want to make sure I'm not overreacting and seeing things. My lack of specifics is to avoid influencing anybody's opinion or eyesight
Thanks!
DD
Drillium Dude is offline
Old 10-18-20, 05:30 PM
seedsbelize
smelling the roses
seedsbelize's Avatar
Quoted: 7081 Post(s)
Liked 901 Times in 612 Posts
I never rarely see the offense in these threads. That holds true for this one as well.
seedsbelize is offline
Old 10-18-20, 05:36 PM
thinktubes
weapons-grade bolognium
thinktubes's Avatar
Quoted: 984 Post(s)
Liked 2,363 Times in 888 Posts
Cage looks twisted. On the plus side, it has red "speed pulleys".
thinktubes is offline
Likes For thinktubes:
Old 10-18-20, 05:42 PM
Drillium Dude
Funny you should note the "speed pulleys" as that's why I bought it. I will use the pulleys while a buddy, who has the correct ones, will use the rest of the derailleur. Assuming it's not messed up.
To which cage were you referring? Main body or pulley?
DD
Old 10-18-20, 05:45 PM
thinktubes
thinktubes's Avatar
Quoted: 984 Post(s)
Pulley.
Drillium Dude
That's still good feedback. In this case the issue is very subtle, which is the reason I'm soliciting feedback. I might be seeing things
DD
Old 10-18-20, 05:53 PM
krakhaus
krakhaus's Avatar
Quoted: 206 Post(s)
Liked 460 Times in 176 Posts
Looks straight to me.
krakhaus is offline
Old 10-18-20, 05:54 PM
P!N20
P!N20's Avatar
Quoted: 1077 Post(s)
Liked 1,890 Times in 927 Posts
Croce d'Aune - send it back.
Inner plate/cage looks mangled.
P!N20 is offline
Old 10-18-20, 05:57 PM
BFisher
Quoted: 767 Post(s)
Liked 1,898 Times in 889 Posts
Is that the correct screw securing the lower jockey wheel? Looks long.
BFisher is offline
Old 10-18-20, 06:11 PM
Mr. 66
Mr. 66's Avatar
Quoted: 1134 Post(s)
Liked 1,726 Times in 950 Posts
I'm not sure that is the correct inner pulley cage.
Mr. 66 is online now
Old 10-18-20, 06:57 PM
Murray Missile
Murray Missile's Avatar
Quoted: 626 Post(s)
Liked 1,244 Times in 595 Posts
Both cages look slightly bent to me and in a twist causing the two pulleys to be out of alignment to each other.
Murray Missile is offline
Likes For Murray Missile:
Old 10-18-20, 07:03 PM
unterhausen
Randomhead
Liked 3,684 Times in 2,508 Posts
same to me.
unterhausen is offline
Likes For unterhausen:
Old 10-18-20, 07:11 PM
ascherer
ascherer's Avatar
Quoted: 937 Post(s)
Liked 2,909 Times in 972 Posts
Originally Posted by unterhausen
same to me.
Me three.
ascherer is offline
Likes For ascherer:
Old 10-18-20, 07:28 PM
xiaoman1
xiaoman1's Avatar
Bikes: A few too many
Quoted: 1360 Post(s)
Liked 2,175 Times in 1,180 Posts
4!
Best, Ben
xiaoman1 is offline
Likes For xiaoman1:
Old 10-18-20, 07:34 PM
texaspandj
texaspandj's Avatar
Quoted: 1605 Post(s)
Liked 582 Times in 379 Posts
Looks slightly bent.
texaspandj is offline
Bigbus
Very Senior Member
Bikes: Giant Quasar & Fuji Roubaix
Quoted: 413 Post(s)
Liked 343 Times in 244 Posts
I'm old and hard of seeing, but I agree which makes me 5. Good luck. of course if you just wanted the speed wheels, your friends out of luck haha
Bigbus is offline
Old 10-18-20, 07:46 PM
Lascauxcaveman
Lascauxcaveman's Avatar
Quoted: 1627 Post(s)
Liked 630 Times in 356 Posts
Not just bent, but twisted, as @thinktubes said. Those pulleys look they are rotating on very different planes, which I think would be problematic. Not that those C'dA derailleurs shift all that great anyway.
Lascauxcaveman is offline
Old 10-18-20, 08:37 PM
merziac
merziac's Avatar
Quoted: 4501 Post(s)
Liked 6,367 Times in 3,663 Posts
The bottom pic looks way better to me than the first, even so the lower pulley bolt is either long or missing a lock nut and not true through the cages.
If a locknut is missing it might straighten that out some but cages seem not true either and I would assume many are not after the time and miles they get.
merziac is offline
Old 10-18-20, 08:49 PM
tricky
Quoted: 634 Post(s)
Liked 444 Times in 298 Posts
Cd’A Photo from Disraeli gears. The pulley cages look straight and pulleys aligned in this photo. Campagnolo Croce d'Aune (B010-SM) derailleur
tricky is offline
Old 10-18-20, 10:34 PM
repechage
Quoted: 3463 Post(s)
Liked 2,826 Times in 1,994 Posts
having just cleaned up a mech with Bullseye pulleys... good chance the spacing washers are MIA. That may have a lot to do with the situation.
the two pulleys May not be co planet at the moment.
repechage is offline
Old 10-18-20, 10:47 PM
P!N20
P!N20's Avatar
I see Campagnolo stubbornly refusing to adopt slant parallelogram derailleurs.
P!N20 is offline
Old 10-18-20, 11:09 PM
daka
Bikes: Raleigh Super Course, Raleigh International, Raleigh Gran Sport
Quoted: 250 Post(s)
Liked 314 Times in 197 Posts
In addition to the two (different sized) pulleys not rotating in the same plane, it looks to me that the cable clamping screw is both bent and has the internal hex stripped out.
daka is offline
Likes For daka:
Old 10-18-20, 11:35 PM
Drillium Dude
Thank you all for you observations and responses.
Yes, I was also thinking the jockey cage plates were bent. When I noticed that most here agreed, I decided to take the derailleur apart to confirm. Yup. Both bent; the rear plate was the worse of the two.
One washer was missing, but l had a spare. When I put that spare in to see what things looked like the bend was obvious. All fixed now, plus I learned how to dismantle/rebuild a CDA RD - which is good practical knowledge to pass along to my buddy when it comes time for him to put the correct set of jockey wheels in there.
DD
Old 10-19-20, 04:10 AM
Prowler
Quoted: 472 Post(s)
Liked 1,028 Times in 404 Posts
Many years ago I found a square of 1/4" plate safety glass. Stashed that away and it makes a good reference plate for things like this. I don't use it often but is handy when I need one. Even for rolling axles to see if and where they are bent.
Prowler is offline
Old 10-19-20, 05:41 AM
cudak888
www.theheadbadge.com
cudak888's Avatar
Quoted: 2412 Post(s)
Liked 4,373 Times in 2,086 Posts
Another vote for bent inner and outer pulley cages. Rear pulley will not run in plane with the front one.
There also appears to be visible witness marks on the inside of each cage, indicating greater-than-usual chain wear.
You can try to bend it out if you take both cages off, but the accuracy of straightening the outer one will almost certainly affect the inner. The inner is more likely to bend and twist to conform to the much stiffer outer plate.
-Kurt
cudak888 is offline
Likes For cudak888:
