Questions RE: brake cable adjusting barrels
I'm replacing the OEM (I think) cables and housings on my '85 Miyata Two Ten. I've read in several cable & housing related threads that ferrules should be used on the cut housings. The OEM aluminum barrel adjusters do not accept the ferrules. I have some steel barrel adjusters in my spare parts box. Other than the tiniest bit of weight difference, the hex vs knurled locking nut and rust resistance, is there any advantage to one over the other? I would like to use the ferrules at the "business" end of the housing as has been recommended and it aesthetically looks better. I will add that the housing receivers on the lever assembly DO NOT accept ferrules. Aesthetically, Es macht nichts as the hoods hide the housing end but is there a functional purpose to the ferrules?
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
The barrel adjusters might act as ferrules if the fit is nice and tight on the housing - I'm not sure.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
There are a variety of sizes of ferrules/housing end caps available. Sounds like you need some narrower ones. For example: Bikeman: Housing End Cap
Quoted: 1944 Post(s)
Liked 2,164 Times
I’m not so sure about that. I’ve run brake housing without a ferrule without any ill effects. If the housing is squared off and it sets into the brake barrel adjusters.
Where is the housing end going to go? It is in the adjuster. The cable is under tension.
John
John
Blamester
Always test the brakes by pulling hard on them after adjustment or cable replacement.
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 101 Post(s)
Liked 46 Times
I will always use a ferrule if possible but if there's no room I haven't found it to be a serious problem. Just use 1/2" or so more housing so that if you someday discover that it is deforming you can just trim a little and start over.
Lucky that I have a lot of time to waste as it seems like that's what I'm doing with this "issue" 😜. Thanks for the reply!
Interestingly, the cable replacement kit that I have came with the aluminum inserts that fit between the cable housing and the body of the brake lever assembly. These inserts are "stepped" so that they can receive either bare cable housing or housing with a ferrule. They don't have the groove with spring steel retainer like the OEM piece but since there is constant tension, I don't think that will be an issue. Since I can, I will use ferrules on both ends of the cable housing for both front and rear brakes. I always save any OEM parts that I remove in the event I make an error in judgement RE: component "swapping"!
Quoted: 4560 Post(s)
Liked 2,802 Times
Some of my brakes can hold a ferrule, some can't. I can't feel any difference in braking, none that can't be attributed to the brake design. If the cable housing fits the guide/barrel doodad on the caliper without much wiggle room, it'll be fine. The ferrule doesn't really do anything other than increase the diameter of the cable housing. (With some shift cable/housing ferrules there's a rubbery O-ring inside that helps exclude water/debris, so it's more useful.)
As others suggested, after using a cable/housing cutter to cut it to length, I use an ice pick or other tool to de-ovalize the housing end, then file off the end until it's square and clean, no burrs. I have a moto tool but generally use files for this stuff.
A cheap batch of brake cable housing I bought a couple of years ago (Sunlite, I think?) is kinda squishy, which is the main hindrance to solid braking. After the cable housing has been on awhile with lots of braking it settles in and works fine. Next time I'll spring for the cost of low compression housing.
Liked 2,164 Times
I’ve seen at stepped (different diameter) ferrule like that.
IIRC, the housing didn’t seat at the bottom of the ferrule, but stops at the step, at least it didn’t for me. I removed the outer plastic casing to get the spiral housing to seat at the bottom of the ferrule.
I don’t remember the exact situation, I doing this weird mod. I thought it was really odd, but the last thing I wanted was a gap in the ferrule.
John
John
Quoted: 1088 Post(s)
Liked 1,024 Times
Some of the old housing was not as thick as modern stuff, I've actually had to partially shave a bit of the plastic coating off to get the housing to fit on some frames since the old housing was just a tighter wound metal spiral with a thin layer of clear or white plastic over it and more like 4mm in diameter. With the exception of SIS der and compressionless brake housing there isn't an actual need for ferrules but you should always use one if it helps the housing to stay seated better and tighter.
Bikes: Wife says I have too many :-)
Quoted: 327 Post(s)
Liked 250 Times
I see your point! I've used a Dremel tool with a cutoff wheel to cut the housing so the cut is pretty square. The housing fits snuggly into the aluminum barrel adjusters but would require a ferrule to have the same fit in the steel barrel adjusters. I would think that there would be a bit less friction (steel on steel) with the steel barrel adjusters but since the actual need adjustment is infrequent, it prolly doesn't make a difference.
I started using my Dremmel with a cutoff wheel for cutting brake and shifter housings also. Makes a nice square clean cut and the ferrules usually slide on nicely.
Thanks for all of the suggestions. I ended up using the OEM cable housing receivers at the lever end of the housing and the steel adjustable barrels (able to accept ferrules) at the cantilever end of the housing. A tiny bit of the ferrule protruded above the brake hoods and I didn't like the "look". I'm sure that the function was not a factor. I do like the "snap ring" that holds the housing receiver in the body of the lever body. Prolly would never happen but that piece could pop out of position during wheel removal when the straddle cable is unhokked and cable tension is released. Just sayin' that it could. I think that using the ferrules at the catilever ends of the cable housings look appropriate and prolly reduces resistance to turning the adjuster barrel as well as potential for disrupting the cut end of the housing. I'm guessing not too much risk of that under most situations but no matter, it's a done deal!
