Certain Areas That Won't Change
Quoted: 1943 Post(s)
Liked 2,164 Times
Admittedly, I ride older bikes. But I don't have an issue with newer designs and would not have an issue going to a modern carbon frame if I felt the need to upgrade.
But there are a few areas where my retrogrouch rears its head. One main area is gearing.
I have never been able to get beyond 7 and 8 speed systems; although I might consider a 9 speed one day. For years I've ridden a 12/14, 13/15, or 14/16 first and second position cogs. Adding another cog has always been to add range on the low end; 6 speed 24t went to 7 speed 28t. My mountain bikes went from 7 speed 13-34 to 8 speed 13-40.
About 5 years ago I picked up a road bike for my wife that had 10 speed 105 with a triple. The first thing I did, before she even took one pedal stroke, was to strip off the 10 speed components and install 8 speed 12-34 cassette with a mtb rear derailleur and Claris shifters. It takes her everywhere she needs to go.
I'm sure there are others that have one area or another where the line is drawn.
John
John
Quoted: 3015 Post(s)
Liked 3,793 Times
Nope. No line whatsoever. It's all good man.
Likes For iab:
Quoted: 634 Post(s)
Liked 444 Times
John
John
Likes For tricky:
Quoted: 378 Post(s)
Liked 1,409 Times
I go with things that work. Or are supposed to before I get ahold of them.
As such, I'm hoarding a pair of compact triples. I plan to outclimb the Zombies.
Matching is secondary, BUT...
... sometimes, a man has to accessorize properly, or risk a faux pa.
Quoted: 3808 Post(s)
Liked 6,681 Times
At one point, I felt like 5-6 speed friction was all I wanted and all I needed (and this was long after the introduction of indexed systems). Then, I acquired a bike with 7-speed indexed bar-ends. Oooh. I liked that a lot. Then I started experimenting with 8-speed Shimergo systems (10-speed Campy brifters and 8-speed Shimano drivetrains mate perfectly) and 9-speed Shimergo systems (ditto for 11 Campy/9 Shimano). Then, I sprung for a modern 10-speed Shimano 105 group for a particular group (though I have found it runs better in 9-speed mode). Now I have one 1x11 bike (SRAM drivetrain and shfiters) and one 2x11 bike (Campy Potenza drivetrain and shifters).
I have a single-speed for when I want to keep things simple.
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4678 Post(s)
Liked 5,795 Times
I stopped at 8 when I realized 9 speed chains were pricey. Neal's modernization trend has got me thinking, though.
Likes For gugie:
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
Also, yes, 5703 was the peak of Shimano's triple products.
My Bikes
My Bikes
small ring
Quoted: 437 Post(s)
Liked 925 Times
If it gets you on a bike and puts a smile on your face, do it.
It's also totally fine to have both old and new. I don't have the same system on any of my bikes.
59 Allegro Special -- 72 Bob Jackson -- 74 Motobecane Grand Jubile -- 74 Sekine SHS 271 -- 80 Nishiki International
Bikes: Yes
Liked 3,868 Times
My Bikes
My Bikes
Likes For Andy_K:
Passista
Quoted: 866 Post(s)
Liked 721 Times
I like 7 and 8 sp because of the no-problems and cheap chain. Would have no issues with a road 9 or 10 sp, I think. But I wouldn't go 11, 12 or 13. Don't know why, maybe just because I'm a retrogrouch, but somehow I don't trust them.
Quoted: 378 Post(s)
Liked 1,409 Times
My fondness for 11-sp is about the range, not quite the function.
Today, at this hour, minute, and second, I like DA 9sp or DA/Campy 10sp DT shifters and whatever I feel like matching to them. The sheet works.
Like Neal, I have 1x11 SRAM and that is some slick stuff. Never tried Potenza, but pot and pizza always did go together.
Having just picked up some Super Record 11, I will rail about the price, (double that of NOS Centaur 11), but someone said it would be orgasmic.
I'll find out. I just wish they'd find a way to make this stuff shiny and silver.
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
I agree. My favorite quote when Di2 first came out was from BikeSnobNYC, "Electronic shifting will completely change the way you think about bicycles--assuming, of course, that you previously thought of them as being relatively inexpensive and easily serviceable." I think he's since warmed up to it, but I definitely haven't. I don't care if it's better. It's just not right. (Especially on a Paramount!! I'm looking at you, @RiddleOfSteel )
If not a Paramount, then an Expedition. Why? Precedent. Wire-in-frame + holes-drilled-in-frame (both from the factory) precedent. Sure, it was for a generator, but still, it counts! External Di2 is super easy to service, but a bit fussy to organize extra wire length (around the base of the seat tube) neatly. Internal battery and routing can be annoying, but you hide the rats nest of extra wire length, it looks clean, and really the only servicing you need to do is battery removal (wedged inside the seatpost per design) for charging. Small price to pay for dynamite shifting and the hottest looking STI levers ever made, IMO.
There was one generation of XTR Di2 that had its front derailleur 3x capable. XTR Di2 is heinously expensive, but hey, it's a triple, and you can run normal road STIs to do the shifting (talk about compatibility!). It's what I would do, and yes, I have thought about it!
As for areas that won't change, I tend to not have any (and am given to heretical bicycle acts, as Andy has pointed out!). Carbon and disc are the two areas that I've had experience in before, and don't mind, but have some reservations on their ability to mesh with what I want my bike to feel like and how easy I'd like to operate/maintain it. Carbon dampens road buzz really well, but it doesn't have (due to its innate qualities) the springiness of steel, titanium, or good aluminum. I do still have much affinity for it, and would love to try a Cervelo R5 or Madone from ~5-10 years ago. And as for disc, it's the fork stiffness and feeling when braking that has put me off before. Well, that and pad contamination (I do like a quiet bike in all conditions). For the right bike, and with a test ride (new road disc forks are a lot better than they were 5 years ago), I'd be up for it again. I love my side pull calipers, though.
Quoted: 4510 Post(s)
Liked 6,377 Times
John
John
And I get it, some things like pedals, clips and straps are non-negotiable, period, drop bars too although that is very likely to be forced on me sooner or later.
Quoted: 634 Post(s)
Liked 444 Times
Likes For tricky:
Quoted: 7348 Post(s)
Liked 2,463 Times
I like most of the new gearing systems, mostly. They are finicky and less durable, but they're nice to ride. Truly 8 speeds are enough in most cases. I upgraded our tandem from 3x7 to 3x11. That was a surprise in that the shifting is better than with any derailleur of any type I've ever used.
One thing I'm not eager to try any time soon is tubeless tires with liquid sealant. I've seen a tire inflated, and I've read plenty about them. I understand the advantages, but I would have to get messy when I really don't want to. I know that the intervals between servicing might increase but when they come, damn, what a mess. Maybe the technology will improve, so I will keep an open mind. But I had enough experience with tubular tires to know how to handle them well, and while they are different from tubeless clinchers, there are some jobs I'm not eager to do.
I haven't owned a carbon fiber bike, but I'm not opposed to the idea. One of my bikes has a carbon fiber fork.
Liked 2,024 Times
You are particular about bike feel, but you are also an addict of sportiness. You are a fan of classic American V8s but I bet there is the bike equivalent of a C8 out there with carbon and discs that would do it for you or at least serve a purpose in your stable as an all out speed machine.
Quoted: 634 Post(s)
Liked 444 Times
So basically, you're telling me to go ahead and have a custom 67cm carbon Land Shark touring bike (45cm stays plus all the braze-ons) or titanium touring bike of similar dimensions built? Have speediness and all-around capability? Sign me up! Or at least let me get a 66.5cm Expedition (or Sequoia) to build.
Likes For tricky:
Likes For BFisher:
Disciple of St. Tullio
Bikes: Ciöcc, Bianchi, DeRosa, Eddy Merckx, Frejus, Hampsten, Kondor, Losa, Magni, Pegoretti, Pelizzoli, Pogliaghi, Scapin
Quoted: 267 Post(s)
Liked 334 Times
I have two hard limits; no electronic shifting and no carbon fiber. I once purchased a bike that had Chorus 11 on it and replaced the Chorus with Athena 11 since it was alloy.
Oh wait....three. I won't purchase a frame that doesn't have DT shifter mounts.
Bikes: 3Rensho-Aerodynamics, Bernard Hinault Look - 1986 tour winner, Guerciotti, Various Klein's & Panasonic's
Quoted: 159 Post(s)
Liked 375 Times
Maybe I should never say never but I cannot see disc brakes ever being in my possession.
Having ridden 9 speed for many many years my spirit is going backwards to The good ole days of 7 and 6. That is where the fun is.
Liked 6,681 Times
I can add that 7-speed index shifting, whether bar-end, down tube, or Gevenalle, is awesome. Particularly if you have a frame you don’t want to respace to 130mm.
Liked 6,681 Times
Likes For nlerner:
Quoted: 4559 Post(s)
Liked 2,802 Times
The older I get the more I appreciate extra cogs between the same 11-13T small and 28-32T big cogs. Smaller increments between shifts, less tiring, easier to stay in the sweet spot. Even my 8 speed 12-32 cassette has one awkward jump in the middle of the cog range that feels a bit abrupt.
This summer the local REI was blowing out some parts, especially Shimano, so I paid something like $8 each for a couple of 9-speed chains (I don't have anything 9-speed atm, but things can change), and three BB-UN55's in various sizes for around $8 each. Not sure why they were deeply discounting bike parts during a pandemic induced shortage, but I was happy to buy 'em.
I have some 10-speed components for another build. The DA cassette is 11-25, which wouldn't be my first choice, but it came off a TT/tri-bike with cracked frame cannibalized for the components. I'll use it for one particular build just for chasing PRs and KOMs (yeah, that'll never happen) on good days when the legs are strong. But for most rides I'd prefer a 28T or larger cog for loafing up climbs.
Likes For canklecat:
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
threadless stem converter
I would never use a threadless stem converter on a 1" threaded front end. Partially because I really don't like the look and partially because they're kind of the worst of both systems. I'm the type of guy to have 70mm or so of threadless spacers or a Technomic. A threadless convervter would either be unsafely flexy to achieve that or much heavier. I will admit to trying the Origin8 31.8 quil stem because modern bars are sooo much more comfortable to me.
