What tubes are better for 700x25 road tires, 18-25 or 25-32?
Hi, everyone!
Could someone please point me in the right direction? My tires are 700x25, but I don't know which of the above tubes would be best. The current ones are 18-25.
Thanks in advance for any help you can provide!
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,245 Times
I tried larger tubes thinking they may be better.
Go with the 18-25's
Go with the 18-25's
Fred "The Real Fred"
Likes For 10 Wheels:
Quoted: 6193 Post(s)
Liked 4,809 Times
The inside of your 25 mm tire may not be the same volume as the inside of my 25 mm tire. I'd buy both. Likewise the mfr of the tubes may vary somewhat from others.
Try the bigger inner tube just to see, and if you think it might be kinking or wrinkling, then use the smaller.
The less your inner tube has to stretch inside the tire, the less it'll act like a balloon being punctured by a pin.
Bikes: 2016 Trek Emonda S6 frameset, custom build (road). 1995 Dawes Genesis Reynolds 531 Competition frameset, custom build (road). 1996 Orange C16R frameset, custom build (retro MTB). Coyote Dual hard-tail, custom build (MTB).
Quoted: 61 Post(s)
Liked 76 Times
18-25 for 25C. No flappy extra rubber needed...no extra weight slowing that wheel down
Likes For Bob the Mech:
Quoted: 2482 Post(s)
Liked 2,955 Times
The difference between the two in inflated wall thickness in a 25-mm tire is completely insignificant. A larger tube stuffed into a smaller tire can end up with localized folded sections; that would be far more likely to result in tube failure. I've had that happen.
Likes For Trakhak:
The smaller tube is much less likely to get trapped under the bead.
Likes For popeye:
Thank you all very much for taking the time to respond. I'm so glad I asked. I'm looking forward to benefiting from your experience.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
I say it depends on the pressure your run. I run 105F/112R due to my weight and so not to get pinch flats. I see the smaller size with small holes and nothing in the tire with age occasionally. The larger size does not. I always forget and go for the smaller lighter tube.
When in doubt, go smaller. A tube can expand way more than the stated width without any issues, and a narrower one is just easier to mount. I think most of my tubes are 18-23, used in 25 mm tyres.
