tire direction
tire direction
Trying to determine the proper tire direction. There is no direction arrow on side wall. The pic is shot from the top, with derailleur on the right side.
Quoted: 427 Post(s)
Liked 705 Times
I don't see a pic. But what I've found, generally, is if there is a printed logo on the sidewall, it goes on the right (gears) side.
Quoted: 5839 Post(s)
Liked 2,673 Times
Your photo didn't link, and if I remember the rules, will not until you have 10 posts.
However, here's some help.
Most bike tires are not directional in any way. For those that are, the right direction depends on the intent. On a rear mtn bike tire the intent is to get the most push off in soft sand or mud, so mount the tire so the "harder" side of treads are to the rear on the bottom (forward on top). Reverse this in front so you get the maximum bite when braking.
For road bikes tread is mainly cosmetic, though it has some effect when the road is dusted with wind blown sand. Typical road treads often have herringbone type treads, modeled like those on car tires. The logic is that the point hits first and wedges water outward as the tire rolls. This doesn't matter on bikes, since water isn't an issue, but for cosmetic purposes mount so the herringbone points forward on top.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Likes For TC1:
Quoted: 982 Post(s)
Liked 587 Times
Likes For sweeks:
Liked 2,673 Times
There is plenty of documentation for why road bike tires don't need tread, and we've done fine without for a century or so.
However, we don't need to argue that here. Instead, feel free to challenge the specific advice I offered the OP.
Or better yet, offer your own opinions in answer to the OP's question.
FB
Chain-L site
FB
Chain-L site
Bicycle tires are essentially different from car tires in an important way. See what Sheldon Brown had to say about this.
Bicycle tires are subject to the same physical laws as automobile tires, and there is nothing about them which changes the fact that water is incompressible and once the vehicle reaches a speed that exceeds the tire's pumping threshold, the tire will hydroplane.
The only difference is that bicycles generally lack the horsepower to achieve that speed, unless gravity-aided.
Really Old Senior Member
Quoted: 6251 Post(s)
Liked 4,851 Times
Is this the pic you intended to link?
https://www.bikeforums.net/g/album/29735669
10 post and maybe a day later you should be able to to post pics and links. Till then just let us know you put a pic in the Gallery here on BF and someone can find it and post it for you.
I wouldn't sweat the tread direction if they don't have an arrow on them. Even if they do, it's not a really big deal. I think you are good with the current direction for mud and dirt when off road.
Quoted: 1619 Post(s)
Liked 2,633 Times
I would mount that tire as shown rotating down. If it was smooth or had a symmetrical pattern then it wouldn't matter.
Liked 2,673 Times
In any case, it's interesting that while you're the most invested in arguing the importance of tread, you're the only one here who hasn't offered the OP any help.
Word of advice, which I'm sure you'll ignore.
Your new here and don't know the players. Some are extremely knowledgeable on bikes, some are engineers, physicists, chemists, or other professionals well credentialed to discuss technical subjects.
You would be well advised to listen more and argue less until you know who's who, and what they know
FB
Chain-L site
FB
Chain-L site
It becomes material as soon as one crests a hill. If you never do that, it remains theoretical.
I corrected the erroneous advice that OP received, specifically that bicycles cannot hydroplane.
I may be new here, but I am not new to bicycles or physics, and I am extremely knowledgeable on both topics. Perhaps you were under the impression that everyone who knows anything about those topics participates here, but I assure you, such is not the case. If you can only argue against my point by attacking me and the age of my account, well, I think we both know what that means. Instead of resorting to ad hominems, why don't you explain how bicycles violate all known laws of physics, and/or why I can provide video evidence supporting my position?
Again, if you can only judge a position by the author's name, you probably don't understand the topic sufficiently.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4340 Post(s)
Liked 2,987 Times
More to the OP's point, no tread in any direction would've prevented any of those crashes.
Well they don't of course. Auto tires are wide and have a flattish profile and they can hydroplane because the water can't out of the way fast enough. Bicycle tires could hydroplane if we're talking really wide ones like 4" with a flattish profile, but your basic road bike tire is too narrow and too round for that to happen; in fluid mechanics terms, the two are not have dynamic similarity so using one to model the other if invalid. The videos you posted show slippery roads and high resistance from riding through deep puddles, not hydroplaning.
You are apparently a few decades out of date with your understanding of the interface between rubber tires and road surfaces. It was once thought that rubber somehow "gripped" pavement, and provided the traction we all rely on. The advent of superior inspection tools, like electron microscopes and others, has improved our knowledge in this field, and we now understand that rubber tires provide traction by deforming into microscopic imperfections in the surface. And that gravity provides the force required to cause that deformation. This is why dynamic weight distribution, and the control thereof, is so critical to performance on both two and four wheels.
So, what you call a "slippery road" is, in reality, we now realize, just the hydroplaning effect of a potentially microscopic layer of water preventing the rubber from deforming into those imperfections.
This is obvious, in hindsight, because there is no other mechanism by which gravity could be disabled, in order to allow a tire's rubber to stop interlocking with the road surface.
The same effect occurs without water, when a tire is pushed beyond its limit, and it begins to melt. A thin layer of liquid rubber results, and behaves just as water does -- suspending the tire off the surface, and preventing tractive force from developing. This is how you leave skid marks on your fixie, or do a burn out in your Challenger.
I recommend that you (general) stop spreading obsolete and inaccurate information on this forum.
Last edited by TC1; 06-17-23 at 09:10 PM. Reason: clarification on whom I was speaking to in the final sentence
Likes For TC1:
Expired Member
Quoted: 3705 Post(s)
Liked 5,541 Times
Oil residue, silt, leaves, painted lines.
Likes For shelbyfv:
SE Wis
Quoted: 2751 Post(s)
Liked 3,407 Times
"Slippery roads" are hydroplaning. Otherwise, you need to provide some alternative explanation for why gravity ceases to function, and allows a tire to lose contact with the surface.
I recommend that you stop spreading obsolete and inaccurate information on this forum.
Likes For dedhed:
All of which interfere with the previously-described tractive mechanism. Oil, in particular, is evidence of hydroplaning -- if that phenomenon were impossible, tires wouldn't slide on oil, either, they would simply pump it out of the way.
Whichever way the manufacturer intended, if any.
That's a very different question from misleading OP into believing that hydroplaning is impossible on a bicycle. The latter is dangerous and inaccurate "advice", and I would've thought this august forum would be opposed to the spread of such, which is why I corrected it.
If, OTOH, spreading dangerous advice is what the cool kids do here, please just let me know that is the MO.
Expired Member
Liked 5,541 Times
Video evidence of precisely the phenomenon in question occurring, and being decidedly not impossible, is also not an opinion.
Expired Member
Liked 5,541 Times
You keep mentioning physics and such. Your opinion might be better received if you posted your qualifications. People tend to respect informed opinions.
Likes For shelbyfv:
If you like, you can remain ignorant of physics. That is your choice. Or, you can watch this video of a cycle traveling across a lake at ~30mph.
Also, for the record and as I already explained, if you can only judge an argument based on who is making it, then you simply are not sufficiently informed on the topic at hand. In fact, that is a popular logical fallacy called "argument by authority". Authorities can be, and often are, wrong -- as recently shown quite famously by the realization that the conventional wisdom regarding the efficiency of skinny, high-pressure tires was dead wrong, despite being believed by almost everyone for decades.
Quoted: 1099 Post(s)
Liked 1,038 Times
OP, the tires in the pic have a center tread that has lines coming in and pointing towards the way forward.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,571 Times
Good luck catching flies with vinegar, @TC1.
If you believe that hydroplaning a bicycle tire is impossible, explain what is causing many of the tires in those previously-posted videos to wander laterally underneath riders who are travelling in a straight line. None of this magical "grip" that you believe in is even necessary for a tire to roll straight, and yet, these riders -- who are all quite talented -- cannot keep their tires rolling straight.
Why, exactly? And be precise.
