Do Want, Way Crazy Tool
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 4,001 Times
Is this the truing+ stand to beat all the others? I present the Radonaut from Cyclus:
(it is in German)
Yeah it is over $6k and completely crazy and kinda ugly compared to P&K Lie or Aivee but whoooooooooooieeeeeeeeee it has a computer machine and shows you all the infos.
Likes For veganbikes:
Quoted: 2338 Post(s)
Liked 2,827 Times
put me on your gift list
Likes For squirtdad:
Quoted: 18378 Post(s)
Liked 4,512 Times
Interesting machine.
I wonder how it compares to a basic analog stand like my VAR truing stand?
Plus the mod to help with hop sensitivity.
I obviously don't get all the gadgets of the machine above, nor the digital printouts, but can get pretty good. All I need is a bit more practice.
Now, mine is more qualitative than quantitative, but one can add dial gauges.
The wheel in the video appeared to be pretty close to true, and just adjusting a couple of individual spokes.
Likes For CliffordK:
Quoted: 194 Post(s)
Liked 204 Times
Who needs reams of data when they could have something as fun as this! OK, if you were doing a ton of wheels then the computer version would be handy, but I repair things for the pleasure of handling objects, for the same reason I ride instead using some bicycle racing game.
Quoted: 569 Post(s)
Liked 588 Times
No, but I would love to replace my Roger Musson's design shop built with a vintage VAR like CliffordK's after getting to play with one in a Portland shop.
Likes For easyupbug:
Friendship is Magic
Bikes: old ones
Quoted: 26425 Post(s)
Liked 10,381 Times
...thanks. I find it very entertaining that the guy in the demo video for a $6,000 wheel stand is using the same spoke wrench as me.
Quoted: 1572 Post(s)
Liked 643 Times
In the end, all that a wheel truing stand does is to provide a stable place to measure from.
Liked 4,512 Times
Ideally that electronic truing stand would be 100% self centering. Measure the OLD distance, measure the width of the rim, and center accordingly. Perhaps even allow one to program in a slight offset for dished wheels if one wishes.
In a home shop, it may not matter if it takes a while to true a wheel.
But, I could imagine the benefits for someone that does a lot, like in a wheel shop or small manufacturer. If one could double an employee's production doing full time wheel building, it might pay for itself in a matter of months.
That machine does appear as if it can probably deal with different rim sizes, perhaps with a different table. However, I don't see any provisions for laterally truing mounted wheels (which was one of Park's arguments for their newer larger truing stands). Not that different rollers couldn't be used with tires.
Quoted: 626 Post(s)
Liked 400 Times
I have The TS-2.2 professional truing stand. I use dial indicators because it is much easier to see what you are doing. I can bring my disk brake rotors to within .2 mm TIR. I have my current set of wheels to within .005" TIR both side to side and hub centered in the wheel. I purchased my tools for far less money and after watching part of the video I don't see that the truing stand they are demoing is any faster.
Liked 2,827 Times
Quoted: 1944 Post(s)
Liked 2,164 Times
The biggest question…
…does the machine print out SOL when it finds a hop that the user can’t fix.
John
John
Likes For 70sSanO:
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,205 Times
Why but that one...
Make one with an Arduino, 4 bulldog clips and a skateboard!
Barry
Barry
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 942 Times
Mine was $20, plus some already in shop spray paint.
Clark W. Griswold
Liked 4,001 Times
If only I had that kind of money.
I would have a dream shop with a live-in master tech full of only the best tools (including at least one of those) and small velodrome in the basement with a full fleet of Don Walker track frames for any friends or family to use. I would have MTB trails in the backyard as well and probably some S-Works Stumpjumpers and some Santa Cruz/Juliana carbon dream bikes for everyone as well (or something else nice).
Really Old Senior Member
Why do people assume RIMS are that perfect?
I've seen 1mm variation from "bead" to bead" on cheap, NEW rims. Often with most the variation off to one side or the other.
You can often get an idea by simply taking an adjustable wrench to use as a go/no go gauge.
Adjust the jaws and slide around the rim.
You'll find high & low spots. Often enough to make dial indicators a waste of time.
Likes For Bill Kapaun:
Somewhat of a niche market for a tool like that. Cool as heck though!
I believe it's the mechanic not the tools.
A good mechanic with good tools does good work.
A good mechanic with average tools still does good work.
A lousy mechanic with good tools still does lousy work.
Quoted: 194 Post(s)
Liked 204 Times
Likes For Geepig:
Liked 4,512 Times
I think with my VAR truing stand setup as above, I was getting variation with the radial runout from a spoke hole to the point between spokes to the next spoke hole, so it was impossible to get it "perfect". My machine would only run the lateral gauge on the right side without flipping the wheel, so I wouldn't really notice if the rim got fatter somewhere.
Palmer
Quoted: 1671 Post(s)
Liked 1,826 Times
Nice, but no Holland Mechanics.
Likes For tcs:
Quoted: 626 Post(s)
Liked 400 Times
Likes For Rick:
This one is purtty! A Perfect Truing Stand - Wheel Fanatyk
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times
The Park TS-3 with a few dial indicators mounted has a soft spot in my heart, but they still don't perfectly center. That VAR is pretty cool. Finish aside, I've yet to use a VAR tool I didn't like.
Clark W. Griswold
Liked 4,001 Times
Quoted: 8 Post(s)
True, but there are some advantages as one goes up in value of the stand from speed to accuracy.
i have this machine at my bike shop. I truing the wheel perfect but it's a little offset when i put the wheel on the bike. Is there any settings? You write: Perhaps even allow one to program in a slight offset for dished wheels if one wishes. But i don't have that program or button or setting, center offset ( mittenversatz) like in the video. Where can i find it, that setting ? I can't attach a photo, cuz i'm new here. Sorry for my english. Have a great day.
Liked 4,512 Times
hey, can you help me with some problems ?
My post was theoretical. Ideally an electronic truing stand could determine exact centering of a wheel. Although, there have been questions whether tire inflation on a dished wheel can impact dishing, so that may also need to be accounted for.
My current truing stand pictured above is 50 years old without any electronic gizmos. Old, but SOLID. In theory, if one is building a dozen identical wheels, one can set it up once, and repeat.
As far as "the wheel perfect but it's a little offset when i put the wheel on the bike."
There are a few possible issues:
- Wheel is not properly dished. A dishing tool will help you verify.
- The wheel is, in fact perfect, but the bike is not. Brakes off center, frame bent, bad dropouts, etc.
There is a dishing tool which you should use if you are building several wheels.
It quickly tells you if the rim is properly centered.
If you don't have the dishing tool, an easy check is to flip the wheel backwards in the bike. If the problem follows the wheel, it is a wheel problem. On the other hand, if the problem remains in the same spot, it is a bike problem. This check can generally be done with either the front or rear.
Once you isolate the problem, you can take steps to fix it.
If the problem is the truing stand not self-centering, more details are needed about what stand you are using. If it is an electronic system, talk to the manufacturer.
If this is a theoretical problem as my theoretical post above, then I can give more comments. But, I believe that a highly automated stand should be able to determine how to properly center the wheel using the axle width (OLD, over locknut dimension), as well as the rim width. And, possibly a fudge factor for the tire inflation.
