I picked up a free Motobecane at a garage sale.......
and am wondering if I can replace the old cotter crank and BB with a modern 68mm square taper. Will the threads match up? The frame indicates the bike was made in France so that makes me think it may have some strange/rare size. This will be my first attempt at working with such an old bike and going in blind, so I appreciate the help.
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
Yes you can...if you find the correct size bottom bracket cups. I did it way back in 1978. You most likely will have either a Swiss or French threaded BB. FWIW I used Campy cups in mine, because that was what was available at the time.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
Bikes: '02 Litespeed, '99 Bianchi Alfana. '91 Fuji Saratoga, '84 Peugeot Canyon Express, '82 Moto GR, '81 Fuji America, '81 Fuji Royale; '78 Bridgestone Diamond Touring, '76 Fuji America, plus many more!
Quoted: 181 Post(s)
Liked 224 Times
JensonUSA seems to have a good supply of BB cartridges when you're ready to order...
https://www.jensonusa.com/store/sub/1...+Brackets.aspx
Quoted: 17 Post(s)
Liked 43 Times
Unless there is a problem with the crank, changing to cotterless will degrade the looks and durability of the crank in exchange for a minor weight reduction and some grief/expense in finding a suitable spindle &/cups.
(PS- Pics or it didn't happen!)
- Auchen
- Auchen
If you decide to upgrade, you may be able find a spindle the right length and just replace that. If you have to buy a bottom bracket and crankset, the cost isn't worth it.
Novist senior member
I have done this a few times and I always used the cups that came with the bike, never had any problem.
is just a real cool dude
Quoted: 32 Post(s)
Liked 34 Times
I don't know what's the hassle with cottered cranks? Loosen up the bolt but leave it on enough to cover up the threads(if you want to save them or sell them) and a few taps with a hammer or mallet. No need to deliver death blows just a few love taps and they always come right out.
Mike
Bikes: 1994 Specialized Rockhopper FS, 2002 DK Fury24
After this discussion now I'm thinking maybe just clean it up as best I can and leave it as original as possible. New chain, cables/housing, brake pads, tires/tubes. The frame has some rust on the stays and rear wheel will need to be replaced, but I just happen to have one that will work. I'll have to check ebay and see if these are worth the fixing.....the frame is too large for me.
Quoted: 70 Post(s)
Liked 15 Times
I have had to drill a couple out over the years, and that was after trying a cotter press and a large hammer. Not all cotters are going to gently tap out.
Aaron
KenNC
Classic & Vintage
17
05-18-14 08:43 AM
TNDave
Classic & Vintage
16
04-26-12 01:28 PM
