Cracked hub flange
Cracked hub flange
Old 05-28-13, 11:19 AM
kayakboy
Bikes: Raleigh M60, Raleigh Supercourse (road), customs....
Cracked hub flange
Just found a crack originating in the spoke hole on a shimano 600 hub. There is one almost as big on the other flange as well. This on my do it all road bike. Is this a common failure? Was it commuting over pot holes, rough terrain over the mountains, dirt tracks in the park? Its tensioned to 70 kg/f. Ridden with 28mm rolly polly tires. Any suggestions to keep from blowing up my wheel in the future (after I replace the hub).
P1040586 by vagmcgina, on Flickr
P1040589 by vagmcgina, on Flickr
kayakboy is offline
Old 05-28-13, 11:36 AM
tarwheel
tarwheel's Avatar
Bikes: Waterford RST-22, Bob Jackson World Tour, Ritchey Breakaway Cross, Soma Saga, De Bernardi SL, Specialized Sequoia
Quoted: 196 Post(s)
Liked 6 Times in 4 Posts
Yikes! I would quit using that wheel right away. I had the same thing happen with a Campy Chorus hub, but it was replaced under warranty because it was less than 3 years old. Not a common occurrence but it happens.
tarwheel is offline
Old 05-28-13, 04:22 PM
old's'cool
curmudgineer
old's'cool's Avatar
Bikes: 2 many 2 fit here
Quoted: 263 Post(s)
Liked 112 Times in 70 Posts
Mostly likely causes of cracking as shown/described, not necessarily in order:
  • normal end of life for a high mileage aluminum hub
  • result of incorrect/uneven spoke tension in normal use, due either to initial assembly, or failure to monitor & maintain proper spoke tension in use
  • manufacturing defect or defective/out-of-spec material
  • prolonged, extremely harsh riding conditions beyond design intent of hub (would generally result in collateral failures of spokes, bearings, rims)
Other causes are possible, such as corrosive attack or loss of heat treatment due to overheating, but not very likely.
old's'cool is offline
Old 05-29-13, 01:02 PM
rhm
multimodal commuter
rhm's Avatar
Quoted: 1908 Post(s)
Liked 574 Times in 339 Posts
I've never seen that before. I've seen large hub flanges break when laced with radial spokes, but this is completely different. I would assume this was a defective hub.
rhm is offline
Old 05-29-13, 01:24 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Its Use Life has Ended.. nothing but radioactive wastes lasts for ever..
If the hub shell was steel it wouldn't do that , but nobody wants to build those .
as the hub flange is as hard as the spoke , and Rust is inevitable.
Manufacturing Defect, its not covered after a Year, and those [600] are 20+ years old ..
Buy a new wheel and get on with your Life./.
fietsbob is offline
Old 05-29-13, 01:31 PM
Andy_K
Andy_K's Avatar
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times in 1,439 Posts
Cheap Shimano hubs...have to replace them every 20 years. What's the world coming to?
My Bikes
Andy_K is offline
Likes For Andy_K:
Old 07-22-23, 06:54 PM
Jeremy967tree4
Profile hub flange cracks
Under normal cruising street conditions on a 29" BMX (S&M ATF) with Profile Elite hubs professionally laced, my front hub flange has cracked twice. The rear cracked once. The first time my foot stuck in the front spokes and pulled two spokes hard enough to break a chunk off the flange. The hub shell was replaced through warranty. I assembled the new wheel and experienced the same type of break on the flange, but the reason is unknown. The third time was my rear Profile Elite hub flange. All breaks look as if it was a pulling force. I only cruise the streets. I do not bunny hop, jump, etc... It's just crazy to me. All hubs were gloss or flat black. This post is mostly to tell the story, but if you have input, please give. Aloha
I am too new to post a photo....?
Jeremy967tree4 is offline
ryoanji
Bicycle Mechanics
21
06-22-19 05:29 PM
Narhay
Classic & Vintage
4
06-30-15 03:47 PM
Pompiere
Classic & Vintage
19
07-25-11 04:45 PM
merlinextraligh
Tandem Cycling
12
12-19-10 04:55 PM
Barrettscv
Classic & Vintage
1
12-14-09 01:48 PM
