Best Phone Holder For Samsung S6 Edge?
Hey All!
So I did spot this one: Velocity Clip & Bike Mount for All Smartphones
But was hoping you guys could share your wisdom on what the best phone holders are. This one above will only hold the phone horizontally which is ok but not optimal.
Also on a side note, what are the best light weight flashing lights for night riding?
Quoted: 800 Post(s)
Liked 218 Times
Hey All!
But was hoping you guys could share your wisdom on what the best phone holders are. This one above will only hold the phone horizontally which is ok but not optimal...
I carry a cell phone for communication, in particular because I am often on call for work; for navigation; as a camera; and as a listening device. I like to keep my I-Phone 6+ on my chest close to my head so I can hear it, and have it easily accessible to answer a call, take a photo, or spot my position on the confusing, haphazard thoroughfares of Metro Boston. Earlier this year I replied to this thread, ”Water proof cases for iPhones”, describing a badge holder suspended from the neck, in which it nicely fit.
Eventually, the weight of the phone on my neck became a nuisance, so I started carrying it in a side pocket inside my cycling vest, but then it was less readily available, harder to quickly pick up a call, and more awkward to use for the other tasks.
So my final, and most satisfactory innovation was to buy a Hidden Security Waist Wallet with a top zippered opening, and a pair of suspenders with clips. I then shortened the front suspender straps as short as possible, and fashioned a “shoulder holster” as it were, that comfortably holds the I-phone high to make it easily accessible.
I call it an ”I-bra.” . As mentioned above, I usually wear a yellow cycling vest, so the holster doesn’t show.
Quoted: 104 Post(s)
Liked 5 Times
Most people carry their phones in their jersey pockets or saddle packs. A phone with a 5 inch diagonal screen should fit comfortably in a jersey pocket.
I sometimes use this case when I'm using my phone for navigation. The smallest size they have should fit a GS6. This case provides more protection against weather and crashes than the one you suggest. Smartphone batteries only last a couple of hours when you have the screen turned on and map displayed, so this is mostly for commuting, not recreational riding. https://www.amazon.com/dp/B00D8IRP3G
I bought this: https://www.amazon.com/Aduro-Universa...e+holder+aduro
So far I have no problems with it at all. It's sturdy, doesn't move, and seems to keep my phone in place. It's also pretty easy to switch from portrait and landscape if needed.
Johnny and Vdub those are both great solutions!!! Dam it. I already ordered that Velocity one. I particularly like the look of that aduro as it can do both landscape and upright. I may have to pick one of those up as well.
Thanks for the other suggestions too guys, but i need to be able to see it so I can navigate the complex streets of NYC.
Cheers,
Simon
Cheers,
Simon
Ortlieb Ultimate 6 Bar Bag, their penultimate & top model has a touch friendly window on the Top.
View the ULTIMATE 6 M PRO at https://www.ortliebusa.com
NYC is a grid; Avenues run one way , Streets run cross town Whats the complex? London (England) is different..
I recommend packing it away in a bag or carrier. If you can't put the phone down long enough to go for a ride (Or anything else, for that matter), there's something wrong with you.
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Jersey pocket, inside a plastic bag to protect from sweat.
Quoted: 800 Post(s)
Liked 218 Times
I carry a cell phone for communication, in particular because I am often on call for work; for navigation; as a camera; and as a listening device. I like to keep my I-Phone 6+ on my chest close to my head so I can hear it, and have it easily accessible to answer a call, take a photo, or spot my position on the confusing, haphazard thoroughfares of Metro Boston.[/B]
To paraphrase the old Navy recuiting slogan, "A bike...It's not just ‘a ride,’ it’s a way of life.”
(“Navy…it’s not just a job, it’s an adventure.”)
I have two jobs and a family. My phone is as accessible as I need it to be. I have it with me on rides; I just don't let it interfere. I use it for phone calls and texts, usually to and from my patients. I use it on long road trips to find restaurants, gas stations, or hotels. The camera is nice, too. Never needed the GPS. If I can't deduce my location from road signs, landmarks, etc. I usually just ask. Besides, I can read a map, and, in the car there is an atlas. The whole point of texting is that you don't have to answer immediately. Forgetting that is what gets drivers or others killed. I'm from the wrong generation, I'll tell you up front. As far as I can tell, ALL people under 35 or 40 have a form of ADD. They fill their minds with useless extraneous information and panic if they get "unplugged." Really, that's not a criticism--- I don't personally care how you use or don't use your mind--- it's an observation.
I work closely with the ER in one of my jobs. The ER gets several tech zombies a day who were staring at their phone and stepped off the curb, and some who were doing the same while on bicycles. On the local MUPs, at least half of everyone is listening to their phone, whether walking, running, or cycling. I use a bell for the simple reason that they are more likely to hear that than my voice when I pass them. Hospitals have had to make it a firing offense to be caught on your phone at work. A smart phone can be useful, but it's not your life.
Old fart
Quoted: 3587 Post(s)
Liked 3,398 Times
I got a case very similar to this (https://goo.gl/IoXdur) for Christmas. It is pretty bulky but I can easily fit my S6, battery power pack for emergencies, and keys with no issue. I like the fact that phone is very secure (I don't worry about it coming loose from a mount if I hit a bump), and it is protected from the elements in case it begins to rain. I can also use the touch screen without removing it from the case.
It's not the coolest looking accessory on my bike, but it is very functional for my needs.
