Poseidon X VS ????
Quoted: 539 Post(s)
Liked 466 Times
Poseidon X VS ????
Is there a better equipped aluminum frame, carbon fork gravel bike than the Poseidon X , even at $200- $400 more? I'm about to get one unless someone has any suggestions that might be a bit better in this style bike.
First time here, at least posting! I've been eying the Poseidon X also but after really researching frame geometry, it appears the X is a little too aggressive for me. I found the the Ambition X has a higher stack and is a little more upright so now that bike is on top of my list until something else comes a long in that price range. It's about 100.00 more. I recall seeing a Salsa and a few others around 1200.00 or so. I really want the 1x11 drivetrain though and I have not seen any with that for around 1000.00. I did consider the State 4130 but I want light as possible. It seems so many of the 800.00-1200.00 priced bikes are running Claris 2x8 drivetrains right now.
Quoted: 446 Post(s)
Liked 1,045 Times
I'd probably opt for the newer Ambition X as opposed to the original X. The original X is definitely more aggressive geometry-wise. Plus the Ambition has dual piston brakes and will be a better long term bike to upgrade. My only issue with the X series (both the original and Ambition) is that they still use QR, though there's a thru-axle upgrade package available. If you want a new TA wheelset, you can get the thru axle rear drop out only from Poseidon and run a TA to QR adapter in the front to save on the hassle of cutting a TA fork to size and reinstalling everything. That's how I have my X currently setup.
Quoted: 427 Post(s)
Liked 339 Times
For a few hundred more $ the Salsa Journeyer is a huge upgrade and worth every penny extra. There are over a dozen models and several are around $1,050 or $1200. Next up is the entry level Giant Revolt in aluminum ($1350, price just dropped by $100). Also the Jamis Renegade steel S3 is still under $1500.
I posted earlier on the forum that we had two newer Poseidons in the shop to be worked on last week and found that on both either the stems or frames are actually crooked. When seat tube is vertical (with a level) the right handlebar end on both are almost an inch lower than the left handlebar end. It is easy to see with the naked eye actually, but we took measurements from the floor up to show the customer the difference in bar-end height on the bikes. Either the head tube was welded crooked or the stems are defective. On the positive side, it was consistent on both bikes!
The bikes were in for poor shifting and we replaced the cable cores; they were cheap galvanized steel cables like you find on Walmart bikes, not stainless. They had already corroded in the housing and started to bind up.
Likes For dwmckee:
I think you would be very hard pressed to find a better value than Poseidon. The aluminum frames are guaranteed for life (so the two crooked frames will be replaced). The X Line has carbon forks, Microshift Advent 1X has as good or better a reputation than any other group set at this price point. I do think that if you order ANY bike on line, you should have a basic knowledge of bike mechanics. Your LBS will always want you to buy a bike from them. If there is a better value, I would like to know. But I would like to know specifically what is better, not just “Brand X” is better… The other very important aspect is what will you be doing with the bike? Make sure you get a bike that will suit your riding needs! Will this be you only bike, or one of your N+1 bikes? Keep in mind, the more money you spend, the greater your options will be. The Poseidon X Ambition comes in at $900 with free shipping. If you want to spend a few hundred dollars more, do some upgrades. Hunt gravel wheels $510 (1459g), Panaracer Gravel Kings $80, Advent Alloy Cassette $60 (Saves over 8 Oz). So now you have less than $1,700 in the bike that will destroy any bike you paid $1,400 for… And comes in at about 22 -23 Lbs. It all depends what you want to do…
Likes For NitroExpress:
Also, as Poseidon makes their frames, have you seen same defects in other X Ambition bikes? As I am currently considering X Ambition, medium size, purchase, how does bike ride: either on top of bike or in the bike feel due to upright bike geometry? Due to 20" seat post and short top tube length, I am concerned rider (5'8" and 140 lbs.) will ride more upright position, on top of bike, instead of in the bike feel. Thanks
As I am currently considering Poseidon X Ambition, medium size, purchase, how does bike ride: either on top of bike or in the bike feel due to upright bike geometry? Due to 20" seat post and short top tube length, I am concerned rider (5'8" and 140 lbs.) will ride more upright position, on top of bike, instead of in the bike feel. Please respond to my concern. Thanks
Habitual User
Quoted: 4957 Post(s)
Liked 8,099 Times
Quoted: 446 Post(s)
Liked 1,045 Times
Likes For jonathanf2:
Quoted: 405 Post(s)
Liked 430 Times
This is the 2nd biggest myth in the bicycle industry. ("Frame flex wastes energy" is #1.)
Bike shops make nothing on bike sales. In fact, it's not uncommon for MSRP on new bikes to be $1 less than wholesale. Buying a bike online and paying your shop a couple of hundred bucks to build it for you will probably make you the single most profitable customer they see that day... if not all week.
Labor and accessories are where shops make money. Not bikes.
--Shannon
--Shannon
Quoted: 1088 Post(s)
Liked 1,026 Times
--Shannon
--Shannon
Likes For Russ Roth:
--Shannon
--Shannon
As for frame flex, not sure what your background is, but if a frame flexes, the energy required to make it flex, prior to engaging in the drive motion is lost (wasted). Now how much does that account for? For me nothing. For my son that rides 23mph for 50 miles, it means something. For the world class rider that is looking at 1 sec per kilometer, it means more...
Quoted: 405 Post(s)
Liked 430 Times
Maybe it's different now, but when I worked in a shop back in the 2000s, our margin on new bikes varied by brand, but was never that great. And the Fujis were as I said... invoice was MSRP+$1. I think we made like 10 bucks on the Cannondale. Treks had basically no profit in them either, but this was peak Lance-o-mania, so they could charge whatever they wanted.
And even if that's not true anymore, the point remains: your shop is going to make more money upgrading your old bike than selling you a new one, even for significantly more money.
--Shannon
--Shannon
2023 Salsa Journeyer
2023 Rad Rover 6
1980ish Raleigh Marathon (Vintage Steel)
2006 Trek 820 (Captain Amazing) RIP
2010 Specialized Tricross (Back in Black)
2008 Specialized Roubaix RIP
"I'm built like a marine mammal. I love the cold! "-Cosmoline
"MTBing is cheap compared to any motorsport I've done. It's very expensive compared to jogging."-ColinL
Rides:2023 Salsa Journeyer
2023 Rad Rover 6
Quoted: 1110 Post(s)
Liked 1,204 Times
I got the $1050 ones from REI, I got the Microshift Advent 1X9 in 700C and got the Claris 2X8 650B for her (just because it has a little lower gear and after I replace the 45mm tires with a set of 35's I have, she'll have a little more standover fitting her diminutive stature).
They both are great, very "rideable" bikes. And the fit and finish is nice. I might have gone with the Poseidon but it turned out to be easier for me to order the Salsas from REI to be delivered to the store where we were going. We picked them up the day we arrived, fully assembled (very well, by the way). I might have been able to save $100 or more for an "equivalent" bike, but I like that we have the support of REI to get the bikes ready to go for us away from home, and theoretically because they will back them up for a while (although I predict that I'll just take care of any problems that come up.)
The Microshift Advent and Shimano Claris are just fine. They shift accurately and smoothly. Are they Red, Dura Ace or Super Record? Maybe not. I really like the shifting design and function of the Microshif shifters. Better than Shimano (never liked the brake lever shifting) and on par with my favorite Sram "double tap".
Another FWIW: I think the QR axles on these bikes are fine. The design/geometry of the dropouts is such that the braking force will tend to drive the axles into the drip outs instead of causing them to slip out. Plus, they come with what look like very good quality internal cam QRs. We're not super strong riders and don't expect to really tax the braking/axles, etc. but I think they'll be just fine.... and easier to remove and replace the front wheel because we put them in and out of the pickup bed on fork mounts every ride. QR fork mounts are a bit easier to use than thru-axle ones.
Likes For Camilo:
