2018 Post Your Fixed Gear / Singlespeed Megathread
#552
dumb
Quoted: 174 Post(s)
#553
Quoted: 56 Post(s)
Liked 30 Times
Great looking bike sir! I really like your bottle cage. Aesthetically they are very cool. Does it hold your bottles pretty secure? I was looking at the Portland Design Works Maneki-neko for myself but none of my bikes have cage mounts. I may still pull the trigger and mount it on the saddle rails.
#554
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
The PDW bottle holders that look like swallows, owls, and lucky cats are the best you can buy, if you want a perfect combination aesthetics, function, and value. There are stronger ways to hold your bottle, and lighter ways, and just maybe (but doubtfully) better looking ways. There is nothing that rates higher on all points combined.
#556
Dave
#557
dumb
Quoted: 174 Post(s)
I had never heard of these... but cool! I'm confident that I could put them in myself... and I would assume a shop tech with the right mechanical skills could easily install them. They're press fit, so its simply drilling smaller diameter holes and press fitting them in.
#559
the are not all press fit, the ones I use at work I weld intinto place.
#561
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
#563
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
#564
Bikes: Too damn many to list, seriously.
Quoted: 96 Post(s)
Liked 26 Times
I just scrolled through all 23 pages. I noticed a lot of bikes with non carbon wheels and brakes and the brake tracks are still black. How is that? I want my wheels to be all black (no silver brake track showing), but not sure I want to spend the money on carbon wheels. On a side note, how good are some of the Chinese carbon wheels on Ebay?
#565
dumb
Quoted: 174 Post(s)
I wouldn’t suggest using the Chinese eBay wheels. I’ve never seen them in person, but I can see a quality difference just in the pictures they provide. They often look cheesy and toy-ish imo. Plus I’m not sure I would want to put my faith in sub par carbon components. Many carbon wheels will still have an aluminum brake track too. Both tri spokes I’ve owned have been this way. I just take a quality paint pen to the braking surface.
You can get smoking deals on used carbon wheels if you are patient. Just look on Craigslist and eBay regularly. Obviously meticulously watch for cracks and damage to the carbon
#566
Quoted: 56 Post(s)
Liked 30 Times
I've kept mine black by not riding them in the rain
#567
Quoted: 1062 Post(s)
Liked 665 Times
Other than aesthetics, is there a problem with anodized black rims wearing down to bare metal from braking? I assume the same is happening on silver rims, except it doesn't change how it looks.
Of course I don't disputing wanting to keep nice rims nice. I'm just curious for in case I ever come across black rims that I might want to use.
#568
Quoted: 56 Post(s)
Liked 30 Times
It's all cosmetic, nothing changes functionality-wise
#569
aire díthrub
Bikes: Raleigh Competition, Pashley Roadster Sovereign, Mercian Vincitore Speciale
Quoted: 259 Post(s)
Liked 55 Times
as far as the anodising is concerned, my opinion is that it just makes no sense. Yea it looks good, but it will wear away. So don’t buy anodised rims unless you’re using disc brakes. If you care about those aesthetics of course. it stands to reason that you do though, if you specifically chose colour anodised rims. Anodising is essentially just a coloured (or ‘clear’) electrolyticly forced, (surface) oxidation. Manufacturers like anodising because it’s cheaper than polishing or paint as a means of protecting against oxidation. (It’s also easier to control the thickness than paint) The extra ‘hardness’ that anodsing provides, that manufacturers like to talk about, is materially useless to a bicycle rim, or hub, or frame, or handlebars, etc. etc. Because it’s only at the surface. Most silver anodised riims, if they have a machined sidewall, will be bare aluminium or clear anodised on the sidewall. So the wear is the same. It has the same effect.
#570
Old fart
Liked 3,400 Times
OTOH, anodized surfaces tend to have poorer braking performance than raw aluminum. I had a set of hard-anodized Super Champion "Mixte" rims I ended up sanding the anodizing off the brake track to get decent braking.
belacqua
Classic & Vintage
62
02-08-19 10:35 PM
Darth Lefty
Northern California
0
04-01-18 12:15 PM
