Transporting a bike with disk brakes
Bikes: 2022 Specialized Creo E-Bike XXL with Custom Wheels, 1992 Serotta Colorado II with Dura Ace STI, 2021 Zinn Ti Clydesdale Team XXL with Ultegra Di2
Quoted: 54 Post(s)
Liked 39 Times
I’m getting a new bike soon that’s equipped with disk brakes....I’ll be laying the bike down in the back of my Highlander SUV like so....
Anyone have issues with transporting this way with disk brakes, especially calipers? I’m really careful, but I don’t want to unduly stress calipers..mounting....a little more concerned about the front fork caliper mounting..
I’m sure it’ll be ok...just don’t want to mess up a new bike!
Quoted: 54 Post(s)
Liked 39 Times
I can do that but would like to avoid taking wheels off as you can see I have plenty of space in the car...just wondering if any one can comment if they are transporting the same way and if any issues..
Quoted: 3240 Post(s)
Liked 2,086 Times
No, disc brakes don’t add any complications into the mix.
Likes For Steve B.:
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
unless you plan to off-road your car in such a way that the bike will bounce all over the place, I can't imagine any scenario in which you need to worry. I drive with my disc brake-equipped bikes in the back of my hatchback (front wheel removed to make it fit) like that all the time and I've never given it a second thought.
Likes For mack_turtle:
Likes For Geepig:
Quoted: 54 Post(s)
Liked 39 Times
Yes, I just ordered some heavy duty moving / furniture blankets....
Thanks..
Thanks..
Quoted: 590 Post(s)
Liked 445 Times
Just make sure the brake rotors don't contact the floor of the car, to avoid bending them on any big bumps.
No issues with that. I've done it plenty of times, albeit with the front wheel detached as it won't fit in my car otherwise.
Quoted: 94 Post(s)
Liked 151 Times
You did not mention whether your new bike will have hydraulic or cable disc brakes. If they are hydraulic some manufacturers recommend not laying it on its side. Chances are it will not cause issues but this is from the Shimano safety instructions (document SI-8KC0A-001-00) for their Deore disc brakes:
"When turning the bicycle upside down or on its side, the brake system may have some air bubbles inside the reservoir tank which are still there when the bleed screws are replaced, or which accumulate in various parts of the brake system when it is used for long periods. This disc brake system is not designed to be turned upside down. If the bicycle is turned upside down or on its side, the air bubbles inside the reservoir tank may move in the direction of the calipers. If the bicycle is ridden in this condition, there is the danger that the brakes may not operate and a serious accident could occur. If the bicycle has been turned upside down or on its side, be sure to operate the brake lever a few times to check that the brakes operate normally before riding the bicycle. If the brakes do not operate normally, adjust them by the following procedure."
If you put it on its side just check the brakes before you start riding and you will probably be fine. Also if you remove your front wheel do not touch the rotor with your hands and keep the rotor clean and free of grease and oil. Finally, when the wheel is off do not push the brake lever or you risk pushing the pistons out of the caliper (if it is a hydraulic system).
Likes For ARider2:
Quoted: 2026 Post(s)
Liked 1,096 Times
I've always transported my bike upright inside my CRV using a fork mount bolted to a piece of 1/4" plywood. I remove the front wheel and the seatpost and it fits very well.
For disc brakes you will need a bit more clearance so a higher fork mount is required. Here is a modestly priced good candidate and it is available to fit a range of thru axles and quick release hubs:
https://www.backcountry.com/kuat-dir...IaAlBGEALw_wcB
Quoted: 54 Post(s)
Liked 39 Times
Thanks for all the replies...I learned something here......I indeed used to transport my bikes in a minivan with the fork mounts....20 years ago....My car has a pretty low roofline and I am tall...the new bike (with Ultegra hydraulic brakes BTW) would require taking the seat post off or down, so Im going to try to lay the bike down...sounds like some of you do that with no issue...
I DO normally hang my Serotta with rim brakes upside down for storage.....sounds like that is not a good idea with these hydraulic brakes....I have a new Park Team workstand, so I guess I'll transfer that down to the basement during the winter and mount the new bike in that , then use it in the garage to store the new bike in the good weather....
And yes, I know about the caliper spacers when wheels come off.....
Thanks again
Thanks again
Quoted: 381 Post(s)
Liked 145 Times
I would much rather lower my seatpost or remove ..instead of laying flat. In an accident, you could regret that one when the bike becomes a flying obstacle. I do the same as hillrider in my crv.
In any case, if you accidentally press the lever with the bike on its side (or with the bike upwards) the lever will probably go soft. You can solve that by putting the bike horizontal again and pumping the lever. It's that easy.
Likes For Amt0571:
Likes For sloppy12:
If I have to lie my bike, I always lie it on the disc side. The fork and frame hit the floor before the discs, and a properly tightened caliper shouldn't move, so it's a non issue unless you do it on a surface that isn't protected and can scratch the frame or fork.
Quoted: 942 Post(s)
Liked 527 Times
If you lay down the bike with the calipers up....the bike will be derailleur down and that is the last thing you want to do.
Personally I would just get a bike rack.
Quoted: 54 Post(s)
Liked 39 Times
Thanks to all
I’m going to transport drive side up
I’ll use moving blankets / pads and bungees for support and secure the bike
For the new bike I am investigating my options for garage storage as I presently store inverted on hooks with the Serotta
