Replace Shimano Nexus 3-speed coaster brake hub with drum brake hub
Free and Self-Reliant
Bikes: Retrovelo Paula, 3 Speed Brompton, Rivendell Cheviot
I hope this is just an incredibly stupid question, and that explains my inability to find an answer by searching. Please let the answer be "Yes, duh."
I love the Kona Africabike, but a coaster brake is a deal breaker for me. I hate them hate them hate them. I *assume* that it's no big deal to replace the rear wheel with one built around an IGH with a drum brake. Do I assume correctly or is there something I need to look for to make sure it can be done?
At the price, the bike is totally worth buying and changing out the rear wheel. I just need to know that it *can* be done. I will never have another bike with a coaster brake. Did I mention that I hate them?
You have to look up the width or "over locknut dimension" for these hubs and find a drum brake hub with the same width as the hub which is in there already. You'll probably need to go with the same number of speeds.
If the Africabike is steel you don't need to worry because steel frames can be respaced to accomodate wider hubs.
I have had a newer Nexus 3 speed and a S/A 8 speed with drum. There's nothing that different in terms of the installation except for the width issue. The two hubs were not in the same bike; the 8 would be too wide for a 3-speed frame. However, it would have fit otherwise had I wanted to convert one bike to use the other hub.
Sturmey drum brake hubs have the cable stop built into the hub so you don't even need a cable stop on the frame. You just tie wrap the cable to the frame.
Sure it can be done. Get a Sturmey Archer 3sp Drum Brake hub. If the bike has a slotted tab for a coaster brake, it will be perfect for mounting the drum torque arm. Just keep in mind rear dropout spacing when considering a new wheel.
+ 1 on a sturmey 3 speed with a drum brake ,
there is a drum brake hub threaded for a freewheel too ,
they can be modified to reduce the right axle & spacer length ,
and used with a single, speed freewheels .. 6/7 speed is how they come.
Sturmey archer 8 speed has a gear set more suited to small wheels.
[1:1 is lowest, so chainring needs to be really small, all others are overdrive gears ]
Because the sturmey 3 speed is a century old design, all small parts are available.
SRAM/Sachs offers a drum+ 7 speed.
afraid of whales
Quoted: 347 Post(s)
Liked 5 Times
If it's a coaster brake 3 speed IGH, it's probably 120mm OLD. Sturmey makes 3 and 5 speed drum-brake 120mm old hubs.
What brand is the rear coaster 3 speed hub on the Kona?
I wouldn't try the 8 speed Sturmey Archer IGH right now, it's having issues even with the newest version and it will require changing the front chainring to a ~30T (no cheap options for that size). SRAM 7 speed drum version is hard to source in the US and spare parts are even harder to find. IMHO, for IGH/drum and 120mm OLD, SA owns the US market.
LOL, my kids say the same thing. I have one coaster brake bike in the stable (SACHS 7 speed) they refuse to ride it, they can't get used to not being able to backpedal.
afraid of whales
Quoted: 347 Post(s)
Liked 5 Times
I guess it's relative, a rear cog runs ~$6, new crank may require a new bottom bracket too, chainline can also be an issue. Good luck with your SA 8 speed, hope it works out for you better than other folk's experience. Many of those $125 hubs are the older model, take care not to get one of those!
Senior member
Quoted: 937 Post(s)
Liked 652 Times
BTW, I've installed a wide range 8 speed SA in a 700c wheel to see how it holds up with a 30/25 chainring cog ratio.
I'll be sure to share my findings.
On a Mission from God
Bikes: '10 Surly LHT, Rat-rod Klunker, '82 Peugeot PH12 Centennial
Liked 5 Times
I'm quite certain you are right about that. I'm in a position to know what the wholesale price is too, and I doubt you will find a wide range 8 speed at $125.
fotooutdoors
Adaptive Cycling: Handcycles, Amputee Adaptation, Visual Impairment, and Other Needs
5
06-09-14 03:14 PM
