Finish tape missing inside my box of handlebar wrap... what to use?
Bikes: Schwinn OR2 Hybrid Bike 28" - Schwinn LeTour II 27"
Hello all,
Quick question, what should I use? Gaffer's tape or black duct tape (to match the color) is the first thing that comes to mind. As a temporary measure I'm using zip ties to keep tension at the ends.
Thanks,
Max
Thanks,
Max
Quoted: 454 Post(s)
Liked 104 Times
Electrical tape works well for this, would not want to use zip ties, as these have shape edges from cutting where you are putting your hands
Quoted: 2026 Post(s)
Liked 1,096 Times
Bikes: '10 C'Dale CAAD9 4, '09 S-Works Tricross, Gary Fisher Tassahara
Funny, I have never used the finishing tape. I always end up using electrical tape.
Quoted: 38 Post(s)
Liked 11 Times
What is this "finish tape" you speak? Is it's a conspiracy by 3M and Scotch? If you wrap the tape the right way,you don't need any tape. When did people start wrapping tape backwards anyways......
I have thick leather wrap on my bars and I don't seem to have any problems tucking it in the ends with caps,there's a big hole there.
I always wondered what that tape was for......
Yes 3M electrical tape works good for bar wrap, that said I no longer use any tape as I have learned how to wrap my tape from the stem side to the bar end and use the plug cap to keep it all in place.
It may not be fancy but it gets me were I need to go.
https://www.jtgraphics.net/cyclist_bicycles.htm
Quoted: 4247 Post(s)
Liked 2,955 Times
Black electrical tape. Finish tape is those 2 little strips that are about an inch wide and 6 inches or less long (actually more like stickers with their backing) that you use to wrap the end nearest the stem if you wrapped it the right way. Either that or it's special tape from finland you use you wrap your bars with reindeer hide.
Liked 1,096 Times
Twine, see Rivendale site . You can get it at a craft store. Get a color to match a color on your bike. Get a larger diameter . With practice you can make a finished end like a custom fly rod has on it's eyelets. Amaze your friends, be the envy of others that use electric tape.......
Cheers all.....
Cheers all.....
Hello
Gaffers tape....because it is less prone to come un-done and smear sticky around like electrical... besides I bought 5 rolls at a garage sale.
Cheers all.....
Cheers all.....
Get it at your local hardware store. It comes in Black, Blue, Brown, Gray, Green, Orange, Red, Violet, White, and Yellow. I have a selection of colors at home to choose from to match or coordinate with the bar tape color.
It's stretchy, so it conforms well to contours of the tape end. Don't go wild stretching it and it sticks down very well. I've never had it come loose or become sticky. I didn't know people used anything else.
Quoted: 2952 Post(s)
Liked 3,106 Times
The finishing tape that comes in the box is just another one of those cycling related things I just throw away. (Along with valve nuts and caps.)
Thanks for all the advice .
Liked 7 Times
I wrap mine the "right" way and finish it off with black electrical tape. Cinelli black cork wrapped this way will last a long long time.
Bikes: Cannondale t1, Koga-Miyata World Traveller
The lay of the tape increases the wind drag induced by the handlebars. All serious racers have their tape wrapped starting at the drops.
If you ascribe to this theory, I have a bridge I'd like to sell you.
Roadkill
Bikes: 2002 Lightspeed Classic; 2010 Pedalforce RS
I bought some Arundel bar tape a while back, looks OK, but I haven't tried it yet, but the instructions on the box answer the OP:
1) Remove old stinky tape and scrub sweat residue off bars.
2) If bars are corroded, buy new bars. This is no time to save money.
3) Place a 3” section of Arundel tape around brake clamp to cover it up.
4) Begin wrapping from the end.
5mm-8mm overlap.
Maintain constant pressure. but don’t tear it!
5) Continue wrapping until you run into the stem.
6) Un-wrap some tape because you went too far.
7) Cut end diagonally so it’s straight!
8) Slap the enclosed finishing tape” on your toolbox, chainstay, bumper, etc.
9) Find some nice electrical tape and use it to hold the barwrap in place.
10) Tuck the overlapped tape into the bar end and install the plugs.
11) Admire your fine work.
12) Ride Bike. Don’t crash!
5mm-8mm overlap.
Bikes: Klein
+1 for the 3M Super 33. If you find the finishing tape, put it over the Super 33 if it looks nice.
Collector of Useless Info
At Lowes they have rubberized electrical tape with no adhesive- it just sticks to itself. It's quite a bit stretchier than vinyl electrical tape, and much easier to use. It's expensive- $3 a roll- but one roll should last nearly forever. It does a much nicer job of finishing, conforming to the handlebar and the wrap without all that nasty adhesive that melts when it gets hot and humid.
Yup, I stretched it nice and tight, but the tape I got from my LBS was cheap stuff from china and the bars on my LeTour II seem longer/wider & thicker than most modern bars I see in bike shops. As a single piece they would end up being about an inch short. I have a feeling though that the tape they had just isn't as long as good brands.
Thats awesome haha.
5mm-8mm overlap.
5mm-8mm overlap.
