Is this a safe way to add water bottle mounts?
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1087 Post(s)
Liked 1,825 Times
Seems if you are going to drill such large holes, you could weaken the frame. Maybe stick to clamps?
Robert
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
IMHO done right it will look fine and I don't think it will weaken the frame enough that it is going to fold up on you. That being said, the bikes I have without brazed on cage mounts are nothing special and mostly hi-tensile and I still don't want to do this. Velo-Orange and other places sell better options for clamping the cages to the tubes.
Likes For Chuck M:
Bianchi Goddess
Quoted: 2937 Post(s)
Liked 2,934 Times
Yeah it probably wouldn’t hurt but it’s not something I’d do. You need to make sure you get those rivnuts absolutely tight or they will start working on you.
Sugar "Kane" Kowalczyk
Likes For Bianchigirll:
ambulatory senior
Quoted: 1956 Post(s)
Liked 3,662 Times
I've used rivnuts successfully but wouldn't do it now with the VO clamps available. I bought some of those when they were only available through European sources. Glad they are at VO now!
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3891 Post(s)
Liked 6,491 Times
RJ
The Bike Hack.
"Hey, viewers!"
The Bike Hack.
"Hey, viewers!"
Likes For SurferRosa:
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
I wouldn't.
I dig RJ- especially in the early days- I identified with his brand of 'home mechanic without all the fancy tools.' He fixed **** with adjustable wrenches.
Commence to jigglin’ huh?!?!
Likes For The Golden Boy:
Pedalin' Erry Day
Rivnuts are perfectly fine, that's how bottle cage mounts get added to modern production bikes. Yes, you can spin them loose if you over-torque the bottle cage bolts - but that's not a problem easily avoided, and a spun out rivnut can always be re-tightened or drilled out and replaced if necessary.
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,614 Times
I wouldn't use them on a museum quality frame where originality is everything, but I have used them on less important but nice frames that needed a repaint anyway.
Shifting is fun!
Bikes: Yes, please.
Liked 4,614 Times
Even though I may do some things differently these days, RJ remains a trusted source for stuff I haven't tried yet.
Likes For non-fixie:
Crawlin' up, flyin' down
Quoted: 1027 Post(s)
Liked 2,531 Times
Unless you are having the frame repainted by someone who is experienced both at painting and brazing bottle mounts, I'd stick with the clamps or use the Velo Orange thingies. I sure as heck would not trust myself to start drilling on a frame.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
Small-diameter holes can have a higher "stress concentration factor" than larger-diameter holes.
I would be more wary drilling into butted frame tubing, all else being equal.
I ride a 1981 Bianchi Nuovo Racing with holes drilled into it's seat tube, and a 1976 Centurion Pro-Tour with holes drilled into it's downtube. Both are butted steel and none too heavy.
Likes For dddd:
Bikes: many
Quoted: 1448 Post(s)
Liked 1,396 Times
These? They look butt ugly to me. Not something I'd care to install on a nice vintage bike. Surely vintage bottle cage clamps are available in decent supply, yes?
Likes For TugaDude:
Quoted: 1952 Post(s)
Liked 2,013 Times
Likes For Classtime:
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,396 Times
Likes For cudak888:
Quoted: 586 Post(s)
Liked 612 Times
I saw them on Pinterest, along with a bunch of other options. Here's what the verbiage said...
Here is the link to the Pinterest page. Tons of options.
https://nordicgroup.us/cageboss/
Seat Post Bottle Cage Mount
Available for 30.9mm and 27.2mm seat posts. Sold direct from Specialized. Interestingly, I received a phone call from a bicycle shop in May 2012 asking where to buy these since a customer had inquired about them after seeing them on this site. Don't use these on a carbon-fiber seat post.Here is the link to the Pinterest page. Tons of options.
Bikes: many
Liked 1,396 Times
So, it would seem not to be intended for use on frame tubes. Instead, you slip them over the seatpost, then install the seatpost. That's unlikely to be all that useful on most C&V bikes with level top tubes. I don't think there will be enough exposed seatpost to squeeze a bottle cage and bottle between the saddle and the seat stays.
Likes For smontanaro:
Bikes: many
Liked 1,396 Times
Here are a few options on eBay right now:
- VINTAGE N.O.S. STAINLESS STEEL BICYCLE WATER BOTTLE CAGE CLIPS / CLAMPS SET (2) (Canadian seller has seven available)
- Water Bottle Cage Adapter Brackets For Frames Without Drilled Hole Bosses 1 inch (two available)
- T.A. Downtube mount water bottle cage CLAMPS ONLY TA Vintage Bike ALLOY NOS (not cheap, but authentic)
Friendship is Magic
Bikes: old ones
Quoted: 26427 Post(s)
Liked 10,383 Times
...I honestly don't understand the reluctance to mount a bottle cage on the bars ? They seem to work fine.
Likes For 3alarmer:
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 324 Times
I would say nuts to rivnuts. LOL.
I drilled the seat tube on both my old CCM and new Simcoe. Used a broken golf shaft to hold the bolt and then the socket. Later I figured that I should have got the bolt welded to the curved piece of tube reinforcing I used. I tightened a nut on the outside, then the cage and another nut. It's not coming loose.
Then I got 2 old Suntour friction shifters to butcher for use on the downtube. Turned out that they still had different design stubs. So much grinding ensued. Hope I didn't crush the tube over tightening. I would have got it done right if there was somebody to do it here.
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,308 Times
Quoted: 4806 Post(s)
Liked 3,933 Times
My two TiCycles ti frames have three sets each of bottle mount rivnuts. 2008 and 2011. Haven't had a single issue and the bottom, under the DT cage goes on and off for hot and long rides. The Dremel hasn't seen either bike. (I have heard framebuilders say that drilling WB holes is one of the more challenging fits because error is so obvious. I'm guessing most make jigs early on just for this.)
