Large Maillard Freewheel Tool?
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1298 Post(s)
Liked 940 Times
Can anyone give me the name of the tool that removes this Maillard 5-speed freewheel? It's a new one on me.
Unless you climb the rungs strategically, you’re not going to build the muscle you need to stay at the top.
aged to perfection
Quoted: 840 Post(s)
Liked 1,263 Times
that's the 24 spline tool, available on eboy
/markp
/markp
Quoted: 1372 Post(s)
Liked 1,752 Times
Haave a peek at this assortment I have. The one you seek might be Park-FR1 Splined. Beat of luck.
Likes For randyjawa:
aged to perfection
Quoted: 840 Post(s)
Liked 1,263 Times
Randy that's a great collection but I don't think that 24 t Maillard tool is in your pile.
here's what it looks like - pic shamelessly horked from ebay listing. Hard to find this one and priced accordingly.
your "no name splined #2" is a Phil Wood thin wall tool
Would be a well equipped shop that had one of these
/markp
/markp
Standard Member
Liked 940 Times
Yes, I see one, but it is pricey. I measured my spline diameter and it is 1.25", just as they have indicated in the online auction house offering. What was Maillard thinking? Is there anything mechanically advantageous to this design? I could see if the bearing races were a larger diameter, that could improve performance and durability.
That is the type I am still waiting on. From BikeInn. Online from Spain. Taking over three weeks so far. 20 dollars, others on ebay are 40 , also from Europe though. I am hoping it will arrive someday.
Tom.
Tom.
Likes For tfbike:
Standard Member
Liked 940 Times
Thanks. I appreciate it. I was able to re-pack the bearings and add new bearings with the free-wheel still on, even though I ordinarily take the free-wheel off to clean, inspect, lubricate, replace, etc. I've got one of those single-speed tools that you are showing that has the four prongs. Is that what it is? For a single-speed freewheel? Any particular make?
Quoted: 964 Post(s)
Liked 1,451 Times
Back when these freewheels were common, the Suntour/Simplex/Regina two-dog freewheel remover was the most common style. As we all know, these can go sideways in all manner of ways, ruining freewheels in the process of removing them (or even in the process of not removing them). In addition, sometimes you had to remove the axle to get the freewheel remover on there - depending on the configuration of the hub etc. I imagine this was seen as quite a satisfactory alternative.
I have the Bicycle Research splined one, Randyjawa posted in his picture. I'm pretty sure it is what I use to get these off.
Pretty sure it's this one on ebay. $25. I can verify when I am not at work. Remind me if you need it, and I'll make sure to verify my tool fits my Maillards.
https://www.ebay.com/itm/265931001918
Likes For scarlson:
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
The Bicycle Research CT-3 or VAR-405 are the proper tools for those freewheels.
Likes For JohnDThompson:
Quoted: 964 Post(s)
Liked 1,451 Times
There you go! Someone better snap that one on ebay up! Deal of the week, maybe?
Bikes: 2005 Orbea Spirit + 2018 Specialized Diverge + 1974 Raleigh Competition + 1983 Centurion Pro Tour 15
Quoted: 85 Post(s)
Liked 218 Times
I ordered one from BikeInn last week, shipping to Oklahoma. Hope it doesn't take as long as that to get here!
Likes For dbhouston:
Mine better not stop in Oklahoma! It seemed that it took some time to acquire mine? Once it shipped seems to moving along but tracking sucks.
Good luck.
Tom.
Good luck.
Tom.
aged to perfection
Quoted: 840 Post(s)
Liked 1,263 Times
guess I was wrong about that one Randy, you do have the tool on your board.
Weren't these FWs common on Schwinn Varsity ?
/markp
/markp
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 533 Post(s)
Liked 1,007 Times
Not for the faint of heart, but I once got one of these off using a pipe wrench. And not in the conventional destructive way. First I removed the axle and bearings. That gave me enough room to put the top jaw of the pipe wrench inside the center, so the side edges grabbed the splines. Then I tightened the lower jaw against the teeth on the cogs as much as I could so it didn't slip. Then I leaned into the wrench. It was several years ago, and I can't recall how hard it was to get loose, so I might have just got lucky that it wasn't seized on the hub. You are using the wrench 90 degrees from the normal direction of force, so no warranties expressed or implied.
Quoted: 85 Post(s)
Liked 218 Times
Mine last checked in at The Hague four days ago which was, coincidentally, the date BikeInn originally said it would be in Tulsa. Maybe I should alert the Navy that there may be a lost ship in the North Atlantic! Or USPS is just really sloppy about scanning things.
Quoted: 85 Post(s)
Liked 218 Times
Took a while to get here, but it fits like a glove!
Standard Member
Liked 940 Times
Bikes: 1964(?) Frejus Tour de France, 1967(?) Dawes Double Blue, 1979 Trek 710, 1982 Claud Butler Dalesman, 1983 Schwinn Paramount Elite, 2014 Brompton, maybe a couple more
Quoted: 310 Post(s)
Liked 679 Times
I just went up to the bike co-op in Toledo, Ohio looking for one of these, and they had one! Worked like a charm. It felt like the larger diameter spread the force better, and that seems logical to me.
