Stainless tools for stainless fasteners
Bikes: '10 Fuji Cross Comp, '12 Brompton S-Type, '14 All City Mr Pink
Quoted: 10 Post(s)
Several companies make stainless hex wrenches which are supposed to reduce contamination / corrosion when using stainless fasteners.
Does anyone know if this is a significant effect in bike applications?
The idea behind stainless fasteners is their resistance to oxidation/corrosion. Unless you plan on permanently attaching a hex wrench or other tool to any of your stainless steel fasteners there is no need to worry about the tool causing the onset of corrosion.
With the notion of contamination....this is important when dealing with chemicals. Ferrous material can cause unwanted reactions such as explosions when used in environments where high concentrations of O2 are used.
There is nothing so sensitive about a bicycle that non-stainless tools will cause any issues.
But if you want to empty your wallet for no particular reason then go ahead and buy stainless steel tools.
-j
-j
Quoted: 1438 Post(s)
Liked 1,092 Times
Free iron contamination can be a factor in very sensitive applications but is basically irrelevant in bicycle service. The only possible issue is cosmetic, as the free iron can rust, similar to what happens if you clean an aluminum rim with steel wool; iron particles can become embedded and cause rust stains. This risk would not convince me to invest in stainless tools but YMMV. Also, you would need to avoid using your stainless tools on non-stainless items lest it pick up contamination and transfer it to the stainless surfaces.
BTW, "stainless" steel is not truly stainless/rustproof but is properly referred to as "corrosion resistant"; under certain conditions some alloys can rust, especially if improperly passivated.
Here is a discussion: Iron Residue / Contamination on Stainless Steel Surfaces
Bikes: Custom built LHT & Troll
Quoted: 837 Post(s)
Liked 149 Times
I see no reason to purchase stainless tools for the benefit of the fasteners. I do, however, think that it is worth considering on (extended) tours, where tools may suffer from corrosion
Quoted: 10 Post(s)
Thanks for the comments and link.
Yeah, it's really the cosmetic issue that I thought it might help with. The inside of even stainless hex heads seem to wind up rusting a little (I usually give them a dab of T-9, and it isn't totally effective).
I may buy a single 4mm and then do a controlled test on my fender mounts. If it doesn't help any, I have a spare 4mm hex wrench.
Interesting point about touring, and tools that actually leave the garage.
Nigel
Bikes: 1980s and 1990s steel: CyclePro, Nishiki, Schwinn, SR, Trek........
Quoted: 384 Post(s)
Liked 6 Times
A mild acid (oxalic, vinegar, lemon juice, coca cola, etc), followed by flushing with water, then the T-9 would be far more effective than T-9. The T-9 has nothing in it to passivate the surface.
Quoted: 2595 Post(s)
Liked 1,923 Times
Good point. It'd be nice to get a stainless multi-tool for commuting as well, since sometimes it rains. But the "stainless" tools I've seen all wind up being stainless frames or such, and the hex wrenches, etc. are all carbon steel.
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
I nominate for OCD post of the month...
Today, I believe my jurisdiction ends here...
You could try clear fingernail polish especially on bolts that aren't likely to be undone again for a while.
Stainless tools are aimed at the boatie market. I can guarantee you will pay two, three even five times the price of a normal similar tool.
I have toured extensively in wettish climates. The little crescent wrench I have has done many thousands of miles. It gets rusty occasionally, but not so it's unusable. If getting tools wet is an issue on tour, use a small dry bag to pack them; when I used one, it used to hang from the rails of my saddle behind the seatpost.
Just reading another thread about the back brake going on the front, and using a bench grinder on the nut... and it raises a good point about the chrome finish being removed and causing rust.
Most small fasteners on bikes have poor quality chrome plating and using a tool of any sort -- carbon steel or stainless -- would seem to disturb the plating on edges and corners, so inviting rust.
If you really want to preserve the finish, go stainless bolts. I am sure there must be a nuts-and-bolts retailer who specialises in stocking metric stainless fixings. You will pay a little more, but it sure would be cheaper than buying a stainless tool.
Quoted: 273 Post(s)
Liked 10 Times
I look for SS (or Ti) fasteners for that exact reason.
Check these out: 10 New Tektro 10mm Brake Mounting Nut Stainless Steel Road Bike M61019 119559 BD | eBay
Constant tinkerer
If cosmetic rust is your concern I think your money would be better spent on a bag of stainless fasteners so you can throw them away when they get rusty and replace them with new ones.
Quoted: 258 Post(s)
Liked 1,923 Times
Fastenal in the U.S. has metric stainless bolts. Call me OCD, I picked some up to replace some bottle rack bolts that were well rusted after only 15 years. Remember to ask me in another 15 years how well they worked out.
Friendship is Magic
Bikes: old ones
Quoted: 26381 Post(s)
Liked 10,358 Times
...the great thing about stainless fasteners is you can also use them on your sailboat.
Friendship is Magic
Bikes: old ones
Liked 10,358 Times
Friendship is Magic
Bikes: old ones
Liked 10,358 Times
...word.
Friendship is Magic
Bikes: old ones
Liked 10,358 Times
Friendship is Magic
Bikes: old ones
Liked 10,358 Times
Half way there
Quoted: 985 Post(s)
Liked 879 Times
What sub tender? I spent some time on the Hunley and Holland when they were in Scotland.
Friendship is Magic
Bikes: old ones
Liked 10,358 Times
...the USS Fulton, AS-11. We left the pier in New London twice when I was aboard, and it took a while to grind the welds off the mooring chains.
