#1601
Derby Lightweight racer
I just pulled a Derby Light Racer down from the rafters and have begun to clean, degrease, and change the cables. I haven't been able to find much info on this bike but it seens like a worthwhile project. I don't think it's a cheap bike, seems on par with a schwinn voyageur I had in '73.
#1602
Quoted: 4494 Post(s)
Liked 6,300 Times
#1603
Overdoing projects
Quoted: 783 Post(s)
Liked 1,215 Times
#1604
Not lost wanderer.
Quoted: 885 Post(s)
Liked 979 Times
Had to fix a fork and finish this simple bike for my friends kid.
IMG_20190311_181046292 by Bwilli88, on Flickr
had to straighten the fork
IMG_20190318_163056392 by Bwilli88, on Flickr
IMG_20190320_152314453 by Bwilli88, on Flickr
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
#1605
ambulatory senior
Quoted: 1953 Post(s)
Liked 3,634 Times
#1606
ambulatory senior
Liked 3,634 Times
I dont have a pic but i took my park tool pmp-5 pump apart and reassembled it. The end of the plunger had come off and i was afraid i would break it taking the pump apart. Losing my zefal pump prompted me to take the plunge and pry the endcap that the plunger goes through off. All ended well and i have a frame pump again.
#1607
Fender treatment on big blue.
#1608
Quoted: 796 Post(s)
Liked 522 Times
The pitted cups on the 85 Novara Randonee
pitted and "gritty" even after cleaning
Led to the purchase of a UN-55 sealed BB unit which got installed today
Spiffy new BB
Spiffy new BB
#1609
ambulatory senior
Liked 3,634 Times
#1610
Quoted: 796 Post(s)
Liked 522 Times
#1611
ambulatory senior
Liked 3,634 Times
Seem to be very smooth.
#1612
Quoted: 9 Post(s)
Liked 9 Times
fixed cup and freewheel removal
never had much luck removing fixed cups on bb but was motivated to get this french threaded bb off a vitus to install on a gitane with honeycomb rear drops. used a sugino bb wrench and with some persistence and leather gloves, the fixed cup loosened to my surprise. another challenge was removing a regina FW off a suntour superbe large flange hub with the spokes cut off from the wheel. thanks to RJ the bike guy youtube video for guidance on how its done, i managed to remove the FW without any damage to the hub or FW. FW will be used as a paper weight.
#1613
This.;. Bar mast custom , to my design,
Shortened the shift cables, to take the S bend, seen here, out .
Brakes: from BB7 to HyRd ...
#1614
Quoted: 233 Post(s)
Liked 346 Times
I just installed Odyssey Straddle Rods to the Scott-Pedersen SE Brakes on my "85 Cannondale SM600. The original straddle cable and yoke assembly was too lightweight and easy to adjust.
It was very hard to find those rods in the longer length of the 2 that they made which I needed. It is a very solid-feeling set-up.
#1615
ambulatory senior
Liked 3,634 Times
#1616
Quoted: 2300 Post(s)
Liked 4,766 Times
Well today I removed the stuck dust caps on the Martens built Ribble so I could make sure the play I was feeling was the BB not crank arms. Two days of soaking in PB blaster, heats, tapping with wooden dowel, etc all failed to free them. Quick work though once I drilled a hole in them then took punch and small hammer to them. Couple of taps at angle and they started turning just fine.
Play does appear to be in the BB so now to source the best option. For no good reason than other than "because" I'm trying to get this under 20lbs built up, ready to go. Right about there so I want to make sure every new part that goes on is lighter than what I took off.
Steel is real...and comfy.
#1618
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3846 Post(s)
Liked 6,437 Times
#1619
señor miembro
Liked 6,437 Times
No doubt. Vitus 172 feels every bit as light as 531. Maybe it's not as strong, but I wouldn't know it.
I had an early '80s Grand Jubile like that. Great bicycle. And even though it was longer than my 531 Grand Record, it would climb just as well.
#1620
Bikes: Only my riders left...
Quoted: 350 Post(s)
Liked 782 Times
Done!
Mmmmmmotobecannnnnnnne...
Shake down ride awesome!
Flawless! Confident! Fast! Stupid stable!
All of the above!
No adjustments needed!
I’ll mess with the fit as I go along.
Bike weighs 27lbs.
#1621
Ellensburg, WA
Bikes: See my signature
Quoted: 313 Post(s)
Liked 457 Times
Picked up what look to be never used Sampson Stratics pedals today. They’ll go on the Nishiki Maxima today. Yeah, the cleats on the shoes are a pain but I really like the pedals
Likes For scozim:
#1622
minimalist cyclist
Bikes: yes please
Quoted: 1112 Post(s)
Liked 1,626 Times
Nice ! I just got a '75 Continental last week and I plan on keeping it original too, it even has the matching color tape in good shape.
https://www.bikeforums.net/classic-v...st-39-lbs.html
I worked on it today, and I did take the turkey levers, rack and reflectors off but plan on keeping everything else original including the saddle if half-way comfortable. I like how Schwinn put their name on everything, even the Ball Bearing holder in the BB
Where'd you get the fenders?
#1624
Bikes: The keepers: 1958 Raleigh Lenton Grand Prix, 1968 Ranger, 1969 Magneet Sprint, 1971 Gitane Tour de France, 1973 Raleigh Tourist, 3 - 1986 Rossins, and a '77 PX-10 frame in process.
Quoted: 221 Post(s)
Liked 237 Times
Finally got around to the final checkover, tuneup, and other niceties on the '98 Trek 6500 mountain bike that I picked up at the Westminster swap meet. And, headed out to Poor Farm Park in Ashland, VA for my first stint of mountain bike riding in about five years.
Jeezus, am I rusty! It didn't help that I forgot the layout of the park, and hit the trails in the middle of the more technical section. Gingerly picked my way to the easier part of the park and proceeded the relearn what I haven't done in years. The bike and I got along fine, and it'll probably be a keeper . . . . . . . at least until I go thru another mood of, "This is stupid . . . I'm a roadie" and sell this one off just like I've done each of its predecessors.
Seems about every three years I get in the mood to do some mountain biking. Which lasts about six months, and I sell the bike.
Syke
“No one in this world, so far as I know — and I have searched the records for years, and employed agents to help me — has ever lost money by underestimating the intelligence of the great masses of the plain people. Nor has anyone ever lost public office thereby.”
H.L. Mencken, (1926)
Syke
#1625
Quoted: 535 Post(s)
Liked 344 Times
Today’s set aside for beginning a build I’ve been thinking on for a while. Got a bit of a start to it this morning already. A little cavity prep before squirting Frame Saver into the tubes later, and what should be followed, if all goes as planned, installation of HS & BB.
