Broken Deraileur hanger - glueing it back together!
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times
Bike fell over one too many times and snapped the deraileur hanger . That's what it's supposed to do of course. Problem is, Jamis can't get me a replacement fast enough. 2019 Jamis Renegade Exploit.
Got a big gravel ride this weekend and I need a fix. Gonna try glueing it back together!
More to come....
More to come....
Quoted: 198 Post(s)
Liked 332 Times
Ok, I'm no dummy to bonding. Epoxy is my adhesive of choice. With proper surface prep, clamping and curing, we have the technology. We can rebuild him!
Quoted: 198 Post(s)
Liked 332 Times
5 minutes tack time, 1-hour cure. I let it sit clamped overnight just to be sure.
Quoted: 198 Post(s)
Liked 332 Times
Looking good this morning. Just some mild flexes in my hands are exhibiting good bonding. Can't catch a good photo, but it's like a slight weld bead exists around the bond lines.
Going to throw it on the bike this afternoon and try it out.
May the Force be with me...
- You
WALSTIB
Your much smarter than me. I would have went with duct tape
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 758 Post(s)
Liked 809 Times
yah..that's totally gonna work. awesome dude..
Quoted: 207 Post(s)
Liked 108 Times
I know you need that to work. You want that to work. You don't want to feel helpless by your misfortune. But reflect on this dispassionately before you take that long gravel ride.
Likes For 55murray:
SE Wis
Quoted: 2740 Post(s)
Liked 3,385 Times
I personally would have drilled & tapped it as well as glue. Or minimum wrapped it in wire embedded in glue on the outside as well. I suspect you won't be going far.
Likes For dedhed:
Quoted: 198 Post(s)
Liked 332 Times
I'll be taking it on a test run tonight. Murphy's Law probably dictates it will fail when I'm the furthest out from help or support . In such a scenario, I will convert it to a single speed, shorten the chain, and limp home
Quoted: 198 Post(s)
Liked 332 Times
I thought about doing some of that. Due to where the break is and clearances to the frame, there's really not room for growth externally. Not enough area to drill and add pins.
Likes For Wilfred Laurier:
Quoted: 198 Post(s)
Liked 332 Times
I have a backup bike, it's my Fat Tire with 2.2" wheelset. It is an absolute DOG to ride compared to my Jamis Renegade! I've been riding it over the last week and it wears me out much faster! ALSO, it has a creaky bottom bracket. I have a replacement BB but I found I needed to order a special wrench! Won't be here until Saturday.
Quoted: 198 Post(s)
Liked 332 Times
Adding a little background info.
Called LBS about 1-1/2 weeks ago about a replacement hanger. They didn't' have one in stock so they reached out to Jamis. Heard NOTHING back for over a week, I also tried contacting their Customer service via a WebForm/Email but nada. I finally found a phone number and called them directly, left a message. Was happily surprised yesterday when they called me back. Talked to a nice lady who confirmed the order from LBS but it hadn't been shipped yet and no estimated date
Yes, I understand these are tough times and bicycle business' are overloaded so I understand their situation, they are trying their best. I also reached out to a few other Jamis bike dealers, got a couple responses but none in stock.
Have tried other online suppliers of replacement hangers- no dice
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
I suggest you stop dropping the bike. One more hit and the hanger will break again.
Likes For GlennR:
SE Wis
Liked 3,385 Times
Quoted: 426 Post(s)
Liked 695 Times
Have you tried a hanger supplier, other than your Jamis dealer, such as: https://derailleurhanger.com/
They don't list the Exploit, but there are other sites out there. Is there a number on the hanger by which you might search?
WALSTIB
https://wheelsmfg.com/derailleur-han...ers/jamis.html
Here also. Maybe can pay crazy shipping for in time
Quoted: 198 Post(s)
Liked 332 Times
Quoted: 198 Post(s)
Liked 332 Times
Quoted: 198 Post(s)
Liked 332 Times
I know what your saying. I've concluded this adds more risk. Appreciate the thought.
On Your Left
Liked 2,433 Times
There's a difference between wear from use and damage from abuse.
Not saying you abuse it but "Bike fell over one too many times" tells me you need to change what you are doing.
Best of luck and if your LBS is not getting results... try another. I snapped the crank fixing bolt and contacted a LBS. With no word after a few days, I called another shop and had the part 2 days later. It's been 10 weeks and i've still not heard back from the first shop and don't plan on using them in the future. My point is some shop can't be bothered to order a part they don't make any money on.
Likes For GlennR:
Quoted: 198 Post(s)
Liked 332 Times
Totally of of context.
You got to learn life's lessons the hard way. Or at least I do.
