Another thread about mounting disc brakes to a frame...
Quoted: 27 Post(s)
Liked 9 Times
I apologize for starting another thread on disc brake frame conversions but I was just hoping for some comment on the feasibility of two frames for conversion. My wife and I have steel bikes we used for Audax riding, general road riding and touring. We have recently spent more time mountain biking and both find the braking on our road bikes frustrating and are looking to upgrade them anyway. We got some feedback from a local frame builder but was interested in any comments others might have on the forum.
My bike is a Fuji World 2004. It has a Reynolds 853 main triangle. I was told the problematic part for a conversion is the rear dropout. To remove the wheel you pull it forward. I was told they could be cut off and replaced by welding in new ones (possibly through-axle). The current fork is carbon/alloy and would need to be replaced. There are a few options around for 1 1/8” steerer in carbon. The nearest to what I have (just from looking at it) is a Ritchey adventure fork but I imagine small differences in the geometry of the fork can make a bit of difference to the ride?
My wife’s bike was a Bioracer shipped out from Europe back in 1998. I don’t have specifics on this one. It’s made from Columbus steel, with a steel fork, had a horrid paint job which delaminated after a few years and had to be re-coated. That said, my wife did PBP on it and plenty of cycle touring. The frame builder I spoke to pointed out his issue with this frame was the front end which has the old style steerer and stem. The fork would need to be replaced and he was not willing to make up a new one as in his opinion discs should not be fitted to a fork with a steerer less of than 1 1/8”. Any thoughts on this? He also said it would not be worth replacing the head tube.
Thanks in advance for any feedback you might have.
Quoted: 4208 Post(s)
Liked 3,874 Times
I'd say the builder is more right then wrong. I could quibble about the rear dropouts and such but the bottom line is axle placement being consistent (and of course the braking load paths on stays not intended to handle them) and how the disk can be slid out of the caliper.
Some of the disk wanting mania reminds me of the hot rod era. Put a big engine is a family car and all kinds of other issues become real important real fast. Andy
AndrewRStewart
AndrewRStewart
Randomhead
Liked 3,699 Times
I have a disc audax bike planned, and I'm going to use a 1" steerer for that bike. My rationale is that braking loads on that bike will not be too severe. I think that if I was going to do touring on it, I would want a 1 1/8" steerer. I thought about this for quite a while and then found that Crust bikes has a 1" steerer disc fork, so I figured if they were still in business, people weren't dying because of it. I can understand why a builder wouldn't want to do this though.
Putting discs on a road bike is a pain. They aren't made with space for a disc. If you really want this, it's probably best to get new bikes.
Likes For unterhausen:
https://www.paragonmachineworks.com/...12-mm-hub.html
Randomhead
Liked 3,699 Times
Those dropouts are not that easy to get on a new bike. I'm struggling with that right now. I don't see how it's really practical to try on an existing bike, especially assuming it has straight stays. It would take some pretty extreme cold setting, which is not that easy on an existing frame. I have seen you mention replacing dropouts a couple of times now, have you done it? Do you have pictures somewhere?
I think the only way to get discs on an existing road bike is to cold set the dropouts to 135 and go with a seat stay mounted tab. There are adjustable tabs for horizontal drops, but as Andy says forward facing drops might have a problem with wheel ejection. Paragon had some vertical dropouts with built in stay mounted tabs, but I'm not sure they still make them. Probably some people out there have some spare ones.
I have a couple of frames that I have thought about replacing the chain stays on. Seems like a silly amount of effort. I might still do it, dunno.
Quoted: 714 Post(s)
Liked 800 Times
Randomhead
Liked 3,699 Times
My next step is to make something like your fixture. It would be a lot easier if I bent my own stays. Pre-bent sbend stays aren't meant to be that far out where they have to be to hit the front of the dropouts. This is good for tire clearance and bad for crank clearance. It's too bad nobody none of the U.S. suppliers got the columbus low mount stays.
And I'm also set on using a lugged bottom bracket shell. I'm not actually worried about the connection with the dropouts. I need to prove to myself that the stays will give me the tire clearance I want while leaving crank clearance
This is the Raleigh Peak 650b disc conversion
3/4 straight CS 1 1/2 inch round Paragon dropout
New build Paragon disc dropout
Randomhead
Liked 3,699 Times
Thanks. Are you tall?
Quoted: 714 Post(s)
Liked 800 Times
Also, I agree that wsteve464 must be tall with the angle on those seat stays.
Was now down to 6'3" from 6'4" . I am having a hard time finding my fit. I need a tall head tube for a more upright position. I think I may have one that fits, the one with the round dropouts has a 550mm toptube as opposed to my other with a 580mm TT. I can't stretch out like I used to.
Likes For wsteve464:
Randomhead
Liked 3,699 Times
I was mostly curious if you were tall because the angle of those seat stays is pretty big for a mountain bike. Road bikes generally have steeper seat stays.
Quoted: 27 Post(s)
Liked 9 Times
Good Point. All I'm missing is the big engine! I must admit though, most of my cycling challenges over the years involved going rather than stopping. That said, the canti's are damned annoying.
Quoted: 27 Post(s)
Liked 9 Times
If you do go with discs you will need new wheels and the standard now is pretty much 100mm axle in the front and 142 mm in the rear. If I were to do this I would make a new fork for the wider axle and legs made for disc brakes. In the rear you should be able to get away with a set of the Paragon drop outs for disc brakes.
Randomhead
Liked 3,699 Times
Your stays have to be bent out. 130 to 142mm wide.
Quoted: 714 Post(s)
Liked 800 Times
I really wish people would understand that the inside of the dropout face is in the same place with 135 and 142. The only difference is that the 142 thru axle dropouts have a 3.5mm recess on each side for the hub end cap to seat in. It is just like the dropout slot in a QR dropout. The inside of the dropout faces are still 135mm apart, only the faces of the slot are 142mm apart.
Likes For dsaul:
Randomhead
Liked 3,699 Times
Yes, you're right. The real issue with retrofitting chain stay mount (low mount as Paragon calls them) dropouts is getting the stays out to the front of the dropout. If you go with seat stay mounting, this might be a little less depending on what it takes to clear the disc. The old-school vee brake mountain bikes tend to have decent clearance for the disc, so maybe the low mount dropouts will work. I feel like a road bike would pose more of an issue unless it's for 140mm discs. Which is to say that someone that doesn't do this all the time is going to have to do a lot of fiddling beforehand and I can understand why they wouldn't really want to do it or at least charge a reasonable rate for their time.
Quoted: 27 Post(s)
Liked 9 Times
Has anyone got any further comment on the suitability of a 1" steerer for a fork with disc brake mounts? Remember this is for a bike that will be going touring.
Randomhead
Liked 3,699 Times
Do you overpack?
I think you already got your answer about the 1" fork, your builder said no. You're going to have to put in some research to find someone that will make one for you. Retrofit is out unless the existing fork is an overbuilt unicrown fork. Most forks built for rim brakes are very marginal for disc, it's not unlikely that it would fold under heavy braking.
The Ritchey fork has Axle-Crown: 393mm. Good news is it has 50mm rake, because that A-C is likely to push the front of the bike up and reduce the head tube angle.
I'm a little surprised I'm the only one who thinks you shouldn't put this much effort into major modifications on a $1500 bike. Does your framebuilder work for free?
With the cost of the rear disc dropout conversion and the custom fork it would probably end up costing more than a new bike.
Quoted: 27 Post(s)
Liked 9 Times
Do you overpack?
Likes For Nomad2:
Quoted: 27 Post(s)
Liked 9 Times
Ask the framebuilder if using a thicker walled steerer tube would work. A standard steerer tube appears to have a maximum wall thickness of .090" and is made of crmo. You can get 1 inch crmo tubing up to .188 inch wall thickness. You would need to use a threadless stem and probably a shim to 1 1/8" over the steerer tube to make the stem fit and have a nut welded in to the top of the steerer to allow the stem cap to be tightened to set the preload as a star nut would not fit, just a thought.
Quoted: 103 Post(s)
Liked 144 Times
If the weight, fit and ride are what I wanted, I wouldn't worry about whether it's 853 or not. It wouldn't have a discernable effect on the ride - especially with our new fat tires. Also, speculating a bit, my limited experience with 853 is that it's too hard (as in material hardness) for efficient post weld machining. 853 ST and HT's are difficult to quickly/easily ream and it wears out tools faster. If this is the case, your current bike might only be 853 in the DT/TT (I'm guessing here but...seems likely).
It looks like the XR is made from 725 which is a similarly high end heat treated tubeset. The XR would be a full upgrade from your current bike including braze-ons, wheel fitment, headtube size and fork. It's any easy choice for me - aside from the $$.
I'm less sure what to tell your wife about the paint! :-) You could have a painter put some accents on it for relatively little $.
https://www.flickr.com/photos/54319503@N05/
https://www.draper-cycles.com
Likes For duanedr:
Quoted: 2338 Post(s)
Liked 2,826 Times
any thoughts about just having the framebuilder do a custom frame? how much cost differential would that be from the conversion. and theoretically the result would be better and more integrated and to purpose
I have had some discussions with a well known framebuilder who has done a lot of pioneering work with disc on road bikes. He noted that to meet his safety standards, especially the forks he has to build stronger and his disc frames are are heavier. disc vs caliper is all up to planned usage
Likes For squirtdad:
