Braking performance varies on two road bikes
Old 06-14-20, 02:07 PM
WorldIRC
Canadian eh?
Bikes: 2020 Specialized Roubaix Expert
Quoted: 131 Post(s)
Liked 96 Times in 54 Posts
Hi There,
I have two road bikes. One is my Cannondale Synapse Carbon Ultegra with Campy Zonda wheels and Ultegra 6800 brakes. The other is an older Trek Madone 4.7 with the stock Bontrager Race wheelset and 105 5700 brakes.
Both bikes are well tunes, modulation is great on both, and pads are in great condition on both.
When I brake on the Cannondale, unless I full lock, I'm mostly just "slowing down". The sound from the rear brakes can be a bit "loud" if I brake hard enough. I looked, they don't appear dirty or contaminated with metals that would cause this.
When I brake on the Trek, it doesn't take much, but I can forcefully feel myself "slowing down", even if just utilizing the rear brake (and not locking it).
Any thoughts / ideas?
WorldIRC is offline
Old 06-14-20, 02:38 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1438 Post(s)
Liked 1,092 Times in 723 Posts
What kind of brake pads are you running? Since they are the friction element they have a big influence on braking performance.
dsbrantjr is offline
Old 06-14-20, 02:48 PM
79pmooney
79pmooney's Avatar
Quoted: 4782 Post(s)
Liked 3,899 Times in 2,536 Posts
+1 And what are the braking surfaces on the rims? Carbon fiber? Aluminum? (I've only ridden aluminum - and steel in the dark ages) so I cannot comment from experience but I hear they brake quite differently.)
Ben
79pmooney is offline
Old 06-14-20, 02:58 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4191 Post(s)
Liked 3,834 Times in 2,293 Posts
I speculate that rim/pad condition as well as cable free movement contributes a lot to overall feel of "braking power" (actually the ability to remove energy from the rider/bike to the brakes) then things like caliper/lever leverage factors and also pad material (although this last bit is more variable).
Having said that Shimano has spent a lot of $ to convince the buying public that each more recent brake system is "more powerful" then the last. Of course this assumes all aspects of said systems are within Shimano's specs, not always valid with non Shimano cables and rims. Andy
AndrewRStewart
Andrew R Stewart is offline
Old 06-14-20, 04:10 PM
WorldIRC
Canadian eh?
Quoted: 131 Post(s)
The Cannondale definitely has Ultegra pads. The Trek I believe has 105 pads as well.
WorldIRC is offline
Old 06-14-20, 04:12 PM
WorldIRC
Canadian eh?
Quoted: 131 Post(s)
Ben
Aluminum for both.
WorldIRC is offline
Old 06-14-20, 09:35 PM
MudPie
MudPie's Avatar
Quoted: 114 Post(s)
Liked 119 Times in 92 Posts
How are the conditions of the brake cables and housings?
MudPie is offline
Old 06-15-20, 04:58 AM
WorldIRC
Canadian eh?
Quoted: 131 Post(s)
I don't imagine they're the issue. Like I mentioned modulation and contact to the bike appears good and immediate. No squishy or gunky feeling.
WorldIRC is offline
Old 06-15-20, 06:41 AM
AeroGut
Quoted: 254 Post(s)
Liked 182 Times in 141 Posts
Is it possible that something that is different between the bikes is affecting your perception of how the brakes are working? Maybe there's a more noticeable weight transfer to your hands on the trek so it feels like you're stopping more quickly?
Alternatively, the noise from the cannondale brakes might be causing you to react by releasing some pressure (ie letting up on the lever a bit) without thinking about it.
Certainly a hard problem to diagnose over the internet.
AeroGut is offline
Likes For AeroGut:
Old 06-15-20, 11:31 AM
WorldIRC
Canadian eh?
Quoted: 131 Post(s)
Appreciate the insight. Maybe I'll have my LBS take a closer look when things quiet down a bit. Nothing urgent.
Thanks for everyone's help
WorldIRC is offline
Old 06-15-20, 07:30 PM
zacster
Bikes: Kuota Kredo/Chorus, Trek 7000 commuter, Trek 8000 MTB and a few others
Quoted: 22 Post(s)
Liked 459 Times in 361 Posts
The Cannondale is the newer bike with the "better" brakes but doesn't work as well. Hmmm, sounds like maybe the older bike had an upgrade, or a pad replacement? I have a bike where the braking sucked for years. They were Campy record brakes and Modolo Kronos levers. I always thought it was just the poor design of the first aero type levers, but when I replaced the pads when I resurrected the classic Italian bike they were on suddenly I could brake again. Now the issue is that rubber hoods are unobtanium. I've tried a few things but nothing really works well. If I had the Campy levers I'd use them but the bike was built with the Modolo. In any case, bad pads can cause really bad braking. They aren't expensive and if you don't know the age maybe assume they are old and dried out.
And now that I'm talking about it maybe I need to take the Zilioli for a spin. I think I need to check the wheels, or maybe just swap on my modern Eastons for a ride. I believe the front has a Clement Criterium Seta mounted on it, another piece of unobtanium. Not sure I would trust it though. As far as I know there is only one other Zilioli bike in the U.S.
zacster is offline
Old 06-20-20, 08:46 AM
WorldIRC
Canadian eh?
Quoted: 131 Post(s)
So apparently some bike wash on a clean rag, cleaned the rims, cleaned the brake pads, and all is good now! Despite "looking" clean, all it appeared to need was a good wipe down.
WorldIRC is offline
Old 06-20-20, 08:51 AM
TakingMyTime
Bikes: Canyon Endurace
Quoted: 1036 Post(s)
Liked 922 Times in 539 Posts
Personally I have never thought that Shimano pads were that exceptional. I know it sounds like a lot of hype here on the forum, but ever since using Kool-Stop pads I would never go back to Shimano pads. The increase in stopping power has been quite noticeable.
TakingMyTime is offline
Old 06-20-20, 09:19 AM
WorldIRC
Canadian eh?
Quoted: 131 Post(s)
Which ones do you use? The reality is you can only have so much power before you just lock the wheel everytime.
WorldIRC is offline
Old 06-20-20, 05:59 PM
cpach
Bikes: Too many. Giant Trance X 29, Surly Midnight Special get the most time.
Quoted: 532 Post(s)
Liked 312 Times in 236 Posts
I honestly find stock Shimano pads to be very good, but given my choice I usually use Kool Stop Salmon or hybrid Pads. Swissstop FlashPro BXP is also quite nice.
cpach is offline
Old 06-20-20, 06:16 PM
TakingMyTime
Dual compound Salmon/Black. Don't take it as i consider Kool-Stop to be the best there is, it's just that personally I think they're much better than Shimano pads.
Likes For TakingMyTime:
Old 06-20-20, 06:19 PM
Davet
Licensed Bike Geek
Davet's Avatar
Bikes: Look 585, Kirk Terraplane, Serotta Ottrott, Spectrum Super Custom, Hampsten Carbon Leger Tournesol
Quoted: 92 Post(s)
Liked 69 Times in 48 Posts
I’ve used the Kool Stop salmon pads on all my bikes for years. The salmon pads give better ‘feel’ and modulation, no noise, work truly great in the wet and their wear characteristics are very good, Not at all expensive.
Davet is offline
Likes For Davet:
Old 06-20-20, 06:34 PM
delbiker1
Mother Nature's Son
delbiker1's Avatar
Quoted: 852 Post(s)
Liked 1,433 Times in 815 Posts
Another vote for KS salmon pads. However, I will say that the braking on my new 105 7000 brakes/pads is very good. That is with both Fulcrum Racing 5 clinchers and Pro-Lite Bortola 2.0 clinchers. The wheelsets are also new.
delbiker1 is offline
Old 06-20-20, 11:41 PM
lostronin
Bikes: Centurion Ironman, Soma Smoothie, Lynskey Peloton, Look 585, Colnago CX Zero
Quoted: 8 Post(s)
Liked 39 Times in 16 Posts
Shimano 105 r5800 brakes with Kool-Stop Salmon pads, Shimano r500 wheels on the Lynskey.
Shimano 105 r7000 brakes with Shimano pads, Campagnolo Zondas on the Look 585.
Better feel and stopping power with the Kool-Stops.
However, the Shimano pads are fine and I will wear them out before replacing them with Kool Stops.
lostronin is offline
Likes For lostronin:
Old 06-21-20, 11:31 AM
bikebikebike
Bikes: Downtube IX NS&FS, Dahon Speed8Pro/Matrix/Curve, Brom S2L,Montague Para, ICE-XL w/Rollie/Schlumpf, Trident Spike, ebikes, BFSatRDay
Quoted: 172 Post(s)
Liked 95 Times in 81 Posts
i really wish that pads came with an "expiration" date, esp "new"ones.
They age and get overlooked
'"They still have meat on them"
Um, is not the right answer
bikebikebike is offline
