Go Back  Bike Forums > Bike Forums > Fatbikes
Bike to start with to upgrade later with a 25-30# upgrade weight?
Fatbikes Designed for use in sand, mud or snow, Fat bikes are the right choice for true all-terrain riding. Check here for the latest on these fun, adventurous two-wheeled machines.
Old 05-25-20, 11:11 AM
tammons
Quoted: 46 Post(s)
Liked 3 Times in 3 Posts
Bike to start with to upgrade later to a 25-30# upgrade weight?
Dont want to spend a fortune right now.
Would prefer to upgrade as I go.
Or I should build it from scratch = expensive?
How about a steel frame?
Would that work into 30#? I know it would be heavier.
Or should I start with an Aluminum or Carbon fiber frame?
tammons is offline
Old 05-25-20, 08:58 PM
HerrKaLeun
Bikes: Giant Toughroad SLR1 and Motobecane Sturgis NX
Quoted: 900 Post(s)
Liked 231 Times in 168 Posts
Light fatbike will be expensive.
Steel isn't the best material if you want low weight.
HerrKaLeun is offline
Old 05-26-20, 07:49 AM
qclabrat
qclabrat's Avatar
Quoted: 257 Post(s)
Liked 70 Times in 63 Posts
Light, Quality, Cheap... pick two as they say.
Your best choice is to pick up a used Fatboy or Farley in aluminum. Wheels will make the biggest weight difference and most expensive as well..
qclabrat is offline
Old 05-26-20, 08:53 AM
tammons
Quoted: 46 Post(s)
I have no problem with used. And I am in no big hurry.
Now, after finishing 2 (rat type bikes) and having a fair amount of sand around here, I think I would like a fat bike.
How about 30#? What type of $ am I looking at there to do a build from a used frame?
Looking around the internet, I had no clue you could drop $1k on a lightweight decent set of wheels.
tammons is offline
Old 05-26-20, 04:52 PM
qclabrat
qclabrat's Avatar
Quoted: 257 Post(s)
That was for 30 lbs option. To go 25, you're looking at carbon. Decent fat wheels are starting at 1k. Btw, it's a fat bike, if you don't race 30 is just fine. It gets expensive dropping each pound after you get the first 3-4 off.
qclabrat is offline
Old 05-26-20, 05:09 PM
tammons
Quoted: 46 Post(s)
So, how much would a 30# fatbike build cost, roughly.
tammons is offline
Old 05-26-20, 08:48 PM
HerrKaLeun
Quoted: 900 Post(s)
$2000 would give you a really decent fatbike if you build it yourself with CF fork and rims.
The Canyon Dude used to be available here. That was a bit over $2000 and weighed 13kg or so. But only had 4" tires (one way manufacturers save cost and weight)
Old 05-27-20, 12:44 AM
Happy Feet
Happy Feet's Avatar
Quoted: 2236 Post(s)
Liked 1,314 Times in 707 Posts
My older Aluminum Spesh fatboy comes in stock at about 34lbs. To drop some weight easily one could go with lightweight, tubeless tires and carbon seat post/bars and add lighter saddle/pedals.. That should get you roughly to 30lbs but I don't think it will make a huge difference overall. The tubeless light tires probably will though.
After that it's only expensive wheelsets.and CF frames left to work with.
To get really creative, one could drop the whole drivetrain and go fixed gear fatbike! The cassette, shifters and derailers have to account for something.
Happy Feet is offline
Old 06-08-20, 09:58 AM
c_m_shooter
c_m_shooter's Avatar
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times in 166 Posts
Weight doesn't matter that much. Go ride more.
c_m_shooter is offline
Likes For c_m_shooter:
Old 07-11-20, 04:51 PM
Kapusta
Advanced Slacker
Kapusta's Avatar
Quoted: 2762 Post(s)
Liked 2,537 Times in 1,433 Posts
IMO, If your wishlist starts with - and revolves around - weight, your doing it wrong.
Start with:
4” or 5” tires?
26” or 27.5” wheels?
Rigid or suspension fork?
Tires for mud/snow or smooth trails?
Dropper post?
Then see where the weight ends up.
Kapusta is offline
Old 07-23-20, 01:02 PM
revcp
Bikes: 2017 Salsa Carbon Mukluk frame built with XT, 2018 Kona Rove NRB build with Sram Apex 1,2008 Salsa El Mariachi, 1986 Centurion Ironman
Quoted: 286 Post(s)
Liked 100 Times in 65 Posts
Look used. Last Sunday I picked up a 2017 carbon Beargrease ridden twice for $950. Even with stock wheelset--My Other Brother Darryl aluminum--with tubes, it's about 28 pounds. Unless you race, a carbon wheelset for a fat bike is expensive bling.
Don't complain about the weather and cower in fear. It's all good weather. Just different.
revcp is offline
Old 10-06-20, 06:56 PM
xseal
xseal's Avatar
Quoted: 34 Post(s)
Liked 46 Times in 25 Posts
Trek 9.6 Farley.
xseal is offline
Old 10-12-20, 05:47 PM
Toadmeister
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times in 170 Posts
If it’s your first fat bike, consider an alumnim frame for lower cost while being light enough.
Toadmeister is offline
Old 10-14-20, 10:17 AM
prj71
Quoted: 2976 Post(s)
Liked 1,182 Times in 771 Posts
Upgrading to make it light will always cost you more in the long run.
Just spend the money right away. Sheesh.
prj71 is offline
