Cassette, Freehub, Freewheel
Old 08-07-20, 06:49 AM
taylorgeo
Quoted: 115 Post(s)
Liked 25 Times in 20 Posts
What the hell is the difference? And what the hell is sturdiest?
taylorgeo is offline
Old 08-07-20, 06:56 AM
Phil_gretz
Zip tie Karen
Phil_gretz's Avatar
Quoted: 1465 Post(s)
Liked 1,542 Times in 806 Posts
Here you go...
https://www.sheldonbrown.com/free-k7.html
Phil_gretz is offline
Old 08-07-20, 06:58 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3580 Post(s)
Liked 3,391 Times in 1,927 Posts
Perhaps this can help:
tl;dr version: freewheels are old technology, and not as strong or reliable as a freehub/cassette system when the number of sprockets on the rear cluster is greater than seven.
JohnDThompson is offline
Old 08-07-20, 09:13 AM
70sSanO
70sSanO's Avatar
Quoted: 1942 Post(s)
Liked 2,162 Times in 1,321 Posts
Basically a freewheel is a carrier, body, with the gears, cogs attached, that simply screws onto the rear hub. The entire assembly, with ratcheting pawls, is installed and removed.
A freehub has the carrier, body, attached to the hub and a cassette, (gears/cogs) slides onto it. Only the cassette is replaced.
Since the question is being asked, I’m assuming you have, or are looking at a 7 speed, maybe 8, bike.
What is funny is that for all venerable 7 speed setups out there, 7 speed freehubs were so short lived, only 6 was less. They were only around for a few years. As far as I know, no one has made a 7 speed freehub for 25 years. Note: All new 7 speed bikes are freewheels that are not as strong and usually lower quality.
Ironically 8 speed freehubs have been around for decades. The 8 speed 130mm/135mm freehub accepts 9 and 10 speeds without modification so it just kept rolling along.
John
70sSanO is offline
Old 08-07-20, 09:22 AM
Wildwood
Veteran, Pacifist
Wildwood's Avatar
Quoted: 3895 Post(s)
Liked 4,821 Times in 2,226 Posts
A freehub with cassette is stronger than a freewheel.
Both should be stronger than your legs.
Wildwood is offline
Old 08-07-20, 09:36 AM
woodcraft
woodcraft's Avatar
Quoted: 1814 Post(s)
Liked 923 Times in 569 Posts
A freewheel is often stronger than the tool needed to remove it.
woodcraft is offline
Likes For woodcraft:
Old 08-07-20, 09:54 AM
70sSanO
70sSanO's Avatar
While mountain bikes didn’t usher in freehubs, they were the primary benefactor. A rider on smooth roads usually didn’t have any issues.
Put that same rider on terrain with rocks, roots, and drops and that axle doesn’t fare so well. Legs have nothing to do with it.
John
70sSanO is offline
Old 08-07-20, 03:39 PM
RiceAWay
Quoted: 325 Post(s)
Liked 112 Times in 81 Posts
Originally Posted by Phil_gretz
The brunt of the matter is that there is a longer wheel axle on a freewheel which increases the load on the axle and bearings. I don't remember ever having one fail but certainly I've never had a freehub fail from anything less than wicked overuse.
RiceAWay is offline
Old 08-07-20, 04:32 PM
wolfchild
Quoted: 4227 Post(s)
Liked 2,488 Times in 1,286 Posts
I removed singlespeed freewheels many times. It's important to use the proper tool that is compatible with the type of freewheel that you're removing and as long as everything is set up correctly it's shouldn't be a problem. The biggest mistake that people make is, they don't put enough grease or no grease at all on the threads when installing a new freewheel or they not using the removal tool correctly.
wolfchild is offline
Old 08-07-20, 04:37 PM
wolfchild
I know it's not for everybody but a fixed gear track cog is the sturdiest, most durable and longest lasting of all, there is nothing to break or go wrong with it. The second most durable thing is a singlespeed freewheel, it will outlast any freehub cassette or multi speed freewheel.
Old 08-10-20, 08:12 AM
Phil_gretz
Zip tie Karen
Phil_gretz's Avatar
^ this is not a universally true statement. It ignores all things related to quality in both design/material selection and manufacturing. I can't even fathom why anyone would believe this.
