What is this brake called?
Just got a made in Japan Cobra road bike and this is the first i have seen these brakes with an uncommon brake pad. Please shed some light on my dark tunnel! I paid $30 for this find.
They are just inexpensive cantilever brakes. If you are trying to replace the pads, they might come apart when removed and allow you to find/replace pads only. If not you will probably need to scrounge a different pair of canti brakes from somewhere that mounts the pad a little more traditionally.
1984 Cannondale ST
1985 Cannondale SR300
1980 Gary Littlejohn Cruiser
1984 Trek 760
1981 Trek 710
Pics
1984 Cannondale ST
1984 Trek 760
1981 Trek 710
Pics
Quoted: 811 Post(s)
Liked 1,024 Times
It is called very interesting. That looks like a late 70's to perhaps early 80' bike to me, based on the crank, color, derailleur and brake levers. Cantilever brakes were not common at that time. The brakes themselves look like steel. For a bike manufacturer to go to the effort of brazing the studs for brakes in this era for a lower end bike is interesting. Then again, I believe that Japanese companies are always looking for something to give them an edge.
I am just guessing at all of this, T-Mar or someone else may know exactly that brake caliper that is and when it was produced.
Likes For Velo Mule:
Interesting/cool...feels more '70s than '80s to me.
The cantis are unbranded, so unless somebody has a good eye for '70s Japanese entry-level unbranded components, they won't be easy to ID.
Brake shoe attachment is definitely different/weird, can't recall seeing that kind of brake shoe holder>brake arm interface before. Best bet is to find a replacement shoe that fits the holder, if possible. Otherwise, if you want it to be rideable, you'll likely need to replace the cantis. The boss>boss spacing is likely narrow, so you'd need either vintage wide-profile cantis, or modern repro/clones. Low-profile canti arms or mini-v won't work well.
Looks like the stamped rear dropouts were pressed in place, clamping/crimping the stays to hold the dropout in place, then brazed? Squished stay ends are pretty common on entry-level, mass-market frames, I've seen 'em often, but never really thought about how they work...
Fuggedaboutit!
Fuggedaboutit!
Likes For pcb:
Quoted: 3813 Post(s)
Liked 3,345 Times
possible brakes may be from Yoshikawa
not all of their parts are marked
if the levers exhibit a little fish marking that would be it
chainset is Takagi
frame's bulge-formed head is likely from Nikko Sangyo
this looks to be an all Shimano keiretsu machine
date is close to 1970
chainset is Takagi
Likes For juvela:
chainset is Takagi
chainset is Takagi
Liked 3,345 Times
thank you for the additional pictures.
fine job with the photos!
the Union pedals are from Germany so they are sure to be replacements. they are a model called K10491/U41 and a bit later than the cycle.
the backside of the Takagi crank arms should exhibit markings. these may include a date.
Takagi trade publication advert of 1971:
Three Arrows is the firms logo.
Quoted: 4512 Post(s)
Liked 6,386 Times
Liked 3,345 Times
Takagi was originally independent and then was purchased by Shimano. The Takagi name was kept going and the Three Arrows symbol. Do not have a date for the ownership change. Many lower-to-mid model cycles which are Shimano equipped come with Takagi chainsets.
Quoted: 4722 Post(s)
Liked 3,038 Times
I've seen this brake several times but have been unable to determine the brand. While Yoshikawa is a definite possibility, so is Buffalo/Cherry and about a half dozen other, lower tier, Japanese brands that were favoured by marketing brands due to their lower pricing.
As for the bicycle itself, this particular version of the Lark rear derailleur suggests circa 1969-1971. The frame serial number may also provide some insight.
logo
All cleaned up and tuned, new cables, new bar tape, and new gumwalls. Gonna flip it now!
Liked 3,345 Times
thank you for the additional photos
in the "completed" image we can see that the crankrms are several degrees out of registration
cotters need to be seen to
what marking are you able to read on the cycle's hub barrels? 3 - 3 - 3? S.I.W.? Chair?
Last I heard, it was called a can't believe her brake. What a ridiculous name.
Jokes aside, it's a cantilever, but a very unusual one.
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,055 Times
That's a quintessential Canadian department store bike from the 70's. Instantly recognizable and forgettable at the same time.
Liked 3,038 Times
Yes, it designates the "Front" lever, as opposed to the "Rear". One company which used the F and R within a circle was Yoshikawa, as previously mentioned by juvela. Typically, the levers were stamped with the company name at top and an alpha-numeric date code underneath, followed by the F or R designation. If they didn't use the full name, sometimes you'll find their YSB trademark or fish logo somewhere on the brakes and/or levers.
Edit: Any luck with finding a serial number on the frame? TIA.
Likes For T-Mar:
Liked 3,038 Times
