Hood Options for Dura Ace Levers?
Quoted: 469 Post(s)
Liked 2,442 Times
I'm going to assume that Cane Creek hoods will fit these brake levers. Is there any other hood that would work on this?
Ride, Wrench, Swap, Race
Quoted: 1562 Post(s)
Liked 1,286 Times
I've used Cane-Creek hoods on the early Shimano levers, the fit is ok although the front edge at the roughly 45-degree angle is off a bit, thankfully hidden from view.
As with any hood swap, be prepared to relieve the bottom front of the hoods to allow free lever movement (check this before connecting the cables!).
Also, note that CC hoods should never be rolled back while installing the bar tape, as they have a tendency to split if this is done.
This seems to be due in part to the added thickness of the top surface, which more strongly resists bending sharply.
Simply lift the edge of the hood as needed while wrapping around the levers to get the tape under the hoods.
Basically it's the same as when taping the bars around aged hoods, where a thin tool like a screwdriver is often best at lifting without stretching the hood too much.
Likes For dddd:
aka: Dr. Cannondale
Quoted: 2152 Post(s)
Liked 3,401 Times
Yes!
EBay seller cyclingcolors_france sells excellent repops in black, white and brown. A little plastic-y, but fit properly and last well.
Cheap, too, like $14 shipped. Takes a few weeks ro arrive.
Likes For rccardr:
Quoted: 1372 Post(s)
Liked 1,748 Times
I test ride my bike(s) before doing a final tape job...
When satisfied with where the levers should be left, I use PVC tape (the plastic electrician's stuff) to hold the lever mounts in position. Then, with the lever body removed, I just wrap away, getting a perfect job, or darn close to it, every time. Try getting a good wrap when using Mafac half hoods.
They are a PITA to wrap under but a SNAP (simply not a pain) when the lever bodies are not in the way. Once wrapped, just bolt the lever body back into place...
Likes For randyjawa:
verktyg
Quoted: 1036 Post(s)
Liked 1,237 Times
Hoods and Bar Tape
That's a 1972 or 73 Gitane Tour de France. My almost all original 1971 TdF, even plastic factory bar tape:
I ride the bike a little while without tape too!
I like this old timey way of wrapping Mafac levers:
Roger M
As far as hoods for 1st generation Dura-Ace levers, while I haven't tried installing Cane Creek/Dia-Come or Weinmann hoods yet, from close in hand examination, they look like they'll be a close match.
verktyg
Though I have never used CC hoods, the advice above is good and should be seen as a warning. I used to stress every time I had to wrap a handlebar, hoping to avoid damaging the hood (I tend to go original as opposed to repo). But I found a much much better way to do this, being forced to consider an alternate (better) way to tape under the hoods.
Roger M
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
Quoted: 469 Post(s)
Liked 2,442 Times
Thanks Doc. At that price, it is an easy decision. I'll try to post up my comparison between these and the CC hoods when I have both.
Quoted: 469 Post(s)
Liked 2,442 Times
Roger M
verktyg
Roger M
verktyg
Quoted: 469 Post(s)
Liked 2,442 Times
I bought it a couple of months ago at an estate sale. As verktyg mentioned, it's a 1972 Gitane Tour De France. Here's the thread on it.
https://www.bikeforums.net/classic-v...some-time.html
And what it looks like today
aka: Dr. Cannondale
Liked 3,401 Times
“Thanks Doc. At that price, it is an easy decision. I'll try to post up my comparison between these and the CC hoods when I have both.”
Just make sure you get the cheap ones if he still has them in stock. Worth asking. The more expensive ones described as ‘rubber’ are a nicer material but really not as good a fit.
I think the cheap ones are the only ones he had in all three colors, the rubber ones (which fit Record or later DA 7400) were black or gum only.
Likes For rccardr:
Quoted: 2323 Post(s)
Liked 4,936 Times
I just got 3 sets of hoods from him after seeing this. Put the one set on a set of Shimano 600 levers and just had to trim a bit off at the bottom so the lever could move freely. Seem pretty nice to me. Surprisingly I got new hoods in about a week. Really wasn't expecting them that quick.
Steel is real...and comfy.
Liked 1,286 Times
Can you post a photo or two? Thanks.
