Lugged Carbon Frames
They are out there, classic lugged and variations on that theme of tube-to-tube.
The Colnago C40 was perhaps one of the top five most important bikes in cycling history. It continues with the brilliant C64.
My prediction is that lugged carbon frames come back, and there are many reasons for this.
From an engineering standpoint they are superior.
Ciao
Ciao
Quoted: 7069 Post(s)
Liked 11,142 Times
Ciao
Ciao
Likes For Koyote:
Don't be so hard on yourself. You will see Specialized and Trek introduce carbon lugged frames within the next two years. Remember where you heard it.
There are advantages to this approach from a manufacturing standpoint, besides the superiority of the design.
Have you ever ridden a C Series Colnago? Or even seen one?
Quoted: 1514 Post(s)
Liked 735 Times
If we do, we do; but I'm not holding my breath. One advantage of carbon as a frame material is that you can engineer it to have specific qualities in different areas. You give that up if you go to round frame tubes. The first carbon bikes were lugged round tubes and they were reported as 'whippy.' Or are you talking about massive lugs and non-round tubes?
Quoted: 1953 Post(s)
Liked 2,192 Times
It is old technology so I can’t see a Specialized or a Trek making the kind of investment for such a high priced frame (C64).
I would think the major frame mfg’s are looking for advanced dampening systems and more adjustability in geometry.
For me, it is not unlike modern sports car handling and suspensions in that the driver/rider gets all the feedback and feeling attached to the road without the harshness.
John
John
Likes For 70sSanO:
Liked 3,036 Times
injection molding composites to a digitized profile is more likely to happen.
-Oh Hey!
-Oh Hey!
Likes For Troul:
Quoted: 3982 Post(s)
Liked 7,433 Times
Quoted: 1584 Post(s)
Liked 1,754 Times
What advantages does it have? The only advantage is it's cheaper for a small time frame-builder to build a custom frame using carbon tubes and lugs. Aside from that I see no advantage and plenty of disadvantages- like the glue coming undone a few years down the road. The other problem is that when carbon comes in contact with aluminum or steel, it causes galvanic corrosion. So inherently it's not a good combo.
Likes For icemilkcoffee:
Liked 3,036 Times
Liked 11,142 Times
And I'm guessing that "digitized profile" is just a fancy way of describing a cad/cam process, but not sure.
Even if it is a longshot, it's probably more likely than the OP's prediction.
Quoted: 645 Post(s)
Liked 797 Times
Ciao
Ciao
Liked 3,036 Times
The thing I dislike about most CF bikes is that they're so "big" - fat frame members, huge BBs - they just seem to occupy so much space. In contrast, lugged CF frames look like standard tubed frames, which are much more pleasing to my eye. Note that this is not a comment on how they perform - simply how they look to me.
-Oh Hey!
-Oh Hey!
I prefer the lugged look over the molded look, however the one piece carbon frame is superior in performance to the lugged carbon frames. I have had both (still have a one piece road frame hanging around) and can tell you there is a difference in weight and BB stiffness. Oddly enough, I prefer the lateral flex of the lugged ones I had before this one, and I prefer lugged steel over anything carbon. The flex in the BB works with my riding style.
Ciao
Ciao
With a mighty wind
Quoted: 1111 Post(s)
Liked 906 Times
I'm waiting for the OP to outline how lugged carbon frames are better. Does it make a bike faster, lighter, stronger, cheaper, or something else? Genuinely curious as to why the OP made his claim.
I'm not worried about the corrosion aspect, since there's no rule that says the lugs need to be metal. Injection molded (insert scientific name here).
Liked 1,754 Times
The Calfee style carbon lugs/ carbon tubes construction method was good for small time frame builders. But you are still left with an uncompressed epoxy glue joint and a heavy glob of epoxy. Contrast that to the modern dry carbon layup- it's extremely light because there is very little epoxy.
The future for small time builders is probably in 3-D printed open molds and dry carbon layup. I think the tube/lug method is a dead end.
Veteran, Pacifist
Quoted: 3910 Post(s)
Liked 4,866 Times
Calfee TetraPro ‘semi-custom’
Not sure about better today, but 20 years ago I would have absolutely agreed with you after trying Trek, Aegis, Kestrel, etc.
This one was purchased after much research and riding. The Look bikes of the day were wonderful to test ride, but even more $$$. Never got to test ride a Colnago, just as well, given the budget.
Lugged carbon, gusseted for stiffness and long term reliability. Ti BB sleeve. It has been converted to 1" threadless fork/HS, Ergo 10, with 2nd factory paint job.
ridden by G Lemond in a couple of stages.
Quoted: 327 Post(s)
Liked 265 Times
I assume the lugs would be CF too in which case there should be no issues gluing the tubes into them. I think that's how Colnagos are made.
Monocoques supposedly have all the variable layup etc but do we know that's not just marketing? Everyone talks up whatever process they're using. A round tube is actually a very good shape for a lot of things including part of a bike frame.
Veteran, Pacifist
Liked 4,866 Times
i don't mean to answer for OP, but when someone tells me = "It's better", regarding a bike - that usually means their hands, feet, or buttocks liked it more. Or some combination of same.
We all have different bodies, experiences and expectations.
Just 4 the record.
The only absolutes are:
Early Ti was noodly
Early Al was stiff and harsh (with 20-22mm race tires)
Early monocoque rode like dead wood between your legs
There are no 'ride quality' experts.
N+1 = the only road to cycling's 'true enlightenment'.
Next year's bikes will be faster, better and improved. But don't quote me about Why.
If the shifter is not on the downtube, it can't be called vintage or classic.
The ride is only as fast as the engine/transmission, the frame has almost nothing to add.
Beauty is in the eye of the beholder, not the shape of the thing.
My bikes are better than your bikes, if not better then more numerous, if not better or more numerous then all bets are off and I respectfully&quietly listen to you.
Just 4 the record.
Early Ti was noodly
Likes For Wildwood:
Randomhead
Liked 3,723 Times
Lugged carbon is never coming back. People are still building ti/carbon hybrid frames and tube on tube carbon frames. I want to say the last carbon lug has already been made, but all ideas get recycled.
Likes For unterhausen:
Quoted: 1624 Post(s)
Liked 2,656 Times
