Ok, take it easy on me, "What's wrong with the Dork Disc"?
Bikes: 2011 ICE Sprint Special Edition
Quoted: 35 Post(s)
Liked 101 Times
I seem to be "uninformed" on WHY, it's a faux pa to have the "so called", Dork Disc on the rear wheel!! I thought it was there to keep the "chain" from over riding the largest cog, so you all are saying, "it's not needed"?? So I take it that you all are saying that the "derailer" never goes so far out of adjustment that the chain can't override the largest cog?? If it's not needed, why does the mfg'er. of every bike made it seems put one on?? I'd like to be "enlightened" so let me know, thanks!
Take Care, Ride Safe, have FUN! :)
Jo: 2009 ICE Trice T
BJ: 2011 ICE Sprint Special Edition
Time for a change.
Liked 5 Times
Removing the Dork disk removes excess weight from the rear wheel and improves your uphill speed by 2mph.
It is put on the Prolls bikes so that they do not show up the club racers who will take it off to reduce the weight of the bike and improve overral speed.
Spike Milligan
Spike Milligan
Likes For stapfam:
Veteran, Pacifist
Quoted: 3876 Post(s)
Liked 4,781 Times
Nothing but a "perceived upgrade in appearance" without it. Mind you that perceived value increase is greatly diminished if the chain (or derailleur) shifts into the spokes. An extra few ounces at/near the hub is negligible for most of us.
Bikes: Eddy Merckx San Remo 76, Eddy Merckx San Remo 76 - Black Silver and Red, Eddy Merckx Sallanches 64 (2); Eddy Merckx MXL;
Quoted: 143 Post(s)
If you keep up on the maintenance of your drivetrain, shifting into the spokes is greatly minimized making the ugly disc unnecessary.
ES&D
Bikes: 3Rensho, Merlin XL, Melton custom, Michael Johnson tandem, Look 481SL, Pedal Force RS
OK, back when some of us were teenagers (and others post-teenagers) the (average) rear derailleurs weren't necessarily the most precise shifting piece of equipment on your pride and joy, so if the monkey behind the wrench at your LBS (who was usually the lowest paid guy there) put it together half-assed, there'd be a chance that the chain would go into the spokes, chew them up, and eventually you'd have really annoying wheel issues down the road. Oh, and back then, the dork disk/pie pans were usually made of steel, so they weighed a bit more than the plastic ones you see now, so removing it took at least a few ounces/grams off your overall bike weight.
Fast forward three decades or so, and nowadays most rear derailleurs are pretty spot on with their shifts, assuming it's not grossly mis-adjusted, and the disks are probably light enough/clear enough that it doesn't take away from the appearance of the bike, so it doesn't really matter if you keep it on or take it off or whatever. But...
The original bottom line, IMO, is if I see a disk on a bike, is it on there because the derailleur's not properly adjusted because if it was, it's an unnecessary piece of equipment. After all, do you see any of the pros riding with them?
Liked 6 Times
This is more aligned with my experiences. The group of riders I grew into cycling with some 35 years ago always felt that no self-respecting cyclist would have this, because "By God, we can take care of our own bikes and ALWAYS have them adjusted correctly." The "pie plate" as we called it then was a sign that you couldn't take care of your own mechanical work.
A conclusion is the place where you got tired of thinking. - S. Wright
Favorite rides in the stable: Indy Fab CJ Ti - Colnago MXL - S-Works Roubaix - Habanero Team Issue - Jamis Eclipse carbon/831
Location: Colorado-California-Florida-(hopefully soon): Panama
Bikes: Vintage GT Xizang (titanium mountain bike)
Yeah, and newbies to bikes also leave on those front, rear and spoke reflectors. And they always wear helmets and knee protectors.
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
I took the dork disk off my first 10-speed because I thought it looked better that way. I'm currently reviving an old tandem which has a plastic d.d. The rear hub uses such a large spindle that my freewheel remover won't fit over it. I didn't think to pull it when I re-lubed the bearings. So unless I want to pull the rear wheel off the bike again, a non-trivial task, and pull the spindle out again, the d.d. will stay where it is.
Real cyclists use toe clips.
jimmuller
jimmuller
Desert Rat
Bikes: GT Timberline (1990?), Trek 1100 (199?), Giant OCR3 (2007)
I don't see what difference it makes whether it's on or off. I have one bike without it and two with it.
Do people really think I don't do my own maintainace because I have it on the bike? How dumb is that?
Likes For Makeitso:
People who care about riding bikes won't notice if you have one.
People who care about appearing as if they care about biking will snicker.
Likes For mulveyr:
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
My Cannondale has a small minimal disk and it is staying on. I don't feel the need to please anyone but myself when it comes to my bike. I have had a chain over ride the large rear sprocket after a crash put the derailuer out of adjustment and lacing wheels is time consuming when the spokes get torn up from the chain. To each his or her own.
Bill
Bill
Semper Fi, USMC, 1975-1977
Likes For qcpmsame:
Gearhead
Bikes: 1982 Schwinn Sidewinder, Sun EZ-1 Recumbent, Cannondale R-400
Quoted: 7 Post(s)
Liked 10 Times
I've never removed them from any of my bikes that had them. It's more trouble than it's worth. Elitists used to scorn such things as 'safety' brake levers and stem mounted shifters as well, but I rode with them since the early 60s, and still have a bike with them (a great vintage Motobecane). They work fine, and I've never had any issues with them.
It's more about perception, than reception....
Semper Fi. Oough Rah!
3/5 Phu Bai, RVN 1969-1971
Likes For Schwinnhund:
Life is good
Bikes: 2018 Lynskey Helix Pro
Quoted: 522 Post(s)
Liked 10 Times
If the limit screws are adjusted correctly and you don't ever screw with them (no pun intended), then the dd isn't needed. Unfortunately many newbies think those screws are some kind of an adjustment for fine tuning the shifting.
Bikes: Trice Q; Volae Century; TT 3.4
It's only a faux pas in the mind of posers desperate to imagine themselves superior to some being other than their parents' dog. Many of their parents don't buy that notion of the family hierarchy making the situation dire and spiking the scorn levels.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1102 Post(s)
Liked 2,136 Times
That's it. The limit screws keep the chain from going too far. Now if you ride a bike without proper maintenance (chain gets gunked up, no lube, stretched, cables not adjusted, etc.), it's maybe a concern. IHaving one doesn't really distract from the bikes performance that much but it does send the message that the rider doesn't do a lot of maintenance.
Erect member since 1953
Bikes: Trek 520 Grando, Roubaix Expert, Motobecane Ti Century Elite turned commuter, Some old French thing gone fixie
Quoted: 121 Post(s)
Liked 38 Times
Nothing wrong at all.
If you're a dork.
If you're a dork.
Bikes: Cervelo Prodigy
Quoted: 475 Post(s)
Liked 87 Times
Liked 645 Times
I've never seen a sig in BF that read "I like dork."
jimmuller
jimmuller
just keep riding
Quoted: 173 Post(s)
Liked 33 Times
They look dorky.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12636 Post(s)
Liked 7,528 Times
Nothing wrong with dork discs in my opinion. After 10 years or so they'll usually crack and start rubbing on the cassette, then it should be removed or replaced.
They are one more attempt to make the modern bicycle idiot-proof, much like the "lawyer lips" on fork dropouts. When slobs pedal, they do NOTHING to maintain their bikes, and thus experience rear-wheel-chainsuck from running their garbage into the ground.
I prefer the term I read several years ago -- it's what my co-worker/riding bud and I call them at work -- from MOUNTAIN BIKE magazine; they had a column called "Uncle Knobby", kinda like dirt's version of "Style Man". A reader wrote in, lauding the 'coolness' of the DD, asking where he could get one, as his bike didn't have it. Knobby told him to go to any LBS and ask for a "big wedgie"...they always have them in stock, never run out, and always a good price.
So, at my place of work, they're called "big wedgies". Every 6- and 7-speed freewheel-equipped bike has one.
rebmeM roineS
Quoted: 653 Post(s)
Liked 345 Times
If you don't really know what it is, then it is best to leave it on.
If you understand what it is and have the ability to keep things in proper adjustment, then take it off.
There used to be some really heavy chrome-plated steel ones which were great for helping get up to speed downhill.
If you really are a dork, then you are obligated to leave it on.
