Gah.. Shimergo Surprise!
Chainstay Brake Mafia
Quoted: 16 Post(s)
Liked 11 Times
Just wanted to vent.. after spending a pretty penny on some 9sp Campagnolo Veloce shifters/brakes I discovered today that they only work with Campy brand cables and housing... which cost $50 a set. The generic housing which I have a ton of and get for less than $10 a bike from the LBS won't fit, and neither will the $30 jarwire stuff The price to avoid Shimano's ugly alien octopus brifters is pretty darn high..
Your situation reminds me of the old days when,,,,
...we had to pay a hefty markup at the Schwinn dealer because only Schwinn tires would fit their s2 rims. We vented then too!
Quoted: 16 Post(s)
Liked 11 Times
doing a little more research it might be possible to get away with using housing other than campy brand.. it's mostly the housing ends that are campy specific. i dunno though, might just bite the bullet and go for the campy cables
Good luck
It's a bit easier today to find generics. Back then, nothing but a Schwinn tire would fit a Schwinn rim, and believe me we tried to find alternatives because coaster brake skids really wore them down quickly.
Quoted: 16 Post(s)
Liked 11 Times
yeah, looking into it more it's not as much of a big deal as i first thought, but still seems i gotta get at least campy ferrules which means paying like $10 for a few bits of aluminum
Quoted: 16 Post(s)
Liked 11 Times
actually, maybe i spoke too soon or misunderstood something I read earlier, as i just tried some stock housing and had no problem putting it in the campy shifter. the shifters came with one campy ferrule and the housing doesnt fit in the ferrule but it fits in a stock ferrule
i was shopping for jagwire "Racer" housing and read it wasnt campagnolo compatible which made me confused. I think maybe the older campy stuff used more generic housings? i dunno... glad it looks like i can use stuff I have on hand, or the fancy colored jagwire stuff
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
I have Veloce 9 speed ergos on one bike, running a Shimano 8 speed cassette and derailleur, so a classic Shmergo setup. I most definitely did not buy campy cables, nor even campy specific, and it works fine. I think I had to do a little work on the cable ends with a file, if memory serves. Whatever it was, that I had to do, it was, not enough of a hassle for me to remember it now, two years later.
www.rhmsaddles.com.
www.rhmsaddles.com.
Quoted: 16 Post(s)
Liked 11 Times
Ride, Wrench, Swap, Race
Quoted: 1562 Post(s)
Liked 1,287 Times
Yeah, no problem using generic housing with Ergo levers, as long as the right size of ferrules (i.e., normal ferrules) are used with the particular housing. Easy to get flummoxed by Campag's 4.5mm shift housing though.
Quoted: 7346 Post(s)
Liked 2,452 Times
What's different about the Campy ends?
Bikes: 1997 Rivendell Road Standard 650b conversion (tourer), 1988 Schwinn Project KOM-10 (gravel/tour), 2013 Foundry Auger disc (CX/gravel), 2016 Cannondale Fat CAAD 2 (MTB/winter), 2011 Cannondale Flash 29er Lefty (trail MTB)
Quoted: 167 Post(s)
Liked 5 Times
Quoted: 378 Post(s)
Liked 1,409 Times
I can relate to your initial dismay, however. On a set of new 2011 Veloce shifters, I used a Jagwire Race kit, thinking it would be fine. As such, a bike swap relegated me to trying to get the cable out of the shifter, with the ends stuck in there. I ended up taking the shifter apart, cutting the cable off, removing the coiled spring, and then forcing the end out by pushing it from the cable side with a needle-noze pliers. Then, of course, I had to re-assemble a new Veloce shifter that I'd never had apart before. Let's just say, I learned a lot during that 2-hour session, and used words that, although not new, were certainly not in my normal vocabulary. Silver lining: at least now I know how to disassemble that part of a Campy shifter. On the re-coiling of that spring, it appears that I coiled it one more turn than OEM, but the levers "return" quite well, so everything is hunky.
Liked 2,452 Times
Thanks, Tim. So as long as you can find a ferrule that fits, then there are no concerns about the housing?
Quoted: 113 Post(s)
Liked 16 Times
I file sram ends to fit. I like sram 1.1 cable best... smoothest.
1 Super Record bike, 1 Nuovo Record bike, 1 Pista, 1 Road, 1 Cyclocross/Allrounder, 1 MTB, 1 Touring, 1 Fixed gear
Quoted: 167 Post(s)
Liked 5 Times
I confess, I spent $70 on a Campy-brand full cable kit for my Giordana (8s Ergopower equipped). It came in white, fit perfectly, and has little gold "Campagnolo" script on the housing. I'll spend a bit more for aesthetics sometimes.
Quoted: 28 Post(s)
Liked 60 Times
I took the other compatibility approach and drilled out the hole in my campy ergo shifter that the cable end sits down into so that a standard size cable end will fit. 20 years later, same ergo shifter is working fine.
Quoted: 16 Post(s)
Liked 11 Times
oh maybe this is what people were talking about.. it looks like 5mm shifter housing will fit into the levers but i guess I need to get campy specific shifter cables or grind down the cable end.
Quoted: 16 Post(s)
Liked 11 Times
so i checked all the shifter cables i have here and they all seem to fit the campy shifters just fine.. i even see a little C on them. I guess the generic stuff just uses the smaller campy size since it will fit both campy and shimano. It does make me wonder about the jagwire racer cables though.
