cassette and freehub help
I'm not up on this stuff, so I need some help. I bought a set of wheels off ebay, campagnolo hubs, and a freebody. I then purchased a campy 9 speed cassette off paceline forum. Well they dont fit, and I'm not exactly sure what the freehub body is. It doesnt thread on like a shimano. If anyone has what I need, I will trade both the shimano and unknown to me freehub for the correct campy 9 speed freehub.
This is the freehub that came on the wheels..
This is my cassette.
Semper fi
Semper fi
is what i have an 8 speed freehub?
Semper fi
Semper fi
I just found out. It is an 8 speed cassette. Now the question, will a nice speed freehub fit on the campy hub that i have and fit the cassette i have? thanks
Semper fi
Semper fi
I'm using all campy. I just showed the shimano incase someone wanted to deal.
Semper fi
Semper fi
Quoted: 28 Post(s)
Liked 60 Times
Since you already have all the parts, it looks to me that it would be possible to modify the 9-speed cassette splines to fit onto the 8-speed hub body. OD of the spline pattern is same for both, the 9-speed pattern had smaller ID so you would need to file/grind away some of the spline until it fits the 8-speed body. No idea or firsthand knowledge as to if the resulting spline would be strong enough for long-term reliability!
Looks as if a 9-speed spline pattern body swap is also possible though campy utilized different size axles and you would need to match the new body to your existing axle size, so beware that not all 9-speed bodies will work.
Short answer---no. Longer answer, it can be done, but you need an early 9s freehub, like a Veloce, which are tough to come by in good condition. That is not an 8s cassette, BTW. You may only have 8 cogs, but the spline pattern is 9s/10s.
Like I said, if you can find a very early 9s Mirage (not Veloce, bad memory) hub, you can swap out the freehub and it will fit on your old shell...maybe. Is yours a Record/Chorus hub, or lower?
Thread here: https://forums.thepaceline.net/showthread.php?t=113527
chorus. I really wasnt sure what i was getting. I didnt think their was a difference. The ebay add was listed as 8,9,10 speed wheelset.Guess i should of asked someone before i bought them.
Semper fi
Semper fi
Looks like I will either sell or trade them. Thanks for the info.
Semper fi
Semper fi
Quoted: 378 Post(s)
Liked 1,409 Times
OK, looks like a mess; if a deal goes through for me, I'll have some 9/10 Campy wheels.
I'll PM you because I'm waiting on two different parties to fish or cut bait.
