looking for a water bottle that doesn't smell like plastic...
Most of the water bottles made for cycling have that plastic smell and sometimes carries over into the taste of the water. I think the type of plastic used is meant for durability when dropped etc. but then its usually the type that smells bad. I like the clear type like the typical water bottle sold but these seem to have a life span of only a month or so.
What brands or type of plastic bottles have you all used that do not have this smell/taste?
Likes For TenSpeedV2:
Bikes: 2017 BMC Roadmachine 01 Enve wheels, Sram red etap,Cinelli Vigorelli single speed, 2009 Cannondale Capo, 2016 trek Domane 6.9, disc and Di2, 2016 Scott Scale 710, 27.5 plus tires and boost rims
Quoted: 110 Post(s)
Liked 203 Times
I have a couple of aluminum water bottles, more vintage oriented but they do not smell like plastic. Velo orange..maybe Rivendell.
eBay: Bottle Water in Aluminum Copy Peugeot Vintage Bike Old Bicycle US Model N°3 | eBay
"ready to navigate"
"ready to navigate"
aka Phil Jungels
A couple teaspoons of baking soda in a bottle full of water will get rid of the taste. Let it sit for a few days, and rinse thoroughly. Let them air dry and store open when not in use.
Quoted: 523 Post(s)
Liked 228 Times
Bottles made of PETE with the recycling number 1 do not add taste to the water even if left in the sun. That's what most plastic beverage bottles are made from. If you can bear to stop while taking a drink, a 20 oz Gatorade bottle makes a perfect fit for waterbottle cages and for the most part are free. Just rinse the bottle out with warm soapy water once a week or so. If you leave if for more than a week or two, slime mold may grow on the inside of the cap. No problem, just rinse it out.
Quoted: 1422 Post(s)
Liked 7 Times
The Purist water bottles from Specialized have some kind of coating on the inside that blocks absorbing any flavor from your drinks.
I've got a few and they're really good. The Camelbak bottles are also pretty good.
Bikes: 89 Paramount OS 84 Fuji Touring Series III New! 2013 Focus Izalco Ergoride
Quoted: 285 Post(s)
Liked 74 Times
scott s.
Quoted: 4559 Post(s)
Liked 2,802 Times
No complaints about my Polar 24 oz insulated bottle, which Polar says is made from LDPE 4. I dislike that plasticky odor and taste, but don't notice any problems with the Polar bottle.
But if I was very sensitive to any plasticky odor but was okay with disposable clear plastic bottles, I'd just find a way to make those work for me. There are disposable clear bottles of water that are a close fit for standard bottle cages, and a little tape or foam would take up any slack. You can retrofit pull-push squeeze dispenser tops. Or poke a hole in the lid with an ice pick, or drill a hole, then tape over it, wrap Saran wrap around the top secured with a rubber band, or plug it with something until you're ready to drink, then stuff the tape or plug in a pocket.
Likes For rydabent:
Non omnino gravis
Buy a stainless steel bottle.
its cap lets the air in easily so the water gets out easily, so does the Sigg
Airflow is where some metal bottles are better than others.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,173 Times
There are plenty of ways to protect a glass bottle. For impacts the one that worked well for me was to go the helmet way: rigid outer layer-softer inner layer : duct tape-bubble wrap (+ a fancy cover) or plastic bottle-bubble wrap.... . Dropped the bottle a few times with no trouble.
If i remember correctly the studies i read a few years back plastics that got the best results against heat and UV were HDPE and PP.
Administrator
Liked 2,173 Times
So the bottle with bubble wrap just can't have a diameter larger than a bottle cage?
I too am a fan of the Camelback Podium Chill. I wash them after every use and store them without the tops on.
For cleaning the nozzles all you have to do is press on the gray tab on the inside and they come off. There's a YouTube video on them.
Bikes: 2016 Specialized crosstrail comp disc
Polar.........no smell, no taste.
I leave the nozzle pulled out, so I just reach down to the cage, lift it and squeeze the drink into my mouth with one hand.
very convenient. Keeps things pretty cold, but this is Florida so.......................
yep. It's no different than an insulated bottle. You get small capacity but keep it fresh longer. With a pannier it starts to become interesting as you can bring big bottles. My most used one is a 1.1L insulated glass bottle
Bikes: Litespeed M3, Trek Fuel EX7, Giant Defy 1
Jesus. I feel like I'm the only one that just uses the $5 performance bike standard water bottle. Haha.
i bought a couple of those polar bottles. About 8 bucks each. So far no after taste.
Don't make me sing!
Bikes: 2013 Specialized Crosstrail Elite, 1986 Centurion Elite RS, Diamondback hardtail MTB, '70s Fuji Special Road Racer, 2012 Raleigh Revenio 2.0, 1992 Trek 1000
Quoted: 308 Post(s)
I have plastic bottles from Specialized, because that's what's at the LBS, and I usually end up buying another as a token purchase whenever I spend a Saturday morning in the shop just BSing. I haven't noticed a plastic taste, but it wouldn't stop me drinking the water, if I needed it!
