Is a light on a headband around a helmet safe?
Quoted: 19 Post(s)
I've got an LED light with a headband. It will fit on my bike helmet, with the headband wrapping round the front and sides of the helmet, but will this make the helmet less effective in preventing or reducing head injuries? Since this is a safety issue I am looking for links to authoritative sources to answer this question.
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
I can't imagine why it would affect how well the helmet protects your skull. if it makes drivers more likely to see you, that's useful.
Likes For mack_turtle:
Quoted: 1364 Post(s)
Liked 1,677 Times
On the one hand it may be dangerous if you hit your head on the ground at precisely the right angle (although if you think of the elastic band as a "break-away" mount, it seems like even less potential danger in a crash).
On the other hand, the light increases your visibility to other vehicles, especially since it's a high mounted light that you can swivel and point at drivers approaching from the sides.
I've worn a helmet mounted light after dark for years, but started wearing a flashing helmet light during the day on my commute last year and it has definitely made a difference in reducing harrowing interactions with inattentive drivers.
When weighing the pros and cons I say overall wearing a headlight on a headband around your helmet is safer than not doing so...especially if you ride in traffic.
Likes For BobbyG:
n00b
Quoted: 428 Post(s)
Liked 466 Times
how heavy is that light and what kind of batteries are in it? if that's what I think it is, a headlamp that takes 3x AAA batteries or AA cells is usually not very bright and the battery life sucks compared to a smaller, lighter unit that has a built in li-ion cell. the better alternatives are not expensive either. There are also bike-specific lights that probably cost the same as that one but work much better and are more easily mounted to the helmet. if that's what you've got and it's working, no need for something different, but if you want something that really works better and you have a few bucks to spare, there are far superior alternatives on the market.
does the elastic strap really make the light stay put? I would think the smooth exterior of the helmet would allow it to slip when jostled.
Quoted: 166 Post(s)
Liked 252 Times
100% liability wise I cant imagine any helmet manufacture would say that it is OK to do. the exception would be if they make the light. they don't test a helmet with a light mounted to it. if you land perfect on that light it for sure will add to the force applied to that one spot on the helmet.
with that said I do it. better to have the light, odds are strong the light will just push away from impact its not like the straps force the light to stay in that one spot.
This is more of a liability question than a safety one. IMO
Quoted: 18377 Post(s)
Liked 4,512 Times
But, I have never gotten a clear answer at how these accessories are actually tested. For example on the Bontrager helmet, would it take a direct impact with the accessory installed? Would it drive the accessory into your skull?
I've got a Lumos (V2) helmet on order with built in lights, whenever they get around to shipping it. Again, no clear indication that they chose the worst possible case for testing the helmets.
For the OP, if you do choose to use a light, I'd worry that your mount could roll the accessory down onto your face, which wouldn't be my choice. You can also mount the light using the top of the helmet vent holes. Hopefully it would still tear away in an accident, and would be less likely to end up in your face.
Likes For CliffordK:
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4390 Post(s)
Liked 3,016 Times
Likes For MinnMan:
meh
Quoted: 1110 Post(s)
Liked 1,013 Times
I know many riders that will use a camping headlamp on a strap for night riding. OTOH - I like my "see the road light" on the bike and the "be seen light" on my helmet. In the pic below, I've got an older Knog Binder light mounted through the vent in my POC helmet. This configuration is not going to compromise the helmets effectiveness and allows me to point the light while riding.
FYI - this set up in the pic was to read cue sheets in the dark during The DAMn.
Likes For 10 Wheels:
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 321 Times
I don't care what others say. IMO, it is 100% STUPID and dangerous. You think blinding drivers is a good idea?? NONSENSE.
The purpose of the light is to see the road and allow driver to TRACK your bike. In near total darkness, there is ZERO chance of this happening with only a headlight. You need to look around in every direction. Having the light zooming around like a disco ball is GOOFY. With the light up high there is NO way to properly focus down a highway either.
The light belongs on the FORK. So it points the way the wheel is going. Mine then twinkles on the spokes for a FAR better side presence.
Quoted: 2495 Post(s)
Liked 738 Times
Likes For Leisesturm:
n00b
Quoted: 428 Post(s)
Liked 466 Times
yes, having a helmet-mounted light is great for both seeing where you're going, and being seen. the helmet light is higher and more mobile, so it's much more effective than a handlebar light alone. however, on the road, it's a good idea to have a light that's easy to "direct." of COURSE, it's a bad idea to "blind drivers" with a super bright light right in their face, which is why no one would recommend doing that. nothing in this thread implies that's a good idea. (who said that blasting drivers in the eyeballs so they can't see anything is a good idea?) but a moderate light that can be pointed in the direction of a driver to get their attention is a good idea. just be considerate when doing so.
regarding the specific question in this thread though, it's unlikely that the light will hurt you any more than the impact will hurt you otherwise. if that's your concern, there are dozens of other ways to get maimed on a bike and fixating on that very specific one is not helpful.
Liked 4,512 Times
Choose light power and focus for your needs.
Moving light is likely better than stationary light.
Quoted: 590 Post(s)
Liked 445 Times
I have a typical USB rechargeable mounted to the top of the helm though the vent holes, with the rubber band style bar-mount it came with, so it should bend over or break off pretty easily. But until I read this thread, I never considered the concentrated energy impact if the light were to hit first, bt the impact would need to occur on the very top of the helm, directly onto the top of the light to do this, without the light breaking off, which is probably very rare, but not impossible in a ragdoll over-the-bars scenario, been there done that. All of the 3 dents/scuffs in my helms, from various crashes, some minor, some concussion causing, were in the "headband" zone above the ears or on the forehead area.
Liked 3,016 Times
So that's some progress and expanded perspective, right? Initially, "can't imagine" to now "(can imagine, but) unlikely"
Liked 3,016 Times
I agree with those who argue that the added risk of injury is likely small, but just as a general point of discussion, the idea behind modern bike helmets is not that they are simply padding, but rather they are designed to distribute the shock of impact in such a way as to minimize the local acceleration forces imparted to the head. Though the risk is maybe not so great, there's every reason to think that attaching something hard and high density to the helmet would interfere with the behavior expected during its design.
Likes For MinnMan:
Quoted: 347 Post(s)
Liked 418 Times
I don’t like anything on my helmet. I have visions of a light or camera getting caught in part the pavement during a fall and causing a broken neck or a screw or battery getting embedded in my brain during a serious crash. Maybe thats unfounded, but I prefer to use my brain bucket unaltered.
Quoted: 529 Post(s)
Liked 255 Times
If I did most of my riding at night, I may use a helmet light. They are good in that you can see anywhere you turn. But I do most of my riding during the day. So I use lights on my bike, and don't need extra weight on my head, with lights I don't use that often.
Quoted: 4806 Post(s)
Liked 3,929 Times
No. If you crash and hit it on the road, it will die, almost for sure. If you want your light to be safe, it needs to be inside your helmet, not outside.
Seriously - the odds to the light doing you additional damage in a crash is small. Having the light positioned so you see what is important and therefore don't crash is huge.
Likes For 79pmooney:
Bikes: nothing to brag about
Quoted: 130 Post(s)
Liked 206 Times
I commuted in pitch black for a while. I started with a handlebar mounted light, then switched to helmet. Huge difference, to be able to aim near and far, around corners, or into the face of people coming up on side streets. The other day I was riding in city traffic, and saw someone in traffic with a helmet mounted rear light two blocks ahead! Coming towards me was someone with a bar-mounted headlight, and I saw him a couple of hundred feet ahead, at the most, and might just as easily missed him. When I'm driving I also appreciate seeing that headlight bobbing up and down over the tops of cars parked to my left rather than not seeing the guy with light on his bars.
I've wondered the same thing, about getting a light driven straight into my skull in a wreck, but decided based on what I see in traffic that I have a much better chance of not being in a wreck at all if I wear the lights up high, so that's what I do.
Liked 4,512 Times
I've had animals shadow me in the pitch black. A bit of an eerie feeling.
If only I had a light that when I turned to look, I could actually see what it was.
n00b
Quoted: 428 Post(s)
Liked 466 Times
I've read reports of owls following riders in the dark. you're essentially helping them hunt, and they chase down any small critters that your bike scared out of hiding.
Liked 321 Times
Here is my fork light. This was 40 miles south of Thanh Hoa, riding first of 3 days to Hanoi with my birthday flowers courtesy of the Muong Thanh deluxe hotel chain. The wind didn't ruffle the flowers at all. LOL. This bag was there all the way up Vietnam. The fork was broken 3 times near the top LS.
I went 30 years with only a boat anchor bottle generator that went years without being used. A couple years all I had was a cheap 3 LED crank flashlight for emergency and getting off the highway too late. I did that one ride, LOL. The power lasted maybe 4 minutes. I took it on this trip also for fixing the bike after dark. Now my phone does this. I have zero use for battery crap on a bicycle anyway.
So only since 2012 I've had my awesome SA XL-FDD. 5 years ago I spent the 5 month winter riding from Saigon up to Dafang China, then bus ride and 2 months in Chengdu. So it was dark after 6:30 and there were maybe 6 days I wasn't riding in the dark. 4,187 miles, half city I guess.
My Edelux was on my right fork. I had ZERO problems seeing or being seen. I tilted it down a bit in cities and back up on highways. The people on the sidewalk were often making fun of my light in DAYTIME. LOL. Lots of times it's about the stay on when stopped feature. Several times I was out late on highways and going over mountain passes. In one very curvy spot on top of a mountain, a 40' truck had to cut off the corner and I was totally blinded for a few secs. I wandered into the steep cement ditch/ gutter. I didn't fall or hurt the bike. It was tough lifting the 120 lbs up in the dark moonlight. Truckers were leaning out the window and waving many times. They are NOT thoughtless goons.
There were many miles going thru road construction, some at night too. They patiently waited if necessary.
BTW ... I never wear a STUPID Hellmet anyway. LOL
Liked 4,512 Times
I also had one where I passed a campsite a little after dusk. Then heard the pitter-patter, then quiet pant of a dog coming up behind me. I gave out my usual dog "GO HOME" Roar (never heard any reaction from the campsite), but that was just before plunging down a hill past a dam. I always wondered if I should have just let the thing chase me down the hill into obscurity.
