rare find? Gipiemme frame & etc?
Quoted: 7 Post(s)
Liked 7 Times
Just bought this in a dark, dusty corner of an obscure shop where it had been slumbering approximately 20 years.
I'm wrenching and completely restoring it.
The only/only marking I can find on the frame whatsoever is: Gipiemme, at the end of the rear forks.
The wheels are Gipiemme.
Seems to have a rare and unique crank set. "Lazzeretti." Anyone know what that is?
Comments welcome!
Comments welcome!
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,182 Times
Here you go....Type in the name Lazzaretti, lots there, it's not a "Gipiemmi"...I believe they supplied parts to a lot of builders.
BTW, it would be nice to post some pictures of the entire bike..drive side a must...and tell us a little more about how you found it.
Without the pictures, it could just be a nice frame with a Lazzaretti crank.
https://www.bikeforums.net/classic-v...azzaretti.html
Best, Ben
85campione
Best, Ben
85campione
Voltaire
Voltaire
Disraeli Gears
Gipiemme (phonetic Italian for the company's acronym "GPM": Gi Pi Emme) made the dropouts, that's all. Like seeing "Campagnolo" or "Simplex" or "Suntour" on a dropout. That's a mid-80s dropout (short horizontal).
Quoted: 3822 Post(s)
Liked 3,369 Times
within the past year & one half we had two threads on a Lazzaretti machine hailing from 1969-70 which turned out to have been constructed by Galmozzi (no less!) -
https://www.bikeforums.net/classic-v...bike-56cm.html
Likes For juvela:
Quoted: 4524 Post(s)
Liked 6,419 Times
@85campione
That crankset is fantastic, it is also Gipiemme, time capsule condition, I would move that hacksaw off the bench at this point.
If Galmozzi built is in the best possible way.
Great score, well done.
Bianchi Goddess
Quoted: 2942 Post(s)
Liked 2,947 Times
That hacksaw combined with “wrenching and restoring” makes me nervous.
did you take the paint off?
Sugar "Kane" Kowalczyk
Likes For Bianchigirll:
Quoted: 7 Post(s)
Liked 7 Times
sincere thanks to ALL who replied. I'm posting more pictures now. Perhaps the frame is Campagnolo, but I'm not sure (absolutely no markings or numbers on it other than a "O" on the bottom of frame). The bike was stored for 20 years. It is a gleaming chromed frame. Someone said it was in vogue in the 1980s, someone else said no, the paint must've been removed. No badge, no decals, no frame markings, nothing. But it looks Italian. Lazzaretti (Gipiemme) crank set and Gipiemme drop outs which appear to have been welded perfectly grinded on the frame (i.e., they are not removeable). Is that strange? Campagnolo headset. Not sure who made the seat post but I believe it is Italian. Gipiemme wheels. The frame has a Campagnolo bracket which holds the upper end of the bike pump. The brake handles and rear derailer are not original. The bike was acquired approximately 25 years ago from a Washington DC collector and has been stored ever since. Nothing further is known about its history.
Liked 3,369 Times
the stay crimping technique at the dropouts is something which was done by Teddy Carnielli
it was not unique to him however so may not advance an identification
have no guesses as to maker
MauriceMoss shall almost certainly knowest...
Quoted: 1609 Post(s)
Liked 2,216 Times
Good clean up!
Campagnolo did not make bicycle frames. Drop outs are the part the axels clamp onto, they are always brazed onto the frame when discussing C&V. AL frames can have a removable RD hanger. Frames like this are brazed and not welded. The clean joints are filed and not ground.
How much does it weigh?
Quoted: 2510 Post(s)
Liked 2,991 Times
In case it isn't yet clear to the owner of the bike in question from the various posts above, the bike brand is Lazzaretti. It was common in the 1980s for Italian builders of top-quality racing bikes such as your Lazzaretti to equip the bikes with "pantographed" components (i.e., with the bike brand name engraved in each component), including, e.g., the crank arms, chainrings, stem, seat post, and brake levers.
Stunning bike, by the way. As hinted at above, be careful with the restoration, not that it appears to need much. For example, make sure that you don't damage the threads in the crank arms when you install the pedals. It's probably safe to say that those pantographed crank arms are all but irreplaceable.
Liked 2,991 Times
Not cromovelato, but here's what the Lazaretti's decals might have looked like (and note the pantographed chainring):
Randomhead
Liked 3,713 Times
The chrome is polished, so this means it was either not painted or it was cromovelato, which tends to chip badly and I'm sure a lot of cromovelato bikes have had the remnants removed. Looks great until it doesn't.
PM me your cotters
Quoted: 1137 Post(s)
Liked 590 Times
Rear mech needs a solvent bath. Shiny everything on the bike, then you get to the rear mech and it's loaded with gunk
I question whether it's actually a Lazzaretti, a pantographed crank in better condition than the frame doesn't make it so. I'd expect there to be additional pantographing on the fork crown, stay caps or elsewhere, lest it was lower-end. But who am I?
I agree with the observation this bike was probably chromvelato.
Some Lazzaretti examples:
https://steel-vintage.com/lazzaretti...le-1978-detail
https://steel-vintage.com/lazzaretti...e-1980s-detail
https://steel-vintage.com/lazzaretti...le-1982-detail
Likes For francophile:
Quoted: 1620 Post(s)
Liked 2,636 Times
https://sfbay.craigslist.org/eby/bik...292117843.html
Vintage Lazzaretti 58 cm (c-t) - $475 (hercules, pinole, san pablo, el sob)
image 1 of 10
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,398 Times
Question for the OP - was that Shimano rear derailer that's visible in the background of the first set of pictures the original RD on the bike? If so, would recommend putting it back on. It's 10 times better than this one.
-Kurt
Likes For cudak888:
PM me your cotters
Liked 590 Times
85campione are there any other stampings or markings anywhere on the frame, aside from the apparent "O" on the bottom bracket shell? In one of those pics it looks like there could be some faint numbers between the cables on the bottom bracket shell, but maybe my eyes are playing tricks on me.
Typical places you may find markings would be on the seat stay caps, top of the fork crowns, in the case of some like Faggin, into the dropouts, or cut/stamped into the lugs.
I'm just grappling with this actually being a Lazzaretti. I honestly don't think it is. I wouldn't expect such not-sloppy-but-not-neat lugwork, no branding on the main pieces whatsoever, apparently no lug filing, no cleanup of the seat cluster brazing... it seems really uncharacteristic.
I almost get an mass-prod Olmo-ish vibe off it, but it's definitely not that either.
PM me your cotters
Liked 590 Times
Specific spot I'm referencing, starting from the left it looks almost like an "S" followed by a space, then maybe a "4" and an "8"?:
Quoted: 7 Post(s)
Liked 7 Times
Thank you for your diligence and sharp eye Francophone, but I could not find anything, even under strong light and a magnifying lens. I have sent the photos to Cicli Lazzarretti in Rome and asked if they can identify the frame as Lazzarretti or not. Will advise.
Quoted: 7 Post(s)
Liked 7 Times
Lazzaretti Roma just looked at the photos and informed me that "unfortunately, it is not clear what type of frame. It is certainly not Galmozzi. Unfortunately, we cannot help you more than that. Sincerely, Lazzaretti."
Likes For 85campione:
