Centre-pull yoke with QR?
Quoted: 1106 Post(s)
Liked 1,326 Times
Have this situation:
Brake lever with no QR.
Centre-pull brake with no QR.
Raleigh rear cable stop (half-hoop brazed to seatstays).
Don't want to change levers/brakes or use a seatpostbolt-mounted stop.
Is/was there a yoke with an integral QR?
Quoted: 235 Post(s)
Liked 349 Times
I know this isn't a direct answer, but is there a barrel adjuster somewhere along the line? If you otherwise like the yoke you have, set brakes up with barrel adjuster out and adjust in to remove wheel. It's not that much of a process and you don't need to buy another part. (Of course none of us on C&V want to buy yet another part!)
Quoted: 3808 Post(s)
Liked 6,683 Times
There was a DiaCompe yoke with a QR built in. One problem was that it was made from stamped steel and looked like crap:
Quoted: 235 Post(s)
Liked 349 Times
Dia Compe made a Roller Yoke with a QR. There's a link to a picture of one in a recent Roller Yoke thread.
Quoted: 1607 Post(s)
Liked 2,216 Times
You could close the calipers and remove the yoke cable. Of course the lever cable might make it difficult. Otherwise just run narrow tires, like 21mm!
Likes For SJX426:
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
If the yoke @nlerner posted looks too pedestrian for you, there was also a Gran Compe version:
Likes For JohnDThompson:
Disraeli Gears
The Raleigh half-hoop cable stop was often furnished with a screw-adjuster. Not a lot of movement, but depending on how "tight" you prefer your brakes to be adjusted (I like 'em tight-ish) it might be enough. The hole through the stop is unthreaded, but the ferrule can be raised by backing the nut off while holding the knurled ferrule sleeve. If you have a decent length of brake housing that "wants to be" straight, there are also inline screw adjusters.
I find that it does not take much slack to be able to get the straddle cable free of one caliper arm, and in fact I've filed the inside and outside corners of the little ear closer to centerline on the front side (here) of one caliper arm, to help a bit with exit and entry. Always good to work with a "third hand" tool or a real third hand, but the former is seldom "at hand" on the road. Another ploy is to loosen the brake caliper mounting bolt -- a single 10 mm wrench is all that's required for that.
