Disc Brake rubbing - help needed.
Hey folks, I got a cannondale caad 10, QR disc.
I recently upgraded from a set of mavic Ksyrium Pro disc to EVNE SES 5.6.
Without getting into the debate of rim vs disc...
With the new wheels I cannot get rid of the annoying disc rub, but only when I put some torque on the front end while climbing/standing/accelerating.
Things to be said:
Rotors on new wheels are dura ace and are actually a tad thinner than the Sram on the Mavics
Rotors are true, calipers have been aligned perfectly (when bike is on the stand there's equal gap all the way around, no rubbing), pistons have been cleaned and retract evenly, pads are organic so should be quieter than metal ones.
The wheel is seated all the way in the dropouts and skewer is tight as hell. I noticed that it seemed to get a little better when I tightened the living crap out of it, but still a little rub.
Here's my guess to what's happening: there's a little flex/play in the hub that causes the evil rub. I don't know if the fact that the Enve's are really a 12x100 hub converted to 9x100 via caps exacerbates the problem. The Mavic hubs were born as a true 9x100 QR disc hub, and although things are a little finicky to get aligned (welcome to the disc world), I can always get them right.
I'm almost thinking about using one of those 12 to 9 sleeve adapters to see if it helps, although the clamping force should still be transferred from the fork to the end caps (it would be the 12mm caps though). to the to the axle to the hub body.
Before I resort to my park tool NE 4.1, any suggestions?
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
I think the OP is on the right track w/ his thinking, and it may end up being really hard to get this perfectly quiet.
Likes For cxwrench:
Bikes: lots
Liked 2,932 Times
I'm very happy for you, and mightily impressed. Still doesn't mean you know what you're talking about. Seems to be a typical stance for guys that make good money, you think it automatically includes knowledge.
Likes For dsbrantjr:
Likes For Ti473:
Clark W. Griswold
Quoted: 4335 Post(s)
Liked 3,958 Times
Oh wow you make more money than the poor stupid bike monkey who dances for your crappy huffy good on you. I enjoy what I do and I am sure cxwrench would say the same. I get to be around bikes all day, sure I don't make a ton of money but I have a more fulfilling life than being some random schmuck in an office.
Anywho to not derail things further I think the disc brake problem is a tough one. It could be that you are getting some flex while you are pedaling and that can cause rubbing especially with QR wheels. I have certainly seen that when no rubbing in the stand but when you get in the saddle it will make little ticks here and there. There isn't a good solution for that aside from getting a new fork and going thru-axle but that is kind of the nuclear option and really isn't worth it. If it is significant rub than you rotor could be out of true which is getting more common these days especially with Shimano rotors sadly (they are usually great rotors with few issues but the past couple years have seen a slight increase in out of true rotors not huge but enough to notice it)
Likes For veganbikes:
The rotor is as true as it's gonna get. Not to the micron or anything but after fine tuning it, it's probably truer than they come out of the box.
the gaps are pretty even and consistent all the way around when on the stand. I think the problem is flex in the hub. Like i said the other wheel does not rub, even with slightly thicker rotors, so i think fork is fine.
I have a spare set of QR caps for this that i am going to try to mod by flushing out the 9mm flange and opening the hole to 9mm so i can use a DT swiss RWS axle/skewer i just remembered i had laying around. This hopefully stiffens things up a little... We'll see
Bikes: lots
Liked 2,932 Times
Administrator
Quoted: 11954 Post(s)
Liked 6,611 Times
Glad to see someone got the hint. Let’s find a way to get along, or just move along.
Likes For BillyD:
Advanced Slacker
Quoted: 2761 Post(s)
Liked 2,534 Times
I am inclined to think that acceleration and hard pedaling in and of itself is not going to cause the front to rub.
Do you mean it rubs when the front wheel is side loaded? Does it rub if you are coasting in a straight line and lean the bike to one side?
Advanced Slacker
Liked 2,534 Times
Liked 742 Times
Oh dear me... what have I done? I wasn't aware that only Professional Bike Mechanics were exclusive to the Mechanics portion of the website and they were the ones to respond to questions. I had no intentions of bringing out or offending the Prickly Petes here. In the future I will let the Pro BMs answer all the questions!
it does not rub if you're just pedaling in a straight line or even turning. But when you accelerate/stand and basically put some torque on the bars, it creates some flex that is enough to produce that rubbing. If I stand next to the bike and put some weight on the bars you can see the pads getting closer to the disc. I think to some degree flex is normal, but shouldn't be so much that pads rub.
Monkey Boy
Bikes: '22 Surly Straggler, '15 Breezer Downtown EX, '19 Motobecane Record (fixie)
Quoted: 77 Post(s)
Liked 90 Times
Just throwing this out there, I was chasing down a brake rubbing issue during a ride last week, and it was driving me bonkers, every couple of miles, I was backing off the pads hoping to eliminate that stupid sound. In my case, it turns out that I was actually getting some spoke rub on the wheel. I retensioned the wheel (I neglect this bike even though it get used the most) and then the rubbing went away. I could not believe that I didn't think of that first (aero spokes in my case so a lot of surface area to rub). Anyway, just throwing it out there that there might be something else that's causing the noise. In my case, on the stand the wheel was silent, but under load it was noisy as heck.
Artist | Musician | Bass Player
Life is what happens to you while you're busy making other plans. (o.o)
Quoted: 1247 Post(s)
Liked 1,321 Times
I have had instances with SRAM calipers not moving equally and had to offset to stop rubbing.
Bikes: lots
Liked 2,932 Times
His offer of help was incorrect, that's not how you adjust a disc brake. The OP has done everything correctly so I can't offer any help, but I can warn him that certain advice shouldn't be followed.
Likes For cxwrench:
Blamester
How big is the gap between piston and rotor?
Push on the wheel at the rim on the stand and see where the rub is. What play is in the hub to cause this? Which side does it rub.
You have to try other things.
Slacken the rotor bolts land pull the brake hard and rettorque the bolts. If that doesn't fix it try the caliper bolts. Test the brake before you ride it.
Or if it's very slight rub it will eventually wear in.
Bikes: Focus Arriba, Specialized Roubaix Expert, Bianchi Impulso Allroad
Quoted: 109 Post(s)
Liked 82 Times
I think maybe the torque introduced by the aggressive riding is slightly flexing the fork legs and causing the rub. I had an old MTB with first-gen hydraulic disc and QR hubs... and the flexy Judy Suspension fork definitely contributed to brake rub, even though none existed in the truing stand. Not a great solution from a cost standpoint, but maybe swap the fork out for one with a thru-axle and get a compatible wheel?
Or maybe just use two credit cards inserted in the caliper when you gap the brake pads like I did with that MTB.
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
I double checked the thread title. It's about brakes, not other people.
Likes For Homebrew01:
Quoted: 942 Post(s)
Liked 526 Times
That is a pretty tight gap between the rotors. It's definitely due to flex when you get on it. So the question becomes, how do you get a little more space on either side of the rotor? You've done everything I would have tried to include cleaning the pistons and working them in and out to make sure they don't stick on one side or the other. You've aligned the caliper by hand.... The only thing left to try is bleeding the system, but I don't think it will fix the gap issue since you said the pistons are working as they should.
