Does anyone have (or used to have) a 97 or 98 Litespeed Tuscany?
I found a pretty good deal on a Litespeed Tuscany that is probably either a 97 or a 98. It doesn't have the GET tubing or at least no to the same degree as the newer models. It might have a flatted down tube at the bottom bracket? I've heard that Litespeeds may have gone down in quality lately (maybe) but I'm wondering if this frame is likely to be significantly less stiff than a newer one (with the emphasis placed on "significantly" - I'm not a serious racer). Does anyone have any experience with older Tuscany's? Also, can anyone with an old catalogue tell me if its a 1" or 1 1/8" headset because I want to upgrade to threadless. Thanks.
Now with racer-boy font!
Bikes: 2004 Litespeed Tuscany, Trek 5500, Breezer Storm, Bianchi road bike (fixed)
Originally Posted by jlapennas
...I've heard that Litespeeds may have gone down in quality lately (maybe)...
The welds on my '04 Tuscany are perfect.
Anyway, a friend has a pre-GET Tuscany and he loves it. He talked me out of a steel bike and into buying Ti. Sorry, I can't say if the pre-GET is more compliant or not. Have you been able to ride it yet?
www.eastalabamacycling.org
The main beef I've heard about newer Litespeeds relates to aluminum shells (or something) in the head tube and integrated headsets. I know people debate this all the time but if you've ever really contemplated the physics of the situation or looked at a beat up bearing set, cup, or cone I think it's clear that the headset is about much more than steering and it needs to be fully replaceable.
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times
Originally Posted by davis
Litespeed has moved away from integrated headsets for 2006: 2006 Tuscany
Regarding the origional topic, LS switched over to 1-1/8" steerer tubes in 2001 for the Tuscany line. That's the year they upped the size of the down tube from 1-3/8" to 1-1/2" as well. Based on this fairly small down tube, I'd expect the older frame to be a fair bit flexier, but ride better, than the newer one. Stiffness or ride quality, you can't have both.
Hope this helps.
Ed
Bikes: Cervelo Soloist Team, Cervelo SuperProdigy, Colnago C50
I bit off topic, but I have heard that LS changes things subtly from year to year. For example, I was told that the Tuscany in 2003 and 2004 was noticeably stiffer than 2002 to the point that it was "too stiff". I heard they reverted back in 2005 to the more "forgiving" set-up. I don't know if it is true. Maybe some of the LS experts may know more.
Liked 425 Times
