Tire Sealant
Tire Sealant
My bike is been in the garage for about 3 months without being ridden. It has been hotter than blazes this summer. It looks like the summer heat will break in the next few weeks so I want to get the bike ready to go. To that end I am sure I need to add sealant to the tires. I wanted to ask how much sealant do you recommend I add to each tire. They are 29".
Thanks in advance.
Thanks in advance.
Quoted: 6976 Post(s)
Liked 10,975 Times
Thanks in advance.
Thanks in advance.
Likes For Koyote:
Quoted: 18431 Post(s)
Liked 15,585 Times
Wouldn’t tire width factor into the equation?
Likes For indyfabz:
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
I think every sealant vendor posts recommended amounts. I usually put in one and and half recommended amount.
Likes For tyrion:
Quoted: 2339 Post(s)
Liked 2,832 Times
Read the bottle, it varies between tubeless, tubular and using tubes
Quoted: 769 Post(s)
Liked 1,749 Times
I live in the South and my garage is generally about 110 to 115 in the summer, I use 40ml of Orange Seal Endurance initially for 28's and 30's and will add about 15ml every 6 weeks or so while it is stupid hot. This year has been more brutal than normal, so I moved to monthly. I will pull some out with a syringe first and if I have at least 25ml then I don't add, but will add some in a couple of weeks.
Likes For jaxgtr:
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 272 Post(s)
Liked 448 Times
You may need to extract what is left of the old sealant.
From front and rear of 2.6” 29er tires. Bontrager sealant after 6 months.
Likes For biker128pedal:
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 298 Post(s)
Liked 676 Times
The 1.5oz lasted about 13 months (approx 1500 miles) with no flats.
Temp reached 36 centigrade once.
After 13 months I got 3 flats in 2 weeks, put 1oz of new Orange Seal in and no flats since.
Quoted: 272 Post(s)
Liked 448 Times
The blue latex coats the tire wall. That is the left over water extracted with the injector syringe. I just have to remember to extract it and add more active sealant. I may need to try another brand. It’s a Fuel Ex 8 I got last January. I’m setting up my Domane tubeless soon so could use another in it. I just have to remember what is used where. It’s gravel wheel set up uses Stan’s sealant.
Sunshine
Quoted: 10971 Post(s)
Liked 7,499 Times
